06-11-2019, 01:32 PM | #1 |
Rep 124
Intermittent Electrical Issues
Hey all, I know this is kinda generic but any help would be greatly appreciated.
My car is acting up, and it seems to be getting worse. I replaced my car battery a couple months ago but I also only drive it maybe 3-4 days a week. Then the rest of the time it's off in the garage. Issues: - Backup camera option is grayed out sometimes and won't turn on. - Heated seats when pressing the button it won't turn on. Sometimes it does but it will turn on to level 3 then get stuck and then eventually turn off. - Sound won't adjust when using the volume knob. Again will turn up/down intermittently and same for trying to mute. Have to keep pressing the button until it sometimes works/sometimes doesn't. Retrofits: Backup Camera Auto High Beams Rear PDC CIC->NBT Touch Controller I have a 2013 BMW F30 335i xDrive Thanks in advance! And I can post a video if that helps. Last edited by ryantpayton; 06-11-2019 at 01:41 PM.. |
06-12-2019, 11:43 AM | #3 | |
Rep 124
Do you know what I need to check to see if it's coded to the car? I have access to the coding software. |
06-12-2019, 11:54 AM | #4 |
Rep 16,079
It's not coded, it's registered. Not the same thing. Your iDrive might have a record of it. An OBD diagnostic tool might be able to tell as well, especially if it's one that has the ability to register batteries. If it was me I'd be using my OBD diagnostic to find fault codes.
06-14-2019, 06:40 PM | #5 | |
Rep 124
07-31-2019, 09:00 PM | #7 | |
Rep 124
Should I just check all my wires connections? So far they look fine... |
07-31-2019, 09:31 PM | #8 |
Rep 16,079
I can't read your screen shot, but TRSVC is for surround cameras. Different model years have different configurations. My rear camera is controlled via the REM, along with the PDC.
07-31-2019, 09:33 PM | #10 | |
Rep 124
ACSM [1] [F801129] readCPS o.k. CAFD_00000909_004_003_007.ncd generated ACSM [1] [F801129] readCPS o.k. CAFD_0000090A_004_003_058.ncd generated ACSM [1] [F801129] readCPS o.k. CAFD_0000090B_004_004_012.ncd generated DME2 [12] [F801129] readCPS o.k. CAFD_00000B0A_000_042_003.ncd generated DSC [29] [F801129] readCPS o.k. CAFD_000009EF_000_024_002.ncd generated EKPM2 [17] [F801129] readCPS o.k. CAFD_00000098_000_008_112.ncd generated EPS [30] [F801129] readCPS o.k. CAFD_00000694_003_003_047.ncd generated FEM_BODY [40] [F801129] readCPS o.k. CAFD_00000794_014_040_152.ncd generated FLA3 [5f] [F801129] readCPS o.k. CAFD_000000AE_005_007_006.ncd generated FZD [56] [F801129] readCPS o.k. CAFD_00000A07_002_018_000.ncd generated FZD [56] [F801129] readCPS o.k. CAFD_00000A08_003_012_000.ncd generated HU_NBT [63] [F801129] readCPS o.k. CAFD_00000DED_003_013_040.ncd generated ICM [1c] [F801129] readCPS o.k. CAFD_0000067B_002_003_147.ncd generated CAFD_00000A3F_005_001_019 Fehler: CPS read from ECU "ECUId:IHKA_0x78" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: IHKA_78_ETHERNET severity: ERROR [2130765072] KOMBI [60] [F801129] readCPS o.k. CAFD_000009C8_006_003_023.ncd generated LMV_FR [19] [F801129] readCPS o.k. CAFD_00001543_000_054_006.ncd generated REM [72] [F801129] readCPS o.k. CAFD_000007A1_005_038_006.ncd generated CAFD_000000B5_010_004_004 Fehler: CPS read from ECU "ECUId:SM_0x6D" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: SM_6D_ETHERNET severity: ERROR [2130765072] TBX [35] [F801129] readCPS o.k. CAFD_000011C5_001_010_009.ncd generated CAFD_00000223_013_008_010 Fehler: CPS read from ECU "ECUId:TRSVC_0x06" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: TRSVC_06_ETHERNET severity: ERROR [2130765072] ZBE3 [67] [F801129] readCPS o.k. CAFD_000011B3_001_002_011.ncd generated |
07-31-2019, 09:52 PM | #11 | |
Rep 124
If I try to write the SVT. It says, "The following ECUs have a wrong bus ID: TRSVC, TBX, ZBE3, HU_NBT" I don't understand why everything is different |
07-31-2019, 11:11 PM | #12 |
Rep 40,765
I replied to your PM.
08-01-2019, 08:29 AM | #14 |
Rep 124
