06-14-2018, 08:07 AM | #2069 | |
Rep 23
06-14-2018, 02:30 PM | #2070 |
Rep 45
06-14-2018, 03:04 PM | #2071 |
Rep 190
06-14-2018, 03:08 PM | #2072 |
Rep 45
06-14-2018, 03:46 PM | #2073 |
Rep 190
06-14-2018, 04:22 PM | #2074 | |
Rep 23
You can set the monitor to remember which UI menu to boot into each time your car starts. To set the monitor to boot into the Android Menu UI: 1. Open the Music Player 2. Now turn off the car and wait 45 seconds. 3. Turn the car back on and the monitor will remember to boot back into the Android menu each time. ===== To set the monitor to boot into the original BMW iDrive Menu UI: 1. Switch to the original iDrive menu any screen will be ok. 2. Now turn off the car and wait 45 seconds. 3. Turn the car back on and the monitor will remember to boot back into the original BMW iDrive Menu UI. |
06-14-2018, 04:35 PM | #2075 | ||
Rep 45
From post above i understood that Cactus_BMW to configure the unit to always boot in Android side. |
06-14-2018, 04:41 PM | #2076 | |
Rep 190
Think that you have your android phone or tablet. Does it boot in the last used app if you take the battery off ? That could be possible only if the system was in sleep state but this is not an option with our units. They cold boot every time you switch the ignition off for more than 30 sec. that for when you switch on the ignition it always goes to I drive screen since ccc or cic or nbt systems are faster or are in sleep state and the screen only saws the signal that gets from the entertainment system. Maybe I am wrong but it seems logical. Last edited by koutsouk; 06-14-2018 at 04:46 PM.. |
06-15-2018, 10:39 AM | #2077 |
Rep 428
Does anyone know of a UK supplier for the CarPlay adapter? I want to add this to my unit but purchasing through Avin looks like it might be very expensive??
Thanks. I'm also after a reversing camera if anyone knows of a good compatible one (preferably from a uk supplier) |
06-15-2018, 11:16 AM | #2078 | |
Rep 108
For me, I wouldn't want it to boot android first, as I would need to wait and look at BMW animation screen This way i can listen to radio immediately, like in OEM unit... |
06-15-2018, 01:32 PM | #2079 | |
Rep 45
I can confirm the above Avin procedure worked for me, i opened the music player and turned off the car and when i cam back after 2 hours the display immediately showed the BMW Connected Drive logo and the unit directly booted into the music player as i left it. I am running MCU ver [BMW-0513T-170518] And App Ver: 20180315 |
06-15-2018, 11:16 PM | #2081 |
Rep 23
06-17-2018, 08:12 AM | #2082 |
Rep 108
Strangely enough it works on my unit too .. It's enough Just to left music app open and turn off engine... At next start it boots to Android and continues to play the song
06-17-2018, 08:54 AM | #2083 |
Rep 584
A new issue, went to install Chrome so I can use the browser tab, when I go to open it a strange Chinese one opens first, can get to Chrome but only after a bit of a faff, any ideas? Can't find it to delete, very odd.
Mick |
06-17-2018, 09:37 AM | #2084 | |
Rep 201
I saw an option in the factory settings about Google. Thought that was odd but you might want to check there. Cheers |
06-17-2018, 10:11 AM | #2085 |
Rep 584
Cheers, Bob, I'll go and have a look. How you getting on with the new unit? Fingers crossed my Avin seems to be plodding on without issue, hope I've not just shot myself in the foot...….
Mick |
06-17-2018, 10:22 AM | #2086 | |
Rep 201
Let me know if that works for you.. |
06-17-2018, 11:44 AM | #2088 |
Rep 37
internet connection issue
My internet connection is disconnecting in 5 minutes every time. I need to reset the device to reconnect. Could you help with this problem?
06-17-2018, 11:57 AM | #2089 | |
Rep 45
I left the car at the home screen in android side two days ago, and when returned the unit booted into android, and music player was loaded. Hope this helps. |
06-17-2018, 09:05 PM | #2090 |
Rep 23
Thank you for sharing. I can’t get it to stay on the Android side consistently. I park in reverse and the only explanation I might have is that I must be turning off the car on the reverse screen which I guess is on the BMW side. If I get to fix this I will share the solution.
