BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 1 USB port but blue connector (for second usb) busy
      11-18-2020, 12:56 PM   #1
cesabas
Drives: 420d
Hi!
I've a Entry nav and I would like to install the second usb port. I have the usb connector in the armrest, while it is absent in the glovebox. But the usb ports behind the radio are both busy!
Thank you!
      11-18-2020, 01:55 PM   #2
atzebmw
Drives: Tesla Model 3
The second connector is connected with the SnapIn adapter.
      11-18-2020, 01:57 PM   #3
cesabas
Drives: 420d
quite right! To reuse it, I would have to dismantle the whole tunnel
      11-19-2020, 03:48 PM   #4
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
Isn’t there a guide/post here where the snap in adapter is removed and replaced with a USB port? You could just unplug the snap in and run your own new wiring to the glove box, would that work?
      11-20-2020, 02:50 AM   #5
atzebmw
Yes, that works.
I moved the second USB to the panel under the climate control (like the LCI models with wireless charging).
