08-26-2020, 03:56 AM | #67 |
Rep 353
09-09-2020, 05:39 PM | #68 |
Rep 814
Drives: 2021 BMW X3 M
Any updates on this?
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
10-12-2020, 02:39 PM | #69 |
Rep 1,467
Not sure if this has been figured out yet but i have something to add.
I have both an ewg n55 in my 2014 435 and then i have an 2018 x4m40i. The x4 behaves exactly like the m2 with n55. When you rev it at idle, it bangs off the limiter much differently than my 435 which has bm3 and xhp stage 3. Ive also noticed in the m40i when you left off the throttle you get thrown forward where in the 435 nothing happens. After owning the m40i, the 435 seems pedestrian at times. Can you get the 435 to behave like the m2 when revving, upshifting and letting off the throttle? |
10-13-2020, 02:14 AM | #70 | |
Rep 86
Yeah, you can get it to work just like it is in N55 M2. |
10-13-2020, 06:02 AM | #71 |
Rep 1,467
10-13-2020, 11:14 AM | #72 |
Rep 7,591
01-20-2021, 03:23 PM | #73 | ||||||
Rep 86
01-20-2021, 04:15 PM | #74 |
Rep 7,591
I follow the logic in the quotes you posted, but i don't see how that's going to improve turbo lifespan... they are talking about reducing turbo lag, and keeping the turbo spooled, and presumably increasing/maintaining high EGTs. None of that seems "better" for the turbo lifespan.
01-21-2021, 01:18 AM | #75 | |
Rep 86
In this case you are right. In regular ALS looks like this = dump a bunch of fuel into the engine to keep the turbos spinning. Due to the constant explosions in front of the turbo wheel, the lifespan is rapidly declining. That’s a fact, no one denies it. You can’t add any lifespan to your turbo with that. But here we have a different type of ALS, similar to Porsche’s solution. It doesn't dump extra fuel into the engine to keep the turbos spooling. Lifting off the throttle pedal shuts off the fuel injectors, but leaves the throttle partially open. This allows more air to pass through the engine, keeping exhaust flowing and spinning the turbos even during deceleration. If you compare it now to people willing to have ALS, this solution adds lifespan compared to regular ALS. The only downside I see is engine braking effect is reduced by this ALS. But you should only feel it when you aggressive drive your car. Everything we have here are are just guesses. We don’t know yet how exactly work this system. Please don’t get me wrong, we are all here to find the solution how to get it to work on regular 35i cars. |
harkes1075.50 |
01-26-2021, 07:26 PM | #77 | |
Rep 2,354
(A Dane in China) |
F20_M135i100.50 |
01-29-2021, 10:39 AM | #81 |
Rep 7,591
02-01-2021, 05:14 AM | #82 |
Rep 86
02-04-2021, 06:45 PM | #83 |
Rep 1,380
MHD just released an anti-lag option for S55/N55 engines and the demo video replicates this sound..
I'm going to try flash it in the morning
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
02-04-2021, 07:24 PM | #84 |
Rep 764
Upon shifting, throttle is closed briefly. I think that is considered "lift-off", no?
I still stand by my statement. My car makes this almost exact noise when on the gas hard, and it shifts. I'll take a video in the next few days if I can figure out a way to mount the gopro back there |
02-04-2021, 07:30 PM | #85 | |
Rep 2,653
n55david1295.50 |
02-05-2021, 12:07 AM | #86 | |
Rep 7,591
This thread is about something different and if you go back to some of the OPs there was this same exact discussion. This thread is about the sound when you let off the throttle without shifting. Its like a overrun sound. Has nothing to do with changing gears. |
02-05-2021, 02:09 AM | #87 |
Rep 551
it's my fault, I misinterpreted what I heard here.
good luck getting your "braap" sound back Last edited by F20_M135i; 02-06-2021 at 09:22 AM.. |
