08-12-2016, 03:47 AM | #1 |
Rep 1,863
Turn off your radio
Hi
Just thought I'd pass this on if anyone is concerned about battery drain. My car was in for a service recently and on checking the dashcam noticed that, due to the dumb way BMW insist on keeping the entertainment system running until you lock the car, the radio is frequently left on until the battery protection kicks in and switches it off. So for my service: Car driven to outside service bay Car moved to another space Car moved into service bay Car back to space outside service bay Car moved to bay outside washing station (I know!) Car to washing station Car moved back to bay outside washing station Car moved to collection point On each occasion the car was not locked so that's 8 times the system was running on battery only. |
08-12-2016, 03:50 AM | #2 |
Rep 7,032
Drives: 335xd Msport +
Does it actually turn the radio off as in no power going into it at all or just mutes it - ie quiet but still draining battery???
08-12-2016, 04:57 AM | #5 |
Rep 9,709
OP I think you are missing the proper guidance. Using the 'lock car' method to switch off the ignition is a lazy way of switching the car off. The correct way is to press the ignition button once to stop the engine, then pressing it again (without foot on brake pedal) to switch the ignition completely off.
08-12-2016, 05:47 AM | #6 | |
Rep 2,468
Drives: F21 M135i LCI
Current: F21 M135i Mineral Grey and few options
Previous: F30 320i XDrive, E85 2.5i, E21 323i |
08-12-2016, 06:58 AM | #7 | |
Rep 1,863
I'm not using the car, it's at the dealers. THEY are not shutting the car down. That said, it's a daft scenario anyway. One press should shut the car down, not two. |
08-12-2016, 08:19 AM | #8 | |
Rep 15,858
Not everyone wants a complete shut down on the first press, no more than key users necessarily want the radio off with an engine switch off. IMO, BMW have it correct, it is really the same as the old days with ignition 1 & 2 positions. |
08-12-2016, 08:37 AM | #9 |
Rep 2,234
And that would be annoying if you didn't want everything shut down. I think the present way works fine. I've never had an issue with it in over 11 years of driving BMWs with the push button ignition.
08-12-2016, 08:56 AM | #10 | |
Rep 1,863
Fair point not everyone wants everything off with an engine shut down. Time for a poll on that one? LOL This conversation has been had before. It's not the same as Key 1 & 2 positions because keys spring back to position 1 from 2 after starting the car so when you turn the key one more position (same as one press of the start/stop button) everything goes off. |
08-12-2016, 09:18 AM | #11 | |
Rep 257
1) Off 2) Accessory 3) Ignition 4) Start So the key springs back to position 3, ignition not 2 (your 1) |
08-12-2016, 09:20 AM | #12 | |
Rep 257
08-12-2016, 09:21 AM | #13 |
Rep 707
It turns itself off after a certain period in any case. I can't see it really being likely to cause any big problems, and if it did run the battery all the way down? Happy days, the car's at the dealer already.
08-12-2016, 10:40 AM | #14 |
Rep 4,933
It was the irritation factor for me. Fine leaving the radio and wipers on when I have just switched off the engine but I expect them to switch off when I open the door. 1st world problem and all that!
08-12-2016, 11:39 AM | #15 | |
Rep 15,858
0) Steering lock engaged. 1) Steering lock disengaged. (Individual electrical accessories are ready for operation). 2) Ignition on. (All electrical equipment and accessories are available for use). 3) Starting the engine For the OP; Hence why I stated positions 1 & 2. First push on shut down puts us from the equivalent position 2, back to position 1. Just as it has been for many years with BMW, (key or start button). |
LobB5109.00 |
08-12-2016, 11:47 AM | #16 |
Rep 1,034
Some like that the radio stays on (for passengers), others hate it, me included, and that is the beauty of an F30, £10 for a cable and 10 minutes work and you can set it to go off when the drivers door opens.
08-12-2016, 11:48 AM | #17 |
Rep 15,858
Again this is not peculiar to our current start-stop system. Has been the BMW way for as long as I can remember, certainly from the first generation 3-series. (May even have been so on the 2002). You could get out and still have the radio and intermittent wipers working. You had to switch to position 0 to switch everything off. Only difference I suppose, we had to do so, to withdraw the key and take it with us to lock the car.
LobB5109.00 |
08-12-2016, 12:57 PM | #18 | |
Rep 2,376
Current - X3m Comp
Gone but not forgotten - F80 m3 Comp, F30 340i, F30 - 320i |
08-12-2016, 01:07 PM | #19 | |
Rep 25,113
I'd be concerned if I'd ever had a problem....but simply have not had any battery drain concerns.
My car made front page of Bimmerpost
08-12-2016, 01:33 PM | #20 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
The cars are connected to a charger as soon as they are in the workshop. I'm a bit confused by this thread, if my car battery went flat after the car being moved 8 times, they can have it back!
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
08-12-2016, 01:40 PM | #21 | |
Rep 11,292
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
08-12-2016, 01:43 PM | #22 |
Rep 378
Drives: M135i, becoming an X3!
Yep, that's what I thought. Even if the radio stays on (for eight minutes), if you did it often enough the car would shut it off due to the low voltage of the battery. Ironically, with Connected Drive, it would also let the dealer know the battery was nearly flat!
