      06-30-2012, 05:58 PM   #309
svache
svache's Avatar
Drives: 2012 F30 328i
Originally Posted by Silver F30 View Post
It may be the fact I don't have comfort access but I can't get my windows/roof to close with the FOB. I appreciate your response FROGMAN but is it holding down the lock or unlock button on the FOB that closes everything?
For closing it's the lock button, to open the windows you need the open button
But, like you said, it most likely wont work without comfort access
      06-30-2012, 10:19 PM   #310
Frogman
Originally Posted by svache View Post
Imho, people should just do it for free if they use the information provided here or on one of the other sites. After all, they downloaded their software and everything for free as well. The only cost would have been the cable. It's a different story when someone actually bought everything and has to make a living out of it, but those who use the software from here, they should just do it for free imo
+1
The work is in getting the cable purchased/built and then getting/installing/setting up the software. After it's all setup on the PC, coding is just a few minute process, thanks to the F10 guys and svache.
Taking money for doing some coding implies taking responsibility if something goes wrong; that's not something I think most people would be willing to do.
      06-30-2012, 10:37 PM   #311
Frogman
I would think it might work with the FOB without CA (lock to close, open to open), just that the door handle method probably won't work (as svache said).
Note that depending on the date your car was built, the KOMFORTSCHLIESSUNG_FB needs to be set to atkiv (as shown in the cheat sheet), but the werte value will be set to 00, not 01.
My 328i was built in April and I ran across that. I was going to set it to 01 (as the cheat sheet shows), but decided that the software was probably right and I left it alone (changed to 00). I've seen others reporting the same thing. Did you force the wetre value to 01? If so, try setting aktiv again and werte to 00 and see if that helps. I didn't have to change the KOMFORTSCHLIESSUNG_PA value and that werte value was 0 also.
Also, you changed the ASP_...KOMFORTSCHLIESSUNG status to aktiv/01 too, right?
Good luck!
      07-01-2012, 01:26 AM   #312
svache
svache's Avatar
I think you say something very important indeed. If someone pays someone else for doing this, he/she is implying that there might be a form of warranty in case something goes wrong and, in the worst case scenario, the ECU needs to be replaced.
I'm willing to code for people, to help them out, but I can't take that kind of responsibility. That's why I'm offering it for free, the risks are always there and it is up to the car owner if he/she wants to have that risk
Regarding the KOMFORTSCHLIESSUNG_FB and werte thing.. I just checked and you're right, nicht_aktiv = 01 and aktiv = 00. I should change this in the cheat sheet
      07-01-2012, 03:49 PM   #313
Silver F30
Silver F30's Avatar
Drives: F30 Sportline
Thanks FROGMAN and SVACHE that did work. I also tried to enable windows going up when closing the door but it does not work. There sure is a lot to investigate. Have a great Sunday!
      07-01-2012, 05:30 PM   #314
08bmw128i
Drives: 2018 X5M
Is there a way on the f10 to code the fog lights to stay on when the headlights are on? So if i turn my headlights on and the fog lights are on, that the next time I turn the lights on the fogs are on?
      07-01-2012, 05:40 PM   #315
svache
svache's Avatar
Check your pm
      07-01-2012, 07:35 PM   #316
Yobyot
Yobyot's Avatar
494
Drives: MY19 X3 M40i
Originally Posted by Yobyot View Post
Thanks. I'll take a look.
Right now, there are three seeders.
I downloaded this torrent and wouldn't recommend it. The files were named incorrectly and when renamed wouldn't unzip.
      07-01-2012, 07:36 PM   #317
Yobyot
Yobyot's Avatar
494
I may be crazy, but the folding mirrors from the fob with comfort access is so cool that I'm thinking of coding my F30 when we pick it up on ED in Europe. :-)
      07-02-2012, 09:36 PM   #318
Frogman
I downloaded the torrent and the .zip file tests correctly. You have to combine the .001 through .016 files into one zip file before you can extract it.
That all may be moot as the torrent psdzdata files are an older version (46.1) compared to the rapidshare ones (46.3).
I don't know if that makes a difference or not.
I'm using the ones from rapidshare and they work fine on my F30.
      07-03-2012, 08:27 PM   #319
Yobyot
Yobyot's Avatar
494
Yeah, I was concerned about the files being back-level as well on that torrent. So, I signed up for RapidShare and have downloaded the files, which are extracting as I speak.
I very much want to use the Esys and pszdata files that svache has been so successful with, so it was worth it to me.
Let me ask this question to F30 coders: if I were to zip all the RapidShare files together into a single archive, create a torrent file that I upload here and seed the torrent for a couple of days, would that help others? Are there others out there who would help me seed it?
I'm willing to seed it for a week or so, but after that, I can't afford the bandwidth.
      07-05-2012, 09:49 AM   #320
Erik.klenke
Drives: 2012 328i Sportline
I also download and installed the torrent version. Now realizing the data files in it are an older version. Anyone know if 46.1 should work fine with 2012 F30, or do I need to download the 46.3 version from RapidShare? Still waiting for delivery of my car, so can't test it yet.
Thanks,
Erik
      07-05-2012, 10:39 AM   #321
mmanes1
mmanes1's Avatar
Drives: F30-320D SPORT
hi
hello f30 fans...
i have a new one f30 320 d Sport Edition...
But i have a lot of questions...
1. its possible to read the FailureMemory from Car with the enet cable?
2. its possible to change the vMax
3. when i switch of the Auto Start STop function the car shows a failuremessage in Display with Car with less power, drive carfully...
where is the trick to became no error Message...
4. its possible to coding the bmw aps function ? 6NR
I have navi prof with bluetooth and telephone.... & connected drive etc...
I hope my english is okay
THX a LOT for your time...
marcell from Germany
      07-05-2012, 02:17 PM   #322
mmanes1
mmanes1's Avatar
no Answer ?! Please give me a response... thx a lot
      07-05-2012, 07:30 PM   #323
BMWCali
Expect the Unusual
BMWCali's Avatar
Drives: 2018 X6M
Anyone know if you can get it to display the digital speed? Anyway to get a digital readout of your speed?
      07-05-2012, 09:01 PM   #324
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Hi guys ...
I'm a bit stuck on the software installation. Following the steps in the PDF, step 4 states:
04) Copy "est" folder from "\\E-sys 3.18.4\est" to "C:\ESysData\e-sys est"
I have the "est" folder ... but I do not see a folder named "e-sys est" in C:\ESysData to copy the folder to? Am I suppose to create this folder? or am I supposed to rename the "est" folder to "e-sys est"? See file hierachy screenshot below?
Any help would be appreciated - want to ensure I'm doing this correctly.
      07-05-2012, 09:37 PM   #325
Silver F30
Silver F30's Avatar
It is sort of a typo it should read C:\ESysData\EST make sure in the EST folder that you have an EST File that is named Cde Away.est Sorry I am responding from my desktop and all my files are on my laptop so no screenshots. But the folder you are showing should have the EST folder in it.
      07-05-2012, 09:41 PM   #326
Silver F30
Silver F30's Avatar
Also just to let everyone know I have coded using a Netbook with a 1.6 gHz processor and 1.5G RAM running Windows 7 and also a Netbook with a 1.6gHz processor and 2G RAM running Windows 8 preview.
      07-05-2012, 09:47 PM   #327
Silver F30
Silver F30's Avatar
@ martinf79 when you finally get E-sys up and running go to "options" drop down box to settings and then tab to EST. Once there browse for Code Away.est where you put it. Should be Whatever drive you have it on I'll use x as the example X:\ESysData\EST\Code Away.est I also recommend in the same settings box going to "Program" and uping the RAM in increments of 512MB at least to 1024. E-Sys will need to restart after you bump that up.
      07-05-2012, 09:50 PM   #328
BMWCali
Expect the Unusual
BMWCali's Avatar
Drives: 2018 X6M
svache?
      07-05-2012, 10:02 PM   #329
martinf79
martinf79's Avatar
191
Will do. Thanks.
      07-05-2012, 10:04 PM   #330
martinf79
martinf79's Avatar
191
Sorry - one more question. RE:
06) Copy the contents of the "C:\ESysData\psdzdata\swe" folder into the "C:\ESysData\SWE" folder.
Can I delete the files in "C:\ESysData\psdzdata\swe" once I move them. Files are about 15GB and running on an ultrabook (120GB SSD), so don't want to use up more space if I don't need to. Can you please let me know.
Also - can I actually run all of the folders off of an extneral drive as opposed to my C: drive?
