BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > How to connect aftermarket amp to basic stereo
      12-27-2017, 07:17 AM   #1
carl_t
Drives: F30 320d
Hi all
I want to connect an aftermarket amp to my 2014 bmw f30 with basic stereo.
Can anyone tell me the best way to do this? And are there any harnesses for the job?
Cheers
      01-09-2018, 01:52 PM   #2
drivethrurecfan
Drives: G30 540i
I used a custom F30 AMP harness from eBay that had pre-built RCA's. I believe in the UK your base stereo may be wired differently than the US. In the UK, I believe the base model stereo does not have an external amplifier, the speakers are powered directly by the head unit. Can you confirm if you have an amp in your trunk?
If you have an amp in the trunk, the harness with the prebuilt RCA's is extremely helpful.
if you DO NOT have an amp in the trunk, you will need to buy line converters, or use an amp with one built in to convert the speaker output of 30~watts into an RCA line (not the cleanest sounding method, but still works)
      02-14-2018, 10:07 PM   #3
JneneJ
Drives: 2018 320i
Why is there only 2 sets of rcas? I want to hook up an amp with that same harness but if I have 6 channel amp we're would I hook up the third rca pair?
Jb
      02-15-2018, 07:56 PM   #4
THE_AVIATOR
THE_AVIATOR's Avatar
Egypt
Drives: F30 320i LCI M-Sport
The headunit outputs sound in four lines! 2 to the front speakers (via the underseat subs) and 2 to the rear speakers. You need to take that and depending on your amp, channel it into the speakers.
