04-05-2016, 08:56 AM | #1 |
Rep 2,639
ACS Springs vs Dinan Springs xDrive
So I've been doing alot of research the past couple days on which springs to get as I have the adaptive suspension, and came across two that I just could not decide on.
For those who has used them or has them, which springs provides more drop and reduces the most body roll? (The Dinan springs comes with bumpstops) I've heard great things about both, but haven't really seen a comparison on actual drops on the xDrive. Thanks. |
04-05-2016, 09:02 AM | #2 | |
Rep 3,940
You will need all the ground clearance you can get xDrive or not. |
04-05-2016, 09:19 AM | #3 |
Rep 3,940
04-05-2016, 09:25 AM | #4 |
Rep 2,418
Go for the dinan with the software as well to keep your warranty. ACS in Canada is not supported like in UK. No need to go back to stock height in winters, just know when to drive. X-drive sits way too high.
04-05-2016, 09:27 AM | #5 | ||
Rep 2,639
I believe Dinan drops the height 3/4" and ACS 30mm, however, I've seen the front end with ACS actually higher than rear. |
04-05-2016, 09:34 AM | #6 |
Rep 3,940
04-21-2016, 07:54 PM | #7 |
Rep 313
335 X drive with Dinan. It's settling in a bit. The rear is settled but front seems too high still. Hopefully it will settle in.
Estoril MUTHA Fn BLUE...II
11-30-2018, 03:41 PM | #8 |
Rep 245
Old thread revival alert: did the front ever settle down? I've heard mixed reviews about both sets (Dinan vs ACS). We're all after a drop that evens out the front and rear wheel well gaps, but it's hard to find a consensus about which one does it better.
-PCA Instructor #201804533
-B58 F30, 6MT, M Sport, M Perf Exhaust, Dinan Springs, BM3 Stg 1 -My B58 F30 Build Thread https://f30.bimmerpost.com/forums/sh....php?t=1981176 -My F80 Build Thread https://f80.bimmerpost.com/forums/sh....php?t=1757458 -My N55 F30 Build Thread https://f30.bimmerpost.com/forums/sh....php?t=1739248 |
12-02-2018, 09:31 PM | #9 | |
Rep 253
Basically the Dinans (and maybe ACS too?) on Xdrive have reverse take. My RWD on Dinan doesn’t though.. |
01-13-2019, 02:30 PM | #10 | |
Rep 93
Also, what's your opinion on the ride quality? That's something I don't want to sacrifice too much. |
01-13-2019, 09:33 PM | #11 | |
Rep 253
As for ride quality the Dinans are a great compromise between paying $1k+ for coilovers and H&Rs which give a great stance but apparently sacrifice rideability more than the Dinans, and I believe even more on XDrive. At first the ride is identical to stock, but after a month or 2 in on the Dinans on M Sport struts and would say the ride quality is now a little bit rougher than stock but not enough to bother me. I much prefer the lower stance and improved handling, but if you're expecting zero change in smoothness over bumps you'll be disappointed. |
Ragnarok30.50 |
