BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > *** bootmod3 *** XDI Fuel Pump (HPFP) Support - Now Available!
      11-29-2018, 07:38 AM   #23
Martin.328
Drives: 14 6mt 335
Originally Posted by Stanio View Post
The big pump can handle full e85 with no issues.
I'm happy that now people will see how much more they can get out of their cars. Hopefully, they don't break other parts in the process.
The big pump is too expensive. I rather have an upgraded hpfp than pi for sure but not at more than double the cost.
      11-29-2018, 07:45 AM   #24
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Nice! Now all we need is a full E85 OTS tune...lol.
From a cost standpoint, this is only about $300 more than the Fuel-It port injection kit and seems to be a much cleaner approach. I like it.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      11-29-2018, 08:08 AM   #25
JaredG_F30
JaredG_F30's Avatar
1106
How are you getting a PI kit out the door for $1,000? The base spacer kit from Fuel-it is $1,150 but once you add fuel lines, 750cc injectors and a controller it's right at $2k. If you run the Phoenix Racing manifold it's even more.
ronanz1819.50
      11-29-2018, 08:27 AM   #26
Martin.328
Drives: 14 6mt 335
The bmp kit with jb4 pi controller is right at $1k, besides i was talking about the big pump not the 35. If you cant run straight e85 with the 35 and an upgraded turbo then its not worth it IMO. Once you go pi you dont have to worry about fueling again with the xdi35 u still do. If full e85 is doable with this pump and a ps2 then im all for it.
      11-29-2018, 12:24 PM   #27
Stanio
Bulgaria
67
Drives: F30 335 2014 Xdrive
You know that with the small pump you can get at 500whp on 93 alone right (with a PS2)? You can run 50/50 mix with the small one. At that point you'll be limited by your tranny and transfer case if you're xdrive or some other drivetrain issues.
From a convenience point of view... it's a no brainer. You don't have to look for gas stations with e85 and you can still run 50/50 if you wish.
ceedawg467.50
      11-29-2018, 03:34 PM   #28
BeeEyez
Drives: 435i Dinan Stage 3
so in theory, its either the PI kit or this upgraded HPFP (plus most likely LPFP and fuel lines) and you can be good to run higher than the e30 tune or full e85? im with you on the "cleaner approach".
      11-29-2018, 04:06 PM   #29
Raymondo1234
Raymondo1234's Avatar
Drives: 2016 M235xi
I have been running this 35 pump with my pure stage 2 235 xdrive for several months now. I'm local to TTFS, who have been great. I see peak boost about 20psi on 93, about 450 whp.
dr.roro195.50
      11-29-2018, 06:54 PM   #30
Marlinman
Drives: 2013 335i xDrive
are you one of the individuals running the stock LPFP?
      11-29-2018, 06:57 PM   #31
Raymondo1234
Drives: 2016 M235xi
I was until a few weeks ago, reason I swapped is I have e85 very near me, and I am thinking of going to e50. TTFS said they will provide a tune if I go ahead with this.
The LPFP was absolutely fine and wasn't needed to be changed. I'm just doing it as a preventative measure.
ceedawg467.50
      11-29-2018, 07:01 PM   #32
Marlinman
thank you for the input!
the smaller pump they offer goes for about 2.2K I believe, I don't see the bigger one listed.
      11-29-2018, 07:02 PM   #33
Raymondo1234
Drives: 2016 M235xi
If you got in touch with frank at TTFS I'm sure he would be able to help you. I went with the 35. I did it all in one go along with the pure stage 2.
      11-29-2018, 07:16 PM   #34
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
Gotta pay to play guys. Besides my boy sandro i will be getting tuned with this pump as well with PS2 by Labworx so will update with results very soon.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      11-29-2018, 10:57 PM   #35
IK6SPEED
Drives: BMW M3 / AH3
Which pump?
The XDI 35, XDI 60 or the S55?
I want to see numbers that justify the cost of the pump. I would like to see it handle full e85
TTFS stated in another post the XDI-35 could NOT run straight E85.
I have seen no info on if XDI-60 can or cannot...and its not even on their website, so very little is known.
Besides, the JB4 is a POS for running PI.
      12-05-2018, 07:39 AM   #36
MTWO
Drives: M2
Great work PTF! PI is such a bandaid for fueling I never liked it. Getting fuel from DI only is best when it can be done. I’m looking into getting the XDI-60
FSociety3812.50
      12-10-2018, 10:40 AM   #37
F30_SixSpeed
F30_SixSpeed's Avatar
1171
Drives: 335i M Sport
The TTFS XDI pump is holding 20-21 psi the whole RPM range on PS2 turbo. This is only on 93 octane
Still dialing in the setup, we just started upping boost and damn the car is a missile! This is a nice setup for even pump gas setup. Once we start throwing more octane at it (ethanol mix or race gas) we can bump the timing up more aggressively, but trust me the car is quite fun as is
Here is my setup from this morning - 20+ psi at 6.5k rpm on 93 octane pump gas - fuel pressure is perfect.
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
      12-10-2018, 11:11 AM   #38
insane11
Drives: 435i GC
I want one
      12-14-2018, 11:48 AM   #39
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
PTF stage 2H OTS maps for various fuel blends and octane levels would make the XDi pumps even more tempting.
Something like 2H 93 @ 19 psi, 2H E30 @ 21 psi, 2H E50 @ 23 psi or whatever is reasonable.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
harkes1075.50
FSociety3812.50
      01-06-2019, 02:43 AM   #40
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Yep
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      08-24-2019, 09:06 AM   #41
luchocamp
Drives: 18 BMW M2LPower
Do you have WMI ?
I have friends still using PS2 with WMI and 27psi of boost with B58evo up to 7th gear 6,400rpm. No PI
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires
instagram @luchocampusano YouTube Lucho Campusano
      08-26-2019, 05:26 AM   #42
F30_SixSpeed
1171
Originally Posted by luchocamp View Post
Do you have WMI ?
No WMI.
bm3, bootmod3
