BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > DIY 6.5 to 8.8 L7 display retrofit swap for 2014+ f2x f3x
      10-10-2016, 05:38 PM   #67
Anderw
Anderw's Avatar
Drives: F80 m3
Originally Posted by taranfx View Post
I didn't understand that. My screen is base 6" screen with no navigation. Model: F30 2015. Could it be manufactured in 2014 and yet called 2015 model? Can I have this screen upgrade?
Also, There's another thread where someone managed to install F10's 10.2" screen. Can we leapfrog to that?
http://f30.bimmerpost.com/forums/sho....php?t=1168747
Yes a 2015 are made from mid summer 2014 to beginning of summer 2015 so more then likely it would still work for you, and yes questions but to fit a 10.2'' you have to cut into the dash to make it fit so its not completely reverable also coding will be different entries since the display resolution will be different and most likely will need to be added to tho possible logs another way. basically 8.8 works clean and easy , 10.2'' may get messy!!!! lol
      10-10-2016, 05:41 PM   #68
taranfx
Z4 35is
taranfx's Avatar
Drives: 2011 Z4 35is || 2016 435i
Thanks, I checked production date is 2014-07-09.
"more then likely it would still work"
Is there a chance it wont work?
      10-10-2016, 05:42 PM   #69
MarkoSK
Drives: BMW G20 330eX
Originally Posted by Smee View Post
Ok I think I got to the bottom of this blue tinge.
It seems to be the angle you look at it from. A low down looking up seems blue but from my normal seating position seems normal
Try taking a photo of the screen with the flash on - you'll notice the display has a slightly blueish accent:
The LCI model doesn't have this, plus it is noticeably lighter than the pre-LCI one. I guess they changed the manufacturer and/or technology, resulting in a different color representation that you can notice only when looking from specific angles.
      10-10-2016, 06:19 PM   #70
Anderw
Anderw's Avatar
Drives: F80 m3
No it will work , I just didn't know your production date month as there are a few exceptions thats the only reason I said more then likely, but your car is within the range of dates so you're good
      10-10-2016, 06:48 PM   #71
taranfx
Z4 35is
taranfx's Avatar
Thanks for the valuable info.
Now its all about finding the deal on screen.
I read about pre-LCI having blue tint and low brightness. And LCI not voltage compatible. Do you know if those are true?
      10-10-2016, 09:21 PM   #72
taranfx
Z4 35is
taranfx's Avatar
Originally Posted by jkishoret View Post
The main reason for me to upgrade to 8.8 is to enjoy the Apple TV ... i have bimmer-tech smartview HD ... but after looking at the display brightness little disappointed.
One more hint to you ... whats the resolution you have set ? are u using 8.8_1280 by xxx as said in this forum ? reason i am asking is .. after watching few videos i felt very disappointed with this resolution ... so as a try i used 10.25_1600x600 resolution and it feels way better.
trying to see if there is any temperature related FDL ... so brightness can be increased ... let me know if you come across any.
Is your car LCI? I've non-LCI F30 2015 6.5" no navigation. And I'm thinking of 10.25" screen instead. Any idea if it will work?
      10-10-2016, 09:25 PM   #73
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Mine is also non lci ... but i am not sure if a 10.5 inch screen will fit in to 6.5 inch slot or not ... even if it fits I doubt the 6.5 inch voltage output can't drive the 10.5 inch screen
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      10-10-2016, 09:42 PM   #74
taranfx
Z4 35is
taranfx's Avatar
It fits after cutting/filing the screen plastic http://f30.bimmerpost.com/forums/sho...1168747&page=6
Only question is compatibility. everyone on that thread is using HU_NBT.
      10-10-2016, 09:44 PM   #75
freespirit
freespirit's Avatar
83
Yup ... it won't power on without coding under hu_nbt
      10-10-2016, 09:48 PM   #76
taranfx
Z4 35is
taranfx's Avatar
You mentioned that you coded 10.25" for 8.8" screen. It sounds like HU_ENTRYNAV has support for it.
btw how much did you pay for 8.8 and where did you get it from?
      10-10-2016, 09:51 PM   #77
freespirit
freespirit's Avatar
83
Yes 8.8 resolution looks terrible so i had to set it to10.25... i bought this from
car-part.com
      10-10-2016, 09:58 PM   #78
Anderw
Anderw's Avatar
Drives: F80 m3
It will work if your willing to cut about 1+/- inch on either side of your dash board away where the screen goes, and possibly the back of the dash as I'm not sure the shape of the rear bezel of the 10.25 display . I would be 100% sure you want the extra 1.45" at the expense of potentially destroying the dash... just food for thought not saying its the worst idea. it is pretty cool
taranfx60.00
      10-10-2016, 10:10 PM   #79
taranfx
Z4 35is
taranfx's Avatar
Checkout http://f30.bimmerpost.com/forums/sho...3&postcount=79
He managed to do it without cutting anything visible from dash.
Looks neat.
Are you sure this works for HU_ENTRYNAV? If it does I'll go that route.
      10-17-2016, 02:10 PM   #80
FeelinBlessed
FeelinBlessed's Avatar
227
Drives: 2017 340i AW MPPSK/Track
2017 BMW  [0.00]
So today I got the coding done and everything works perfectly except they couldn't get dvd in motion to work. They said it's incompatible on my system. It's a major bummer....
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
      10-17-2016, 04:13 PM   #81
Anderw
Anderw's Avatar
Drives: F80 m3
Damn sorry to hear , maybe someone can chime in on how to enable or retrofit
      10-17-2016, 04:45 PM   #82
TePee
Drives: F34 LCI MY2019
Looks neat.
Yes. Entrynav can be coded to 8,8" and 10,25" CID (both use basically the same coding).
taranfx60.00
      10-18-2016, 02:23 AM   #83
taranfx
Z4 35is
taranfx's Avatar
Thanks for your input.
p.s. Does replacing screen void warranty? when they see 10.25" screen, they can easily tell that it doesnt belong to F30 and will that void warranty?
      10-18-2016, 04:00 AM   #84
Abi
Drives: BMW 430d M-Sport
2015 BMW 318d  [0.00]
Hello, can I fit screen from F20 on my F30? There is some difference in back housing, but will it fit physically?
Thank you
      10-18-2016, 04:04 AM   #85
Anderw
Anderw's Avatar
Drives: F80 m3
Thank you
The F30 back is different and the f22 may not fit correctly since the f22s back stick out much further. If you have a f22 screen and want to trade back plates I have a f30 screen in my f22 and would like to trade the plates ! let me know
      10-18-2016, 06:48 AM   #86
MarkoSK
A 10.25" screen will almost certainly void the warranty, since it's not officially compatible with an F30. An 8.8" screen is officially compatible with professional nav, so it depends...
If you have an 8.8" screen, noone will probably notice anything and just think you have professional nav .
The only problem is if they update your car's software, which will revert any custom coding and the screen will be blank until coded again.
      10-18-2016, 06:54 AM   #87
MarkoSK
You can buy a Multimedia Interface (MMI) which has composite and/or HDMI inputs and connect anything you wish. If you google it, you'll find many options.
      10-18-2016, 02:25 PM   #88
FeelinBlessed
227
2017 BMW  [0.00]
Dope! I think bimmertech sells them. But more money....
