BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > EPS Coding
      03-04-2020, 09:37 AM   #1
GlacierF32
GlacierF32's Avatar
Drives: 2015 435i
EPS Coding
Hello,
I recently purchased a used EPS rack and do not have the knowledge to code it. I’ve looked around for ista/esys downloads to code the used EPS, but I can’t seem to find any. Is it worth paying someone to remote code it or is it something I can do myself? Or does anyone have the download and info on how to do it?
      03-04-2020, 09:53 AM   #2
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
I can help you.
Pm please.
      03-26-2020, 11:00 AM   #3
Dark_knight
Drives: 430i M Performance
I also need help, exact same issue. UK based
      03-26-2020, 11:01 AM   #4
Dark_knight
Originally Posted by GlacierF32 View Post
Hello,
Did you get anywhere mate?
      03-26-2020, 05:27 PM   #5
GlacierF32
GlacierF32's Avatar
Drives: 2015 435i
Sort of... when I plugged in the donor rack everything worked right away without any coding. It even knew the end stops. The only thing that doesn't work is servotronic (steering feel change between drive modes). I have repair FSC code for the donor car but I can't seem to get any luck with it working.
      03-29-2020, 07:18 PM   #6
Dark_knight
Ah mine has not initialised at all and the rack is still heavy. Are FSC codes definately required and how are they generated/uploaded?
      04-01-2020, 10:53 AM   #7
Dark_knight
Originally Posted by RuleNormaliai View Post
you don't need any FSC, just code it and initialize with ISTA. when you do initialization you will need to raise your front wheels from the ground.
Cheers, how do i code it? Sorry open question as I need some guidance/instruction.
      04-03-2020, 08:20 PM   #8
GlacierF32
GlacierF32's Avatar
Drives: 2015 435i
I could also use an explanation on how to code it please.
      04-04-2020, 03:53 AM   #9
atzebmw
Drives: Tesla Model 3
The same like any other ecu...
Load and activate the VO
Read Ecu
Mark the EPS
Detect CAF for SWE
Choose the CAFD with the highest numbers or the bottom one or just any one CAFD and hit OK
Hit the button "Code"
      04-08-2020, 07:33 AM   #10
Dark_knight
Read Ecu
Mark the EPS
Detect CAF for SWE
Thanks to both of you guys, really appreciate it.
Will give it a try and report back!
      04-08-2020, 07:39 AM   #11
Dark_knight
Also, can i code it and then do the initialisation?
...and how exactly, do I perform that initialisation?
Cheers
      04-08-2020, 09:49 AM   #12
Dark_knight
Code it with ESYS and initialize with ISTA.
Thanks man, Ive coded with Esys before but not ISTA... is there a tutorial / guide... guessing i need to download it from somewhere first? Sorry for being dumb lol
      04-08-2020, 12:27 PM   #13
Dark_knight
Read Ecu
Mark the EPS
Detect CAF for SWE
Hey Glacier, the EPS isn't found when reading? Your image shows EPS but mine doesn't... could it be a faulty rack or can i try something else?
It successfully reads and shows
ACSM
AMPT
ASD
EGS
...but no EPS?!?
      04-08-2020, 01:01 PM   #14
Dark_knight
Read Ecu
Mark the EPS
Detect CAF for SWE
Here is the screen print
      04-08-2020, 01:11 PM   #15
atzebmw
Did you try both - Read SVT and Read Ecu?
The EPS is new or used?
      04-08-2020, 01:24 PM   #16
Dark_knight
EPS is used mate. I only tried Read ECU. Shall I try the Read SVT?
      04-08-2020, 01:41 PM   #17
atzebmw
Yes
      04-08-2020, 02:04 PM   #18
Dark_knight
Yes
Cheers, will give it another go tomorrow... just on with the ista install...
      04-08-2020, 09:54 PM   #19
GlacierF32
GlacierF32's Avatar
Drives: 2015 435i
Do you have a download for ISTA so I can initialize it? I was able to code the used rack. Thanks for the help!
      04-09-2020, 04:57 AM   #20
Dark_knight
You'll find it and instructions here dude.
Can you share what you did to do that coding? Did you have to Read SVT too? Was EPS missing like mine was?
      04-09-2020, 04:59 AM   #21
Dark_knight
I tried the ReadSVT and it did bring up the EPS... however, the "Detect CAF for SWE" setting was disabled. See screenshot.
      04-09-2020, 06:38 AM   #22
atzebmw
... and start E-Sys direct, without launcher.
