BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Smaller Hub & Bearing Cap?
      12-08-2018, 01:57 PM   #1
Skipdeez
Drives: 2015 F32
Hey folks,
I've got an interesting issue I thought I'd ask for your help with. I recently ordered Forgestar wheels, but the rear wheels didn't fit due to the fact that the Hub & Bearing cap on my 2015 F32 xdrive protrudes too far so the wheels wouldn't mount properly. I had to use spacers to make them fit. Does anyone know of caps that are shorter or fit completely inside of the hub/axle? Apparently not all rear axles are like this, so Forgestar didn't account for the extra 2-3mm. Any ideas on how I could replace that hub and bearing dust cap so I can use the wheels without spacers? I found these, but they look exactly like what I already have. Any help is appreciated!
https://www.getbmwparts.com/oem-part...VkIFByb2R1Y3Rz
      12-08-2018, 02:53 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
That cap doesn't look right. Mine do fit all the way into the hub.
      12-11-2018, 09:30 AM   #3
Skipdeez
Drives: 2015 F32
Agree, the folks at Forgestar said they've only seen this a handful of times. I guess I can try ordering a new part and see if it fits better.
      12-11-2018, 11:47 AM   #4
Billfitz
Billfitz's Avatar
Mine aren't that color either. Mine originally fell out very easily. I had to spread the springs that are supposed to provide grip wider to get them to fit securely. Between the different color and knowing how easily they fall out I wonder if someone who worked on the car lost the originals and tossed in whatever they had lying about.
      12-11-2018, 03:49 PM   #5
k3vin0615
Drives: 2013 F30 335I M sport
remove the cap?
      12-15-2018, 10:37 AM   #6
Skipdeez
Drives: 2015 F32
Originally Posted by k3vin0615 View Post
remove the cap?
I thought about removing the caps. Thoughts on any problems that could occur by doing that?
      12-15-2018, 10:41 AM   #7
Skipdeez
Drives: 2015 F32
That's an interesting thought. They certainly don't look right. The guys at getbmwparts we're also dumbfounded, they can't even seem to source a proper replacement. I'm debating removing them altogether (which may not be the best idea) or trying to retrofit something from another model.
