01-24-2022, 08:24 AM | #23 | |
Rep 5,457
Drives: F30
Any reason this simple screen swap and coding would not work on my 2016 with NBT/EntryNav screen? What sort of increased functionality do you get, besides the obvious aesthetics of the bigger/nicer screen? Currently mine wont even play DVD's... wondering if that will now be possible with the 8.8 display. |
01-24-2022, 02:30 PM | #24 | |
Rep 23
Hard to say if this screen will work with your 2016 NBT/EntryNav. I would "think" so, but I had to do a lot of research on 2 things until I felt I had a solid replacement. I had to get the part numbers for my 6.5" screen and NBT headunit. Then fortunately there were a couple others who had essentially the same and I felt comfortable to make the swap. What I found not to trust is "look it up on RealOEM". RealOEM did not reflect my exact set-up, it throws out a bunch of configuration options. I also had a January 2017 build, which was the LCI switch-over month I believe for the F36, so it's possible my situation is not the same as others and things were in flux that month. What is your current screen part number? And do you know which part number of HU you have? |
