01-10-2021, 11:52 PM | #1 |
Rep 1,170
weird misfire/not much power HELP.
so you guys im getting this very weird misfire/hicups/studdering/vibration/lowpower/ symptom on my car
in every gear is like I loose power and is like a bad shake/vibration/backfires/studdering/misfires. ive tried all different maps and it goes away when I put it to stock map is getting very annoying before it would do it every now and then and it would only do it on part throttle now it does it no matter what.on stage 1 tune stage 2 tune e30 tune even the m2 map even the mppk map tune I am currently using bm3. mods are fBO. intercooler intake chargepipe dp so once the car feels more power obviously its not liking it at all.. does anyone have any idea what it can be spark plugs I replaced maybe 8k miles ago. or less I think coil packs swell same time I dont get no check engine light nothing thats what pisses me off.. and it does it horrible enough for the car to damm notice something is wrong lol but I guess not . note: do you guys think is the pcv valve/valve cover. what I have noticed is that I do feel like the oil cap has alot of suction when the car is on. also I hear a whistle every now and then and especially when I take off the oil cap and put it back on while the car is running . or do you guys think is a bad boost leak . but if I had a bad boost leak shouldnt I get like a 30ff code or a boost leak code asap. tomorrow ima try to do some logs and maybe some one can see it with a log.
bmw m2
01-11-2021, 12:00 AM | #2 |
Rep 1,170
https://www.e90post.com/forums/showthread.php?t=1431130
I get this noise on my car when ever I take off my oil cap and put it back on while the car is on and also while im driving I might have this sound swell when im at a red light do you guys think this has to do with something with my problem
bmw m2
01-11-2021, 03:38 PM | #3 |
Rep 1,170
https://www.bootmod3.net/log?id=5ffc...90c649c15f962d
https://www.bootmod3.net/log?id=5ffc...90c649c15f962e https://www.bootmod3.net/log?id=5ffc...0b431e28db9b93 https://www.bootmod3.net/log?id=5ffc...0b431e28db9b93 here goes some logs of my car GOING DUMB CRAZY lol
bmw m2
MAKH 588.50 |
01-11-2021, 04:15 PM | #4 |
Rep 7,606
You said no CEL - did you scan for codes? Nothing active or shadow? I suspect there is something there if its behaving as bad as you say.
When did the problem start? After any specific mod or maintenance? Happen all the sudden or gradually get worse? Those logs are way too messy. You need to get a proper 4th gear pull or two (to the extent possible with the issue), not just a whole bunch of driving with some WOT in there. I trimmed one of them down to some WOT you did in 1-2nd gear. The main thing i noticed is that you couldnt get above like 11psi and were way below boost target even though you were WOT for a long time. In 2nd gear you only held around 7psi. A boost leak is definitely possible. Pressure or smoke test. Also, your fuel trims are quite positive - what E% are you running? Stock HPFP? |
01-15-2021, 07:39 PM | #5 | |
Rep 1,170
he said it is cutting back too much timing on those logs I was running 3 gallons of e85 on stock HPFP these here is on stock map https://www.bootmod3.net/log?id=6002...90c656f5acc10f https://www.bootmod3.net/log?id=6002...0b434387f959bf https://www.bootmod3.net/log?id=6002...729b13f1e035bf This last one is just normal driving on comfort mode https://www.bootmod3.net/log?id=6002...90c6565b6677ed here are some logs of me on stock map because the car was acting way too dumb on the other maps . on stock map the car almost feels normal but on one of the pulls I did feel some hiccups /hesitation/missfire at the beginning but then it went away quck . honestly this problem used to always be there but only sometimes and in part throttle only . and just over time it started to get worse and worse. I think that one time I did spark plugs and coil packs the problem went away a tadbit but eventually came back and now is just really bad on all other maps so right now im just on stock map
bmw m2
01-16-2021, 03:32 PM | #6 |
Rep 7,606
In the stock tune logs timing is even across all cylinders during the pull. But if you have problems with one specific cyl on the tuned maps and you tried plugs/coils it could be injector. Its possible it got worse over time and those maps demand too much fuel.
Are you running some ethanol on the stock tune logs? Your fuel trims are a bit more than 1. |
01-18-2021, 12:24 PM | #7 | |
Rep 1,170
bmw m2
01-18-2021, 12:35 PM | #8 | |
Rep 46
finally someone that has the same problem as mine.
i guess that there's engine knock below 0 or something like that. (correction knock) still trying to find out what's the problem if you found out what's causing it please tell me :'( |
01-19-2021, 03:48 PM | #9 | |
Rep 1,170
sure at the moment im still on stock map and like I mention the car feels alot better and nice and strong in stock map I haven't had a chance to take it to a shop I know for sure my valve cover is messed up because im getting that squealing noise and Ive read thats from a bad valve cover ( pcv valve ) or something like that
bmw m2
01-19-2021, 04:09 PM | #10 | |
Rep 7,606
01-20-2021, 12:10 PM | #11 | ||
Rep 46
contacted protuning freaks and they said it could be a bad injector as i mentioned in other section. now driving my car on stage 2 and it runs fine as long as i don't hit the throttle like before |
