BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 2 6wa's both with DOWT EPROMs HELP!!
Studio RSR
      03-16-2018, 03:58 PM   #1
Jhnblckwood
Drives: F30 2014 320i xdrive
I have read countless posts about this retrofit and still need answers please. Both EPROMs are DOWT but I was able to clear miles to zero but when trying to blank vin I'm having issues. I heard ppl having issues resetting miles but not vin. One eeprom has one long vin and two short, the other has 3 short. The one with 3 short every time I blank vin it writes ok but when I read it back one vin comes back I don't get it. The other with the long vin it doesn't let me change one value. I am using r270 with test clip, I rather not desolder EPROMs as I'm able to blank mileage but is that my only option? Or do I need to order virgin EPROMs with same serial? Has anyone else have this problem where it's says:
Verify error address: 0x007 (R: 0xFF)!=(V: 0x38)
I know what it means but why wount it let me change 38 to FF?
Any help would b appreciated. Gonna try and install the one with 3 short vins and hoping after I flash or code a miracle happens. Would really appreciate any help.
      03-19-2018, 02:09 PM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
All good questions - when I did both my gage retrofits I used clusters with virgin eeprom and no problems whatsoever
One cluster was new, the other I had someone solder in new eeprom and code for my vin/mileage
      03-19-2018, 11:22 PM   #3
Jhnblckwood
Thank u. I think that’s what I’m gonna have to do. It’s weird, when I read the eeprom the r270 software wants to save it as the last 5 of the donor vin so it must b write protected thus why it vin keeps reappearing as the donors. When ordering new eeprom I have to make sure it’s the same serial?
      06-13-2019, 07:51 AM   #4
BMWFanaticRob
Drives: F33 435i
I am having the exact same issue as you are had. What did you do to solve the problem?
Thanks.
      07-03-2019, 11:47 PM   #5
Jhnblckwood
Thanks.
I put the cluster back in my car, had the red dot then removed it tried again with the r270 n when I put the cluster back In and VO coded it n it worked fine. Mostly trial n error
