Login
View Poll Results: How many Issues have you had with your F30 | |||
More than 3 issues. |
120 | 15.42% |
1 to 2 issues excl. Steering wheel Vibration |
162 | 20.82% |
Steering Wheel Vibration |
46 | 5.91% |
Very minor issues. Not worth putting up there. |
146 | 18.77% |
NO ISSUES WITH MY F30 (touchwood) |
304 | 39.07% |
Voters: 778. You may not vote on this poll |
03-23-2015, 08:39 PM | #309 |
![]() ![]() ![]() ![]() 124
Rep 504
I clicked too minor to care about.
1. Horn low frequency module not working. Will get them to replace at 15,000 km service 2. Floor mat issue. My sales guy came, picked up my spare key (warranty info on key??!) and took my mat back to the dealer to swap it out without having to book in for a service. I was pretty happy with that! ![]() |
03-27-2015, 04:30 PM | #310 |
Rep 8
Drives: 2013 BMW 335i X-Drive MSport
No issues so far, so impressed.
I have a Melbourne Red 2013 335i X-Drive 8AT Sedan with M-Sport package and Stage 1 DINAN Performance Tuner. Added M-performance interior (carbon fibre & alcantara trim kit) and exterior (carbon fibre rear spoiler, rocker panel strips, diffuser kit). Has about 49,000 kms on it. Love the car... A nice upgrade from my e46 320i 6MT!
2013 BMW 335i X-Drive, M-Sport, M-Performance upgrades, DINAN Stage 1 chip, Melbourne Red
10-27-2015, 05:38 AM | #312 |
![]() ![]() 201
Rep 1,252
excluding issues from jb4, once i needed an software update to fix throttle vs pedal issue.
i would put pedal 100% and throttle doesn't go to 100% immediately takes about 3-5seconds and post shift same thing happens. other than that if i was stock i assume i would have no issue.
Docrace 6266
01-28-2020, 05:16 AM | #314 |
![]() ![]() 12
Rep 54
2 minor problems with one semi-major.
Heat shield rattle on driver's side is driving me absolutely bonkers. Spacer issue in the rear passenger side. Seems that the rear passenger tire has more negative camber so the tire isn't as flush as I want it and doesn't match the driver side. Semi-major problem, car is pulling slightly right. I don't have to fight the steering wheel to keep it straight, but if I do let go, it'll pull right. All these issues after dropping my car off at a "trusted" shop to get the car lowered on H&R Sports. Best believe I got my money back! |
01-28-2020, 03:55 PM | #315 |
![]() 0
Rep 17
"Hard drive" went bad on the head unit at 32k miles. Replaced under warranty. The only symptom was the dash not lighting up right away on super cold mornings. Otherwise this '16 328ix is a surprisingly solid upgrade from the Audi a4's I've been driving all these years.
If I have ANY complaints, it's that it gets noticed much more. I did like the stealth of the Audi. |
08-20-2020, 06:00 PM | #317 |
![]() 14
Rep 56
szl keeps going bad, replaced it once under warranty but it went bad , gave me once an error message about cruise control on the idrive and went out instantly but was marked on the compter of the stealership,,
had a blown water hose that nearly costed me an entire engine, from day one i had issues with the car with water, each 6 months or so i had to top up the coolant , sway bars broken even though i"m under 100 k kilos , but that not really a problem |
08-21-2020, 03:04 AM | #318 | |
![]() 11
Rep 49
1) MAP Thermostat 2) Transmission oil cooler 3) Start/stop button I could have done these myself if it wasn't under warranty. Not too pricey. Did the rear brakes recently. Very easy install. Overall good car - makes driving fun every day. |
