01-17-2021, 09:00 AM | #1 |
Rep 2,047
Does 98 octane make a difference?
ie in a tuned 440i when it comes to performance and engine health? Taking it on a dyno next week as I want to see how it performs before and after BM3 stage 2. Not sure if 98 would make a difference
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
01-17-2021, 09:23 AM | #2 |
Rep 271
Based on my experience, yes it does. The car was an Merc amg45, stage 1 tuned. I know it wasn't a BMW, but I believe putting premium fuel in any performance/tuned car is beneficial. On normal 95 octane fuel, the 45 ran a little noisier and 'slightly lumpy'. On premium fuel, it was quieter, smoother and throttle response was slightly better. Also, the exhaust tone seemed slightly better - a bit throatier/raspier. Also, on the Dyno, premium fuel gave about 8 bhp more than the norm fuel - not much on 410bhp anyway, but it all counts. Also, with premium fuel, you have the benefit of the internals being kept cleaner, as the fuel burns more efficiently. I also got a couple of mpg better as well. Btw, in this car, I tried shell and BP premium fuels, but found the best to be Tesco momentum, which is 99 Ron I believe.
Hope this is helpful Last edited by seenthelight!; 01-17-2021 at 09:28 AM.. |
Fez_766.50 |
01-17-2021, 09:55 AM | #4 |
Rep 2,047
My tank is about 1/3 filled with 95 - can I mix?
01-17-2021, 10:01 AM | #5 |
Rep 271
01-17-2021, 10:50 AM | #7 | |
Rep 413
There is a 95RON tune, 98RON and 102RON/E30. Stage 2 95RON will target less boost and ignition advance than the 98RON tune. If you run 95RON fuel on a 98RON tune the engine will pull ignition timing and knock. Not good for the engine at all and less power. The B58 log thread gives lots of info - https://f30.bimmerpost.com/forums/sh....php?t=1648722
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
01-17-2021, 11:41 AM | #9 |
Schmollbraten
12512
Rep 1,985
Its maybe measureable and just for your brains comfort. Wouldnt use it just for 1HP more.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
LobB5109.00 |
01-19-2021, 05:27 AM | #10 |
Rep 3,869
Short answer: Yes, even if you may not feel the difference, it does make one. Usually 98 fuels are also better quality and better for the engine in the long-run.
And besides that - why would you use anything lower than 98 on a performance vehicle!? I use min 98 on my (non-high-performance) Audi as well.... The extra price is at least partially compensated by a lower fuel consumption.
01-19-2021, 06:22 AM | #11 |
Rep 7,703
Used 95 in my 440i for most of it’s 45,000 miles. Tried a couple of months on 98, couldn’t tell a blind bit of difference, so stopped.
The engines are designed to run on worse quality fuel than ours in other countries. So will be fine. Proper tests show mixed results on benefits, maybe there is, maybe there isn’t. Pretty certain that 95 won’t do any harm at all, and you may be able to notice a small difference in higher grades, but it won’t be night and day. |
LobB5109.00 |
01-19-2021, 06:45 AM | #12 |
Rep 3,869
98 is a recommendation by BMW for B58 (for a reason). And a REQUIREMENT for MPPSK. Not to mention other tunes.
It's all about the ignition timing.
01-19-2021, 07:30 AM | #13 |
Rep 1,236
American here, so I'm running the octane versions. I find the difference between the bm3 stage 2 tunes with 91oct and 93oct negligible. I can run a 4.43 sec 0-60 on either. Though on stage 2 93oct I ran a best of 4.4 flat.
When I ran the 93oct tune on 93oct gas (98ron), I had minor timing corrections I could only fix with a gallon of e85. Now I run stage 2 91oct tune on 93oct gas, have impeccable timing and no need for an "octane boost". Bm3 seems very dependent on the gas you're putting in, and seems to perform better (in my experience) using gas that's one step higher octane.
2023 M2. ZB. Manual.
2024 m235i |
M140_BCS237.50 |
01-19-2021, 07:41 AM | #14 | |
Rep 1,659
As in, damage may occur? Or to get the quoted performance increase, 98 should be used?? I would have thought that if 98 was mandatory, BMW would put a sticker on the fuel flap to that effect when MPPSK has been fitted - along with the other stickers in the pack. I understand that higher octane is advantageous for higher performance in a high compression engine, and that the management will retard the ignition timing if it detects knock, with the resultant decrease in performance. Mine has only rarely had in 98, even pre-MPPSK. I run it on Tesco 99 unless I'm in dire need. Its never had normal unleaded in it. |
01-19-2021, 07:51 AM | #15 | |
Rep 413
93 fuel on 93 map = timing pull mostly in mid range but minimal up top.
Silverlining_m21731.50 |
01-19-2021, 10:00 AM | #16 | ||
Rep 1,236
2024 m235i |
01-19-2021, 10:23 AM | #17 | |
Rep 3,869
From the official BMW MPPSK Workshop Manual: "In combination with the M Performance Power and Sound Kit, the use of RON 98 fuel (AKI 93) is recommended."
01-19-2021, 11:05 AM | #18 | |
Rep 15,858
Putting RON 95 in the MPPSK, is like milk drinkers having semi-skimmed, when you can have full fat milk. Even my humble 'standard tune' N55 wakes up on RON 98/99. |
Skyhigh1882.00 |
01-19-2021, 04:01 PM | #20 |
Rep 1,801
I used to get lots of timing corrections running lower than I should but since I've started pushing it harder I can't even run it on 99 (Momentum) anymore without timing corrections so normally add a few litres of ethanol to pep it up a bit.
When you have MPPSK they give you a certificate of installation and it says to run 99 fuel. The BM3 site goes into enough detail about running lower fuel than you're mapped for and you're just asking for problems running lower grade fuel on a higher map. Just swap it to the 91 map instead of 93 and you'll be fine. Adding the fuel now doesn't mean you car needs to adapt over a few tanks the timing corrections happen instantly. The moment your higher octane fuel mixes and gets fed to the engine you will see the benefits.
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
LobB5109.00 |
01-19-2021, 05:07 PM | #21 | |
Rep 15,858
For me, one subtle, but obvious change is the gearbox behaviour. Extra mid range torque means the gearbox down changes more readily, when using similar throttle inputs, compared to running RON 95 fuel. |
LobB5109.00 |
01-19-2021, 05:42 PM | #22 | |
Rep 3,869
Performance engines (especially tuned!) benefit from the highest octane fuel one can find on a gas station. With the additional benefit of the additives in higher quality fuels. If I only had regular access to 102 Octane... Unfortunately 98 is the highest I can get around.
LobB5109.00 |
