09-15-2013, 02:43 PM | #1 |
Rep 579
Why is the 320i faster than the 328i?
The latest Motor Trend has an article on the 320 past & present and they found their 2013 tester pulled more g's and was faster around the figure 8 than the current 328i - .91g, 26.2 @ .7g vs .89g, 26.3 @ .7g for the 328i. I found this surprising since they share the same engine so there shouldn't be any weight advantage there. So is there a legitimate dynamic advantage of the 320i or is it due to drivers, conditions, or the 320i being lighter due to being de-contented?
Instagram: te37sl_m3
09-15-2013, 03:12 PM | #3 |
Rep 57
320i is 100 lbs lighter. According to BMWUSA website, automatic 320i has 3295 lbs and automatic 328i has 3410 lbs.
09-15-2013, 03:29 PM | #4 |
Rep 128
Worth noting that the 320 is barely faster around the track. It's hardly a runaway victory.
I bet, if the same cars were run around the same track 10 times, half of those times the 328 would be faster. In other words, they're evenly matched on the track. |
09-15-2013, 03:51 PM | #5 |
Rep 2,181
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
What a pleasant surprise! Cool article.
09-15-2013, 04:08 PM | #6 | |
Rep 3,619
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
09-16-2013, 02:19 PM | #9 |
Rep 3,331
G ratings are primarily a function of weight and grip. A slightly lighter weight plus tires that are either the same or possibly slightly better will give you a better cornering car.
With that said, upgrading to a set of sticky summer tires and you'll suddenly be ahead again in the 328i, so it's not worth confusing the issue. That extra power would be noticeable on the street and the track.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
09-16-2013, 02:40 PM | #10 | |
Rep 3,619
I think the 320 is just a great performer and the factors you set out do not impact this test as much as we would like to think.
09-16-2013, 03:27 PM | #11 |
Rep 10,509
Would be helpful if the magazine posted info on the tires and conditions when testing.
My understanding from the BMWUSA website is that the 320 sport package comes with 225 front 255 rear tires and the 328 sport line comes with 225 wide front and rear (M sport line needed for 225 front / 255 rear tires). The extra width of the rear tires, plus a difference in the tire compound or test conditions could very well account for the difference. Not really a surprise.. E90 328 had similar skid pad / figure results vs E90 335. |
09-16-2013, 03:32 PM | #12 | |
Rep 2,181
Drives: .
This reminds me of a really interesting article in a car magazine where they touted the 320i as the overall best of the 3 series range (not trying to sound like a douche!) in SA. I was pretty shocked as I thought the 328i deserved it due to great pricing and performance. But recently I've been realising how amazing this car really is. Quite affordable and decent performance too |
09-16-2013, 03:37 PM | #13 | ||
Rep 3,619
Motortrend seems to be implying the 3 series recipe is most evident in the 320i. Here is the online version http://blogs.motortrend.com/more-tha...#axzz2f5enrOMZ
09-16-2013, 04:09 PM | #14 | ||
Rep 2,181
Drives: .
Bear in mind that this article is focused on the first-look of the 320i. It's from September 2012. Also take note that the tested 0-100 times are not close to manufacturer's claims. This is largely due to the fact the Carmag SA tests all cars with two adults sitting in the car and a full tank of petrol. Also know that I don't intend to belittle other F30 models nor do I have any insecurities about my entry-level car, by posting this article up. |
09-16-2013, 04:27 PM | #15 |
Rep 2,181
Drives: .
Here is the comparison data between the 320i and 328i that is referred to in the article I posted above. They are scans from the magazine itself. Sorry about the quality.
09-16-2013, 04:28 PM | #16 | |||
Rep 3,619
09-16-2013, 04:34 PM | #17 | |
Rep 2,181
Drives: .
Check out the performance comparison that I posted above between the 320i and 328i.. |
09-16-2013, 04:43 PM | #19 |
Rep 2,181
Drives: .
Lol, I honestly thought that the combination of handling and better performance would make the 328i faster. I didn't realise how significantly weight comes into play for this small test.
09-16-2013, 04:43 PM | #20 | ||
Rep 3,619
09-16-2013, 05:18 PM | #21 |
Rep 2,181
Drives: .
09-16-2013, 05:27 PM | #22 | |
Rep 3,331
A figure 8 is nothing more than a glorified skid pad. It's great as a magazine metric, but it's a number that's easily modified. 1: Not all run-flats are created equal. It's well known BMW configures their cars with different tires even in the same class. I'm willing to bet one set of those tires provides marginally better grip. Even if it's the exact same tire, different tires will perform differently based on their wear, temperature, and PSI. I could make the exact same car, on the exact same tires perform differently in the skidpad/figure 8 just by adjusting a few PSI in or out of the tires. Also, the weight difference posted in the second set of posts shows a much narrower weight gap. The weight of the car has a lot more to do with how it is configured. You can bet that just adding a navigation system and some seat heaters and window washers will tweak the weight of the car. This isn't rocket science, and skidpad scores that are .1 second different on different cars on different days, don't mean the car will lap a race track faster, out corner you in a turn, etc. Skidpads are no different than dyno tests. I can take my car to 5 different dynos, and do 5 runs on 5 different days, and every one will give me a different number - you have to take that information for what it is, and not for what it isn't.
