BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > HK systems - Enabling Bang and Olufson DSP Options
      04-02-2019, 02:52 PM   #67
natesi
Drives: F30
Originally Posted by Encanto View Post
The 7-band EQ is a function of the MOST OEM amp, not of the NBT HU. Thus no EQ function in any analog OEM amps.
Awesome, thanks!
      05-10-2019, 09:30 PM   #68
howe9191
howe9191's Avatar
Malaysia
Drives: 2013 F13 M6, 2013 F30 328i
2012 M6 F13  [10.00]
2013 bmw f30  [10.00]
I found there are AUDIO_SYSTEM & AUDIO_PROFILE in the HU_NBT.
There are list of options to choose: individual, base, stereo, tophifi and hk, would it seems to work?
And also and amp variant coding.
ANyone can clarify these?
      05-11-2019, 08:56 AM   #69
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
There are lots of options for coding audio in the HU, but they're only useful if the hardware and software support what you're coding. For instance, if you have the base system coding it to H-K isn't going to give you graphic EQ, because the graphic EQ hardware and software reside in the H-K amp that you don't have.
      05-11-2019, 12:46 PM   #70
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
Try coding those and then tell us about it... otherwise just don't.
      05-13-2019, 10:50 AM   #71
paul e
Drives: 340i xDrive 6MT
Wow...guy with all of 17 posts asks a question and you turn on the flames...
What. A. Guy.
      05-13-2019, 11:56 AM   #72
Encanto
Encanto's Avatar
What. A. Guy.
What post count has to to do with asking a member to contribute to this thread as the OP did?
      05-13-2019, 01:20 PM   #73
natesi
Drives: F30
What. A. Guy.
OH SNAP!!!!
N26Ghost496.50
      05-21-2019, 11:36 AM   #74
Framamind
Mr. Discombobulator
Framamind's Avatar
Drives: 335i
Coded this yesterday.
Since I've been using L7, I'll give my thoughts on Expanded B&O:
This DSP is definitely a much wider soundstage, and I can still tell which speakers it's sending to directionally, not really a "pool" of sound, imo (but that's what my ears hear, lol).
I am getting a bit more clarity and separation in the highs vs. L7 , but that could also come down to EQ settings, which I'm going to play around with in both DSPs.
One thing I did notice that changed in the menu besides the removal of the L7 checkbox and the B&O title at the top:
In volume settings, "Speed volume" is no longer available. I know it doesn't have as significant effect with HK systems (versus HiFi), but it is noticeable.
It seems I've had to use a bit more volume with the B&O setup due to the wider soundstage.
'14 MSport 335i | Melbourne Red | MPE | MPBBK | MPS | MPLSD | xHP Stage 3 | MHD Stage 2
N26Ghost496.50
      05-21-2019, 01:04 PM   #75
N26Ghost
N26Ghost's Avatar
Drives: 2014 BMW 328i M Sport
Someone help this dude...
Makes sense, if you want to know what they do, and aren't getting answers from the forums, code that shit and report back. That is what most of us do. Good, bad or indifferent, you'll learn something and if you care about sharing knowledge, you could help others...which is kind of the whole point. Nothing wrong with a little encouragement to explore and report back with findings. Bimmercode takes a backup each time you code, so often, it is as simple as coding, observing and restoring from the backup if things aren't panning out.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
ooshnoo877.50
      12-01-2019, 06:02 AM   #76
dgarcbas
Drives: BMW 428i F36
Hello, its coded with bimmercode?? Its possible to code with esys??
Thanks a lot
      12-01-2019, 08:33 AM   #77
Billfitz
Billfitz's Avatar
Anything that can be coded with Bimmercode can be coded with E-Sys. They're different tools that do the same thing.
      02-05-2020, 02:28 PM   #78
dgarcbas
Can someone explain what values of equalization use in B&O DSP?
Thank you
      02-16-2020, 06:55 PM   #79
VP Electricity
VP Electricity's Avatar
Drives: F34 xDrive
So each MOST amplifier - HK, B&O, etc - gets left and right from the head unit (if you play a DVD, it gets more than that, but let's talk about music and stereo for the moment). It also getscommands for things like Logic 7 on or off, or the B&O surround mode. (NOTE - surround for music is different than discrete surround for DVD).
But it doesn't put B&O processing into your HK amplifier in the trunk. You're sending it some command, I don't know what, but it's only turning on and off something already in the HK amplifier. NOTHING in the audio path of the HU changes when you go from HK to B&O. The amplifier in the trunk has all the processing in it, and the iDrive just does tone controls, EQ, and turns features on and off.
My guess is, you're either sending a command to turn Logic 7 on and off, or you're somehow selecting a tune for another vehicle. The B&O amplifier has active crossover channels for all the tweeters, and has a very different set of DSP functions than the HK amplifier does. You're not enabling them, I'm afraid.
      03-24-2020, 01:17 PM   #80
bringmywallet
Netherlands
Drives: F30 lci
Hello everybody,
I have been reading this thread and also coded the b&o settings in my hksystem.
Great upgrade in sound, thanks for the info!
I coded the kein_insz setting, which still gives you the option of studio/expanded, but gets rid of the non functional light settings.
Next i went to the AMP_TOPHB ecu, 3000 EQSetting and i tried f10 setting which i thought already sounded a bit better.
Then i discovered the rollsroyce eq settings and i couldn't help myself trying those. For now i ended up with the RR4 (rollsroyce ghost) setting which i'm pretty happy with.
The bass sounds tighter, the highs better balanced and defined, i'm not turning down the 200hz in the eq anymore, just turning the 500hz one notch down.
      03-24-2020, 05:36 PM   #81
rsm_CR
Drives: 340i
Originally Posted by bringmywallet View Post
Hello everybody,
Can you please elaborate on what your current car is, year and audio package, and what values you coded? I have a MY16 F30 with HK and was pretty disappointed with general audio until I enabled BO dsp and calibrated it and now it's passable but could be better. I'm interested in trying out what you mentioned
      03-26-2020, 09:50 AM   #82
daschacka
Drives: M5Competition
My car have HK and Logic7.
I've coded this to kein_insz.
Put B&O to Expanded. And what can i say wow like an upgrade.
Deeper Bass and before i had a crackling sound here and there on some songs. Its totally gone.
Thank you for the Tip!!
N26Ghost496.50
jbeer154.50
      03-30-2020, 02:04 AM   #83
scrizz
Drives: 2016 BMW 340i M-Sport
I may have to try this
      03-30-2020, 08:23 AM   #84
tympj
Yellow Jacket
Drives: 2014 328i Orion Silver
If there is any chance someone could upload a sample of any song to demonstrate
the B & O sound upgrade I would really appreciate it?
      03-30-2020, 09:13 AM   #85
daschacka
I dont have any before/after song record to preview that and i think the smartphone microphone might not be able to show that. But its just a 1 minute coding and you can also go back like that (kein_menue = default HK // keine_insz = B&O).
So i would recommend you to just code it and convice yourself I can definately hear a difference
      03-30-2020, 09:18 AM   #86
damack
damack's Avatar
Drives: 2017 F31 330xi
I had the B&O profile enabled a while back. It's different and at the beginning I think that I figured it was better. After listening for a while, I'm not convinced. I'm probably going back to the HK.
I think it's pretty common to confuse different with better. In the end, music is such a personal preference. If it sounds good to you, that's all that really matters.
aps335.50
      03-30-2020, 08:46 PM   #87
Goody4
Drives: 2022 X3 M40i
My sentiment, too.
      04-08-2020, 05:49 AM   #88
J555
Drives: F31 LCI 340iX
Would you mind to share more details about what car it is? And what exactly did you code?
I am curious, because I can't see even this ECU in bimmercode
