11-20-2018, 10:31 AM | #1 |
Rep 1,467
Thoughts on My Wheel & Tire Setup - Summer/Winter/Track
Car: 435i x drive lowered on KW v1's
What do you guys think of this setup. I am trying to come up with an efficient setup for all of my purposes without breaking the bank too too much.. I hated running my summer tires on track because of the extra abuse it adds; it started to compromise the tire in rainy conditions because of side wall wear. I figured since I need 18s for my winter set, it allows me to get a set of 18s for track now. I guess the real question is, will the VMR wheels be ok for both winter and track? Lastly, I know the summer setup ill work with my coilovers because I am already running this. however, I am not sure about the winter & track sizes. I am mostly concerned with the front. Summer: 19" OEM Concepts 763M rep with Bridgestone Pole Positions Winter: 18" VMR 710 Wheels with Pirelli Sottozero 3's 245/40/18 square Track: Using the same 18" VMR wheels with RE-71s 255/35/18 square
11-20-2018, 10:57 AM | #2 |
Rep 192
Why wouldn't they be? It's just a rim, and a good quality one at that. If you mean because of tire sizing, then definately no problem in the rear but I wouldn't know if a 255 will fit up front... I guess it probably would depending on the rim's ET. If too low it'll hit the wing, if too high it'll rub against the shock.
11-20-2018, 12:21 PM | #3 | |
Rep 1,467
I guess I need to be sure I can fit as little as a 225 for winter, and as large as a 255 for track on the 18x8.5 wheels. I think It will be ok.
11-20-2018, 02:49 PM | #4 | |
Rep 192
OTOH, 255s on 8.5" rims are gonna be pretty ballooney... I'd probably run 245s on the track if I had to go with 8.5" rims. Or you could just go with 9" rims and stretch the heck outta the 225s... |
11-20-2018, 03:16 PM | #5 | |
Rep 1,467
Also, I wonder if rocking the VMRs on track & winter is the way to go or if running the OE Conceptz replicas is better for those scenarios... I am having difficulty coming up with the best setup here without spending $1400 on each set of wheels... If i could just have one set of wheels I would but with 3 sets of tires, its no feasible so i need to keep my wheel cost down. My goal is around $2000 for both sets...
11-21-2018, 03:49 AM | #6 | |
Rep 192
By crappy I mean cheap and old, or from a "less cool" brand, not broken or bent. They won't look as cool in the pictures as you pull 80º drifts exiting corners, but it's the cheapest and most convenient option... |
11-21-2018, 08:07 AM | #7 |
A family of bimmers
2745
Rep 7,741
why not spend the extra hundred bucks on apex instead of VMR. and this coming from someone who has two sets of VMR. if you plan to use it for the track , apex is the ticket.
11-21-2018, 10:33 AM | #8 |
Rep 1,467
After thinking about this whole setup, I am going to just get one set of wheels (staggered 19's) and run Michelin 4S for summer AND track and get a set of 19's tires for winter. It will save me a boat load and allow me to get better wheels. If i feel like. I will think about adding a dedicated set of track wheels in the future.
11-21-2018, 11:47 AM | #9 | |
Rep 891
I would also suggest moving up to an APEX offering over VMR, they aren't much more expensive, especially on group buys, and are far lighter with a more premium finish. I do like VMR but for track duty APEX is the clear winner.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
11-21-2018, 01:05 PM | #10 | |
A family of bimmers
2745
Rep 7,741
MacklinUSOB518.00 |
11-26-2018, 09:09 AM | #11 |
Rep 1,467
Alright i have changed my mind. It makes sense just to get the 2 sets of wheels, track tires or not.
I am getting Apex 18s for winter/track because i am sure ill end up buying the track tires. The last piece of the puzzle is finding replacement staggered summer wheels. I currently have 19x9.5 with 265/35s in the rear and fitment is spot on.I either need to find another wheel that is the same or figure out if i can afford to run an et33 in the rear. Its so close i cant be sure the 2mm is going to be ok lol. I would be ok with going with a less aggressive offset and run a spacer, but it would have to be at least a 10mm spacer to be hubcentric correct?
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 Last edited by Insane435; 11-27-2018 at 08:07 AM.. |
11-27-2018, 01:09 PM | #12 |
Rep 1,467
Here is what I think I am going to get:
VMR V803s 19x8.5 ET45 with 10mm spacer & 19x9.5 ET35 no spacer. This gives me the exact fitment i know works on my current setup. Then, for winter, Apex ARC 8 18x8.5 squared ET38. I may need spacers, but its just for track and winter, so i am not too concerned. Both setups are quality wheels that are light, which is key for me. I think I am going to get both sets in black. To me that color just looks the best on both wheels. I may change my mind and go bronze or anthracite on the arc 8s but i have not decided yet. thoughts?
11-27-2018, 09:40 PM | #13 |
Rep 4,315
VMR offers the V803 wheel in 19x8.5 +35. imo, it'd be better to run this than a +45 with a 10mm spacer.
i would just get the same wheel and tire specs as @wdeerfield https://f30.bimmerpost.com/forums/sh...hlight=VMR+803 ...on sale right now at m o d bargains for less than $1k/set, in gunmetal or hypersilver only, though. you will not need spacers for the arc-8, even with 255, i believe @polo08816 tracks and dailys his with 255 square. if you're really hardcore, you can further reduce understeer by widening the front track only with a 10mm spacer on track days. the outer shoulder of the front tire might rub the fenderwell liner at full lock at +28(with spacer). during the winter a wide track will sling snow, ice and debris further up the sides, so i don't see the point there. estoril blue with bronze arc-8 would look hot |
11-28-2018, 08:34 AM | #14 | |
Rep 1,467
I would like to get a set of arc 8s but based on the offset i need, they will not be concave at all, which is fine. However, the arc 8s lose some character when theyre not concave. I am debating getting them still along with the EC7s. Its really down to Arc 8s in either black/grey/bronze or EC7 in grey. Not sure what to do!
11-28-2018, 10:31 AM | #15 | |
A family of bimmers
2745
Rep 7,741
hopefully the forgestars work out for you. based on photos ive seen of them cracking and failing i hope you do not run into any issues. Have you thought about the sm10s in 18?
alohasurftoad3072.00 |
11-28-2018, 10:59 AM | #16 | ||
Rep 891
I initially wanted the ARC8's because they're a track BMW staple. The SM-10's offer nearly the same weight savings and look great on the car squared up with proper offsets. I went with 18x8.5 et35 in Anthracite all around and like the concavity. I get so many compliments on them, even people leaving notes on my windshield asking to buy them. I'm considering getting another set for winter/track duty.
11-28-2018, 12:17 PM | #17 | |
Rep 1,467
MacklinUSOB518.00 |
12-04-2018, 09:35 AM | #19 |
Rep 5,140
