BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F30 coding
      01-21-2018, 03:03 PM   #1
gasman82
gasman82's Avatar
17
Drives: F30 335d xdrive
F30 coding
Hi all,
Just joined the forum, already blown away with what you people get up to modifying and changing things on the bmw’s.
I have a 2013 f30 saloon and have been reading the info regarding the coding of different things etc.
I would like the Bluetooth enhanced and the Apple car play if poss, I have got the top spec sat nav unit widescreen.
Been looking at bcables?
Kind regards
      01-21-2018, 05:39 PM   #2
MarkoSK
Drives: BMW G20 330eX
Get an ENET cable or adapter, download eSys software and check out the coding forums for more info.
      02-21-2018, 11:58 AM   #3
dougieled
Drives: F30 2013 M sport
Hi. I've got the same issue as you. I can only answer calls through the bluetooth and would also like the enhanced bluetooth. Is there a way to check if your car is compatible with it?
I was reading that its possible if you have a combox in the boot of the car(which i think i do)
      02-21-2018, 12:42 PM   #4
Jhnblckwood
Drives: F30 2014 320i xdrive
If u have the combox in trunk or nbt then yes possible. Code 6nh to 6ns.
Look in trunk under the lining and see if u have two boxes. One being fuse box the other is on left side n would b combox.
      02-21-2018, 12:43 PM   #5
Jhnblckwood
Apple car play only possible with nbt evo n fsc code which 2013 wouldn't have.
