BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Apple CarPlay Retrofit - Done! (Update:16/11/18...now also with full screen function)
proTUNING Freaks
      06-27-2018, 05:01 AM   #111
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by NooBish AbbZ View Post
I'm on a Oct 2016 F30 I think with iDrive 4 pro nav? I don't have the tiles so I'm guessing i'd need everything for this? Antenna, mic, idrive update?
New headunit or flash your current headunit to iDrive 5 - I would not reccomend doing that though as the firmware does not play well on the older hardware.
New headunit coded to your car with everything online retained would be a better prospect, just swap it out before service/warranty work - this is what I have done on my car.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      06-27-2018, 05:05 AM   #112
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by rcerro View Post
Hi guys, I paid time ago for the FSC code to enable CarPlay in my car (F34 2017 with ID5) .. it has been working fine until yesterday due to the BMW software was updated by the dealer and obviously they wiped everything :-(. My current BMW software is 006.017.006.
I already contact with the guy who provide the bin file to enable the CarPlay but I didn't get any response back and I don't think so he will reply me :-( .. my question is: Someone is the same situation has re-applied the CarPlay activation? I'm worried if the FSC Code or bin is not compatible with BMW latest software and I would prefer get some confirmation to avoid any issue.
Thanks in advance
if you still have the .Bin file you can re-apply it. I've tested with the latest version of EVO firmware (version O) and it still works.
If you don't have the .bin I can help you.
x-m4n148.00
      06-27-2018, 12:10 PM   #113
NooBish AbbZ
Drives: F30 340i
I'll leave it as is then Thanks for the knowledgeable reply
      08-26-2018, 10:12 AM   #114
RoundRound
Drives: 2017 F30 330e M Sport
Hello peeps,
sorry to jump in, I'm considering getting a used 330e (F30, right?) 2016 or 2017 and Carplay is very important for me (for Waze - back on iOS12).
It's nearly impossible to find used 330e's with car play and they are often newer and more costly than others. I'd love to code in Carplay after purchase but need to make sure the car I get can support it, can I ask what are the required features for CP to work via coding?
Do you need wifi because it's wireless? or can you skip it and connect the phone with a usb cable? Thank you!
PS
While on the subject, is there a way of getting a 'normal' double din HU like a pioneer? (For sound quality purposes...
      08-26-2018, 10:56 AM   #115
R99
Drives: 2016 330d F31 Touring
All you need is iDrive 5 or 6 on a NBT EVO headunit.
Only works via WiFi, but the antenna is cheap & easy to install
      08-26-2018, 02:30 PM   #116
stormlv
Human
Switzerland
932
Drives: Yes
It works without having the Wifi antenna installed, but you have a much limited range.
If you put the phone in the cup holder area it will work without a problem.
If you get it in front of the steering wheel it might sometimes start having choppy audio
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute
Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album
2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album
      08-26-2018, 02:42 PM   #117
stormlv
Human
Switzerland
932
Drives: Yes
Since no one published the how to pictures on how to do it, I though of doing that myself.
      08-26-2018, 05:39 PM   #118
A15X
Drives: BMW 430d M sport Convertible
Hi all, how can I get apply car play coded to my 2016 4 series with pro nav?
Many thanks!
      08-26-2018, 06:52 PM   #119
R99
I know that, hence why I said the antenna is needed
Good addition with the pics, should help a few people out!
      08-27-2018, 02:11 AM   #120
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Many thanks!
Many thanks!
it can only be activated if you have the time menu, idrive 5 or 6.
if you have the slightly older system then you have 3 choices, new headunit or a carplay hardware box.
      08-27-2018, 02:41 AM   #121
A15X
Hi, I have idrive 5 I believe, got the tile type menus.
How do I go about activating it?
Many thanks!
      08-27-2018, 04:55 AM   #122
springer222
Drives: F31 335d M SPORT LCI
Anyone had any issues with activiating CarPlay in this way and BMW finding out when the car goes back in for work?
      08-28-2018, 10:03 AM   #123
stormlv
Human
Switzerland
932
Drives: Yes
Finding out? No ... they really don't care about this.
Worst thing, a new firmware might be flashed which might remove Apple Carplay (revert to standard). In that case, you just re-input the code that you got when you activated Carplay
      08-30-2018, 02:56 AM   #124
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Exactly this.
Some solutions automatically backup the factory FSC codes and can be reverted in a similar method to applying Carplay.
      08-31-2018, 06:39 AM   #125
itolson
Drives: 4 wheels
QQ
Hi Guys,
If my car came with option S6NWA Phoning with wireless charging
is that correct for this upgrade ?
Thanks
      08-31-2018, 09:36 AM   #126
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by itolson View Post
Hi Guys,
Thanks
Send me the last 7 digits of your VIN and i can check.
      09-02-2018, 12:56 AM   #127
RoundRound
While on the subject, is the 2017 S606A Navigation system Business hopeless for carplay/screen mirroring? What ID version does it run?
Thank you
      09-02-2018, 04:18 PM   #128
Gizmodo
Drives: BMW X1
FSC Contact
Does anybody have any contacts for generating these FSC codes for a 2018 X1
      09-02-2018, 08:41 PM   #129
adpack82
Scotland
Drives: F30 330D M sport
I'd like to know this too. How muck is ot for fsc codes?
      09-03-2018, 07:36 AM   #130
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Not possible at the moment, the headunits in F48 even with widescreen nav is not NBT EVO, it's a business nav system - HU_ENTRYNAV 2 (ENTRY_EVO)
      09-03-2018, 03:59 PM   #131
Simpletechguy
Drives: BMW 428i GC
I have a 2015 BMW with I drive 4. I really want CarPlay with the full screen. I’ve read that if I upgrade the unit with the NBT retrofit, I will lose ConnectedDrive due to imcompatabilty on the telematics side. Is that true? Wibbles seems to be an expert on this. Is my only option for CarPlay and keeping ConnectedDrive to do the MMI unit instead?
      09-03-2018, 04:05 PM   #132
Wibbles
Wibbles's Avatar
445
Drives: M3LR
I have a 2015 BMW with I drive 4. I really want CarPlay with the full screen. I've read that if I upgrade the unit with the NBT retrofit, I will lose ConnectedDrive due to imcompatabilty on the telematics side. Is that true? Wibbles seems to be an expert on this. Is my only option for CarPlay and keeping ConnectedDrive to do the MMI unit instead?
depends which version of idrive you have.
go to the map screen and press the options button on the idrive controller and scroll to the bottom of the list and select navigation system version then post a photo of your idrive screen.
