01-01-2022, 05:25 PM | #23 | |
Rep 4,871
Samir72433.00 |
01-01-2022, 06:41 PM | #24 |
Rep 3,185
When I had my E90 N55 there was a table for altering traction control/dtc sensitivity. I don't know what tables are available to these tuners, but there is a chance to desensitize traction control. Sounds like that's what's happened.
01-01-2022, 10:56 PM | #25 | |
Rep 223
01-03-2022, 07:16 AM | #27 | |
Rep 4,871
I'm running winter tires right now, it's cold, the roads are slippery, and if what you said was true, the car would have been wrapped around a light pole weeks ago. |
01-03-2022, 08:41 AM | #28 |
Rep 27
Are you running the new V2.2 map ?
Asking as it's weird why some of us are getting huge amounts of uncontrolled wheelspin and some are getting assist from TC. I flashed back to the 2.1 map and although there is some wheelspin it is definitely being reigned in by the TC. Am going to switch back to 2.2 to compare the difference |
01-03-2022, 12:42 PM | #29 |
Rep 4,871
The 2.2 map removes the 550NM torque limiter on the gear box which is allowing you to get the full power from the tune. If you did the xHP, you would have already overridden that limiter.
You can always spin the tires (even OEM mapping) if you spin up the revs fast (TC won't intervene) With that limiter gone, you aren't seeing the throttle cut when stepping on the has hard. |
01-03-2022, 12:55 PM | #30 | |
Rep 3,368
01-03-2022, 01:08 PM | #31 | |
Rep 4,871
The new 2.2 maps claims more boost (so more power). Roads are crap right now, so I cannot confirm or deny. |
dmanb2b2123.00 |
01-03-2022, 01:59 PM | #32 |
Rep 4,871
I just took the car out for a spin. TC is functional in comfort and sport (you can see the indicator light up on the dash). Stability control kicks in in comfort and sport when you take a corner fast on snow as well.
That being said, it "seemed" like TC didn't engage as much as I have remembered in the past. Now I don't know if it's because traction is zero right now, and this map wants to spool really fast so I'm getting over limits that allow for TC to be inhibited, or if PTF have lowered the throttle/load limits so its not as invasive. That would be a question for them. |
WolfGTI716.00 |
01-03-2022, 02:31 PM | #33 | |
Rep 5,391
I'm kinda surprised that no one has yet mentioned the option of going into the Map Config on Bootmod3 and adjusting the Boost By Gear (% Reduction) parameters. In the past some friends with RWD had talked about adjusting lower gears to get off the line without spinning their rear wheels. See photo from Bootmod3 config menu. You didn't mention which tires you currently have. If they are stock runflats with 25k miles, they could definitely be shot and sliding all over the road. Most popular all seasons are Continental DWS06 PLUS and Michelin Pilot Sport A/S4. IMO Best summer tires are Michelin PS 4S. Hope this helps! |
01-04-2022, 02:54 AM | #34 | |
Rep 27
I'm just waiting for a suitably wet day to do some proper back to back tests to see if there really is a huge difference between v2.1 and V2.2 |
01-04-2022, 09:05 AM | #35 | |
Rep 4,871
When I went from Stage 1 to stage2 of the 2.1 maps, I had to "reprogram the brain" for manual mode. The car revs snapped up so fast that in sport mode it kept doing throttle cuts off the rev limiter before I pulled the shifter. At the end of the day, the tune is adding a lot more power than the OEM car was initially designed around (including the safety features). The driver needs to be more in tune with the car and what it is doing, and less of a "punch the gas and the nannies will save me". Going to Sport+ removes a lot more of that stability control and when coupling that with more power + inexperienced driver = trouble. |
WolfGTI716.00 |
01-06-2022, 06:12 AM | #36 | |
Cheapskate
4445
Rep 4,993
I have a manual transmission so no concern with transmission torque limits, and the car definitely spun sometimes 1st gear on stock turbo maps. I already had good summer tires, so i hooked 2nd gear and up pretty easily. It never spun to redline since I lifted and the car corrects itself very quickly. I haven't tried the new maps but every time I hear this it's the same thing. Maybe post a log in comfort mode to show what you mean. When I'm spinning, I can see the vehicle speed/rpm spikes in my logs. |
johnung4525.00 |
01-06-2022, 05:20 PM | #37 | |
Rep 4,871
What I have seen with this map as well as pre-BM3, is light throttle acceleration on slippery surfaces engages the stability control and traction control (you get the lights on the dash). If you start getting into the petal and loading the car down, it allows you to bypass those limiters (to a point). IE: I can stomp on the gas at a stop light on slippery roads, the tires will spin and I can feel the x-drive shuffling power between axles to keep things in line. At no time did it ever go to lethargic safety mode and do full throttle cuts. The 2.2 maps do seem to bring a lot more midband torque to the table which is super fun! |
01-07-2022, 08:46 AM | #38 | |
Rep 122
Yesterday did a quick comparison between Stage 2 91 V2.1 and V2.2. What I found was that on V2.2 the traction control still works but the intervention is much less than on V2.1. Meaning I got much more wheel spin with V2.2 than with V2.1 in the same situation. Only tested it in comfort with gearbox in S.
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
01-08-2022, 11:54 AM | #39 | |
Rep 4,871
01-08-2022, 12:12 PM | #40 |
Rep 82
I can basically drift in comfort on 2.2 now. It’s not really a problem since im used to high power cars, but TC is definitely more lenient than it was in the last version. Ive been on xhp st3 for a while now. Id recommend ptf developers put the training wheels back on in comfort otherwise i wont feel comfortable letting anyone else drive my car lol
01-08-2022, 01:12 PM | #41 | |
Novice
300
Rep 693
Last sentence was funny. That's cool to know that you can do more in comfort with the v2.2 map but honestly they should add back the v2.1 (training wheels) for anyone who didn't previously copy them in their map storage. |
01-08-2022, 09:18 PM | #42 | |
Rep 126
Why not? |
01-09-2022, 03:40 AM | #43 |
Rep 122
I don’t think so, however haven’t driven the 2.2 much yet.
Also PTF said they got rid of the boost spike which could explain why 2.2 feels less punchy/aggressive than 2.1 and that should help with traction. But we seem to have less traction so it’s more likely a TC issue? When I have some time I will put xHP back on and do some more testing with 2.1 vs 2.2, because maybe the removal of that torque limiter in 2.2 has something to do with it?
Wires1644.00 |
01-09-2022, 10:37 PM | #44 | |
Rep 146
Stage 2 + 93 octane XHP STAGE 3 I'm having the same issue. I've added coilovers and Nitto nt05's Did get better but still have issues in 1st and 2nd I will be doing boost reduction in the first two gears. I started at 15 % reduction and the wheels still lost traction. In both 1st and 2nd I will go up to 20% to see if it fixes my problem. |
