11-03-2018, 03:04 PM | #23 | |||
Rep 15,858
https://f30.bimmerpost.com/forums/sh....php?t=1532449 Quote:
11-04-2018, 12:51 AM | #24 | |||
Rep 46
I'm running stock tire pressures, 35 front, 39 rear; My gauge pretty much matches the TPMS, so I assumes its somewhat accurate. I honestly don't see how the tire pressures could change the diameter of the wheels though to affect the xdrive. Tires have a steel belt around the circumference which maintains the diameter, and with run flats the sidewall doesn't even collapse when there is 0 psi. That also gives me a thought... hypothetically if a BMW xdrive with runflats has a punctured tire and drives 50 the miles before a replacement tire, have they now destroyed their transfer case? The hesitation COULD also be EGR or some sort of misfire, will probably disable the transfer case and run it in RWD only to see if the stutter goes away or not. I would say the issue currently happens at any speed when you are past 1/2 way on the throttle. Quote:
My warranty is up in a month anyway, so the dealer may "win" this game if they can jerk me around until it truly expires anyway. I have a 3rd party warranty as well though, so I'll try to get the work done that way afterwards if it comes to it. Quote:
11-04-2018, 01:15 AM | #25 |
2JZ-GTE
3032
Rep 3,992
Yes they will so don't give them a reason. Surprised about tires size especially if OEM size elsewhere in world. Then again I would not be surprised if BMW void the warranty for flood damage after driving in a light rain
11-04-2018, 09:33 AM | #26 | ||
Rep 891
15 U.S.C. ch. 50 § 2304 et seq: (c) Waiver of standards The performance of the duties under subsection (a) shall not be required of the warrantor if he can show that the defect, malfunction, or failure of any warranted consumer product to conform with a written warranty, was caused by damage (not resulting from defect or malfunction) while in the possession of the consumer, or unreasonable use (including failure to provide reasonable and necessary maintenance). In other words, they need to show that using those wheels and tires is causing damage to the part you requested repair on. While the next dealer spoke nicely, they're still violating Magnuson. There is zero difference mechanically between an F30 xDrive with that tire/wheel option than one without, the driveline and suspension part numbers are identical. Their argument is only possible with the omission they are selling thousands of units with options that cause unreasonable wear or damage to new vehicles rolling off the lot. As for their argument that it wasn't on the build sheet so it automatically voids, that also fails Magnuson. That was tested successfully by a consumer action against their subsidiary brand MINI for voiding warranties for use of parts not provided by a dealer, assuming the PO of your vehicle bought third party. I would encourage you to show them that, in writing. Sorry you're going through this. You've not done anything, nor has the previous owner to deny this or any warranty claim unless you were showing them some badass brake stands in the parking lot.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
11-04-2018, 02:40 PM | #27 | |
Rep 46
From the other threads of transfer case failures, it looks like they blow up even if you have the car 100% stock, staggered or not. Just a sad experience to have as my first BMW. I just find it hard to believe if someone just bought a $100k M5 and had an issue they wouldn’t be treated this way, would they? Going back to an Audi is looking nice about now. |
11-04-2018, 03:50 PM | #28 | ||
Rep 891
11-04-2018, 05:37 PM | #29 |
Rep 126
MacklinUSOB518.00 |
11-06-2018, 09:45 PM | #30 |
Rep 10,256
jseeey, I must admit it's difficult to understand BMW dealer and BMW NA position regarding the size of your tires.
My 2013 335i xDrive sedan was equipped with optional 225/40R19 (front) and 255/35R19 (rear) tires. Unless xDrive on 328 series vehicle is so substantially different - and it's not - it's difficult to imagine why wheels and tires from 335 series xDrive vehicle would not work. Did you have a chance to speak to BMW NA again? |
11-06-2018, 11:02 PM | #31 | |
Rep 46
I do still have other issues with bump steer and and pulling under heavy braking which they are also blaming on the tires AFTER they charged me for an alignment that didn't make any difference. A fresh set of rubber goes on the front this Friday (the rears are already brand new) after that it will go back to the dealer for those issues. The other dealer who test drove my car also said I have a lot of door seal noise that I should get addressed before before the warranty is up (I never noticed, usually playing the radio) Apparently there is an internal bulletin about it (but not a recall) Also looking forward to the new EGR recall that just came up for the 328d's... no fix available at this time though for NA-> https://www.bmwblog.com/2018/10/23/b...lion-vehicles/ |
11-08-2018, 05:24 PM | #32 |
Rep 46
To update I got the 3rd party dealer I bought the car from (CarMax) to take ownership of the problem. They are going to give me a loaner, take the car back and duke it out with BMW themselves.
Beek707.00 MacklinUSOB518.00 |
12-10-2018, 12:09 PM | #33 |
Rep 46
After a full month I finally got my car back from service. It took my 3rd party dealer (Carmax) a week to work it out with BMW on what to do about the car and they finally decided for the car to be serviced it would need to be reverted back to "stock", meaning replacing the wheels. I took them another week to take away my staggered 19" 403M wheels that the car was sold to me with and put on 18" 400M wheels (I guess those things take a while to order). The car then went to BMW where they were NOT able to replicate any of my previous bump steer issues or xdrive stuttering problems. I SUPPOSE the car having 4 brand new tires of exact equal circumference resolved the xdrive stuttering and magically cured the bump steer? Still worries me that I will have an xdrive failure at any moment now, especially since the dealer I went to said there was "damage" to the xdrive due to the staggered wheels, though I doubt they actually did any real inspection into the issue. (car has never thrown or code or anything related to the problems)
I also had another issue with the car pulling to one side while heavily braking; BMW reported damage to rear components along with the rear trailing arm bolt being backed out and almost and almost falling out of the knuckle. Not sure how this would have been missed with all the service appointments I've had previously, including 3 alignments to attempt to fix my issues. They ended up replacing the left rear knuckle, wheel bearing & drive flange. Well, the car drives great now, however they gave me 4 cheap all season "go flat" tires instead of the summer run flats I turned it in with. I'm not a hater of run flats like everyone else seems to be and since the car comes with no jack or spare and my wife and newborn will be ridding around in this car I rather they be on run flats and not have to deal with a flat tire. But that issue has nothing to do with BMW service, just another issue I now have to sort out with Carmax. It seems like I've been dealing with issues with this car for months rather than enjoying it, but I can see the light at the end of the tunnel. In other news my factory warranty is now expired; Went out on Dec. 8th. |
12-10-2018, 12:58 PM | #34 | |
Rep 1,937
Drives: '13 128i, '23 iX M60
2023 BMW iX M60 BSM
2013 BMW 128i 6MT MGM/CR. M-sport/Premium/Cold, HK, Xenons, BMW SSK and PE. ED 7-12-2013 SOLD: '07 E90 6MT BSM/Terra, '18 F31 Sunset/Oyster, '21 Polestar 2 http://www.1addicts.com/forums/showthread.php?t=897862 |
12-10-2018, 03:57 PM | #35 |
Rep 46
update, dealer/carmax is trying to state that the tires they gave me are runflats and that they have confirmed with the manufacture that they are runflat tires
I sent them back a picture of one of my tires deflated... The tires in question-> https://www.tirerack.com/tires/tires...ta+LX+Platinum |
12-10-2018, 04:12 PM | #36 | |
Rep 891
What a bunch of bullshit. It seems like everyone who touches that car wants to plug a smoke machine into your rectum. I feel for you man, it never ends.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 12-10-2018 at 04:21 PM.. |
12-10-2018, 04:40 PM | #37 | |
Rep 46
For the most part all I've wasted on all this is my time (but a hell of a lot of it) and $189 for an alignment from BMW that did absolutely nothing (after they assured me that all suspension components had no damage) I also wonder how many people Carmax is passing these tires off to as runflats that will be in for an unhappy experience when they are left stranded without a spare or jack. Really wish BMW left an area for a spare or a even a donut, thats how VW is doing it these days (there is space for a spare, but just a can of fix-a-flat and a compressor is in there) |
12-10-2018, 05:37 PM | #38 |
Rep 10,473
I must admit I never looked at it until this thread, but are staggered Factory Options withX-Drive. Heck, are 19” even an option.
Went to build your own on the BMW site. Obviously one cannot build a F30 now but the F32 XDrive only shows non-staggered available with the 18” (400M on the MSport and 397 on the others). If that is the case, I can see why BMW would have an issue with 19” or Staggered if there could be issues that we are not aware of. I’ve never had an XDrive and honestly never paid that close of attention to their factory options. That CarMax paid for a set of 400M instead of doing the warranty work themselves as BMW Factory Warranty was expiring tells me that perhaps there are issues with 19/Staggered on XDrive that we are unaware of. Last edited by IK6SPEED; 12-10-2018 at 07:34 PM.. |
12-10-2018, 06:54 PM | #39 |
Rep 10,256
I continue to be surprised by BMW NA response. Staggered 19" wheels and tires are valid OEM options on other F3x models. Strange and even more strange.
12-10-2018, 07:15 PM | #40 | |
Rep 46
Since the warranty is expired now I won't have to deal with that part of it anymore. Now I'll just have to deal with whatever craziness comes along with my Carmax extended warranty. I hope the car is great and I never have to even utilize it, but with my track record so far with the car I'm sure it will happen soon... |
MacklinUSOB518.00 |
