01-12-2021, 08:46 AM | #1 |
Rep 7
BMW 335xi ** NO HEAT IN THE CABIN **
I have a 2014 BMW 335xi that is producing NO HEAT in the cabin at all. I've searched the forums for solutions to this issue and the only answer I found was to replace the thermostat. So I did. Unfortunately I still have no heat inside of the car. Even after bleeding the system multiple times.
Another issue I am having that might be related to my heat issue is the amount of air being pushed through the vents. When I have the fans turned all the way up I can hear the blower motor pushing air through but it feels like there is not a lot of air coming through the actual vents. I have checked the blower motor and there is no debris in the housing. The motor seems to be working just fine. The only ideas I have at this moment are that the heater blend actuator is not working properly and that is causing low air pressure and as a result, no heat to the inside. Another possibility is that my heater core is clogged but strangely enough, if I leave my fans turned off and the car is up to temperature, I can turn the fans on low and for a few seconds I can feel heat through the vents. Has anyone else had this issue before on their F30??? I am looking for any ideas/help I can get at this point being that its getting nice and cold up here in Ohio and I now have to wear a winter hat, gloves, and jacket just so I don't freeze on the way to work. |
01-12-2021, 10:46 AM | #2 |
Rep 7,620
Its probably the blend door actuators in the dash as you mentioned, especially if you have decreased airflow. This really isnt the best section for this question, i have seen several similar threads in the TSB section, so i would check there:
https://f30.bimmerpost.com/forums/fo...play.php?f=437 |
01-20-2021, 10:43 AM | #4 |
Rep 12
Drives: BMW 435i xdrive coupe
The heater cores get clogged with sand. You can try flushing it but it never works
01-20-2021, 02:43 PM | #5 |
Rep 461
climate, climate control, no heat |
