11-28-2018, 06:06 AM | #309 |
Rep 191
I will be heading to the track after work today in an attempt to improve my stock times. The conditions (as far as I understand) seem to be pretty good.
I've purchased Bm3, VRSF IC and Catless DP. Once I receive my OBD connection for BM3, I'll run stock once more the next time I make it back to the track. Then I'll flash STG1 just for a fun comparison with identical conditions. |
sspade2464.50 |
11-28-2018, 06:33 AM | #310 | |
Rep 3,680
BettyFkinCrocker180.00 |
11-28-2018, 09:11 AM | #311 |
Rep 191
Good call. Also, because the ECU will need to "relearn" and I'd rather have a clean "learned" pass on the stg1 rather than on stock tune.
11-28-2018, 09:41 AM | #312 |
Rep 3,680
Right. So flash a week or whatever before, make a pass or two on the tune, and flash to stock for comparison. Curious to see what the results are!
11-28-2018, 08:24 PM | #313 |
Rep 191
Well, I've got a slight bit of bad news. In my stupor of excitement (this track was only 10 minutes from my work, so I was hyped) I didn't realize this was an 1/8th mile track.
None the less, I wasn't going to make it a wasted trip and I had a blast. Took down a big tire S10 looking truck (he wasn't spinning, it was just disappointingly slow for the "hot rod" look and sound it had going on, the slips at 6:09 and 6:19 are vs the truck in the picture) and a somewhat modified 2016 Coyote ( he spun bad enough for me to win while he trapped 10mph faster than me) and a few others. Once again pretty impressed with this thing(being stock and all). Weather conditions definitely made a difference but still didn't improve the 60' that much. I again had no spinning, traction control off, brake boosted as 2nd beam lit. Now, I don't want to be "that guy" I was mocking in a previous post...but if we we're to calculate the rule of thumb with 60' fts (1 10th less on the 60' = 2 10ths in the 1/4), I may have ran a 13.9ish in the 1/4...theoretically. Obviously I'm not going to stick a flag pole in that time as we can't know for sure. But I will certainly be giving it another shot stock in this good weather on the 1/4 at Bradenton. Last edited by BettyFkinCrocker; 11-28-2018 at 08:35 PM.. |
11-28-2018, 08:49 PM | #314 |
Rep 5,456
Ssssoooo....
As an update to this thread: The weatherman was calling for rain today so the Sacramento Raceway was closed... It was supposed to be the closing night for the season but we are in luck! Track management has decided to try one more time, next Wednesday to get a final night in for 2018. We are all crossing our fingers hoping to get out... AFAIK, N26Ghost and Diegov209 are planning to run which will initiate some action on the N2X Speed Rankings! Special thanks to Dheeth-F30 for getting the info for the group |
11-28-2018, 08:53 PM | #315 | |
Rep 3,680
12-04-2018, 07:31 AM | #316 |
Rep 191
Flashed stg1 (91oct to keep it safe)last night. Nice little bump in power. Though if I am looking at logs right, I hit 25lbs of boost at one point...hoping I am wrong, lol.
I'll be heading back to the 1/4 this Thursday, so we will see what stg1 looks like on a timeslip. Weather will be alright, but not as good as the other night. |
12-04-2018, 07:53 AM | #317 | |
Rep 5,456
How does one prevent against overboosting the engine (like you may have done)... General consensus is to not push this motor over 22psi. I plan to keep mine at 20psi max. |
12-04-2018, 08:03 AM | #318 |
Rep 191
Not entirely sure to be honest, but I would hope that these parameters would be set for an OTS map. That's kind of the point(of an OTS) really. I have to believe this was a faulty reading, because my stock CP survived, I got no overboost codes, and the rest of the pulls showed around 21-22.
Just found the log - unless "boost pre throttle" is not the right parameter to monitor...definitely shows 25psi. http://www.bootmod3.net/log?id=5c05cda2d10b432685468572
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
sspade2464.50 |
12-04-2018, 10:27 AM | #319 | ||
Rep 3,680
12-07-2018, 06:00 AM | #321 |
Rep 191
Managed to only get one run. It was a disappointing 60 as I haven't ran since the STG 1 flash(had lots of wheel spin this time). I was hoping to run again after adjusting the boost by gear reduction for first, but too many messes on the track prevented me from doing so. Definitely an improvement. A good 60 would net pretty impressive numbers for a tune only set up.
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 Last edited by BettyFkinCrocker; 12-07-2018 at 08:42 AM.. |
12-07-2018, 06:31 AM | #322 | |
Rep 3,680
12-07-2018, 12:10 PM | #323 | |
Rep 86
12-07-2018, 12:32 PM | #324 |
Rep 5,456
Updated.
Let me know if you see anything that needs correction. |
12-07-2018, 01:00 PM | #325 |
Rep 3,680
I think below 13.4 is a stretch, as in, I think 13.4x is the best a stage 1 car can do. When I was still on stage 1 the best I could do was a 13.46 with a 1.94 60' in good conditions.
12-07-2018, 05:58 PM | #326 | |
Rep 191
Lots of if's of course. So hopefully next time I go, I can get more than one run in.
IG: @derringerF10
12-07-2018, 06:58 PM | #327 | |
Rep 3,680
12-31-2018, 09:09 AM | #328 |
Rep 439
Car: F31 xDrive, ZF8. 4020lb with driver. Track: Maple Grove Raceway, PA in Oct 2018 Mods: Dinantronics Stage 2, Dinan IC, aFe drop in filter. I ran the same (crappy) 60' just about every time. I used launch control as I was 'bracket racing' with coworkers so consistency was key. Next time I need to experiment with the launch as I see many people on here with significantly better 60' times. I really wanted to run a 13.5x that day but my 60' fail stopped me.
2022 BRG G80 xDrive
2005 SGM M3 Last edited by Malloy; 12-31-2018 at 09:41 AM.. |
sspade2464.50 |
12-31-2018, 09:18 AM | #329 | |
Rep 3,680
12-31-2018, 09:47 AM | #330 | |
Rep 439
10/18/18 I ran my best pass around 330PM. If I'm using the drag times calculator properly DA was -589.
2022 BRG G80 xDrive
2005 SGM M3 |
