11-16-2018, 11:04 AM | #507 | |
Rep 3,679
Stage 1: all stock hardware Stage 2: high flow (or catless) downpipe and intercooler That said, you can run stage 2 on the stock intercooler without problems, but the car will be very susceptible to heat soak. It can be done, but I don't recommend it. So, if you don't plan on upgrading the intercooler (which I'd recommend you do) you should probably stick with stage 1, but it won't hurt to try out stage 2.
11-16-2018, 12:52 PM | #509 |
Rep 3,679
Understandable. Unfortunately it's just stage 1 and 2 for now, so I would just run what your comfortable with. If your comfortable with stage 2 on the stock intercooler and being a bit more susceptible to temperatures, go for it. If not stay on stage 1.
CandyRedRC46242.00 |
11-16-2018, 01:53 PM | #511 |
Rep 3,679
That's what I would do as well. Good idea
11-22-2018, 10:43 PM | #513 |
Rep 3,679
Hyyyype! Congrats
11-22-2018, 10:49 PM | #514 |
Go Fast Dont Die!
407
Rep 472
Drives: '12 328i Sport 6MT
Nice! Looks like I'll be switching from Dinan to bootmod 3 now! I can't stand looking at my CEL everyday since Dinan doesn't support catless. I keep hearing great things about BMS but have been a little intimidated to Switch, my next question is do I have to have a FMIC to Run stage 2 93 octane with my current mods? (listed below) I have everything else but the FMIC. I don't have any plans of going big turbo and if I can just flash right to that map and not have to buy all the ots maps that would be ideal. Dont really want to miss the deals going on right now but don't want to have to buy an intercooler or all ots maps which I don't need either. If I can just flash to stage 2 and throw the intercooler in for improvement in the next couple months that would be perfect because that's where she would stay.
BootMod3 stage 2 93 octane AGG| K&N Drop In| Turner Motorsports Intercooler| BMS Catchcan| FTP Chargepipe & TIC| MST Turbo Intake Pipe| CW Catless Downpipe| BAV Coils| KW DDC Coilovers| Active Autowerke Exhaust| CF Mirrors| CF Spoiler| Rohana RFX11| Black Painted Roof| @instagram.com/fastactionjax/
@youtube.com/fastactionjax/ Last edited by FastActionJax; 11-22-2018 at 11:54 PM.. |
11-23-2018, 10:37 AM | #515 | |
Rep 3,679
You can do that. It's not ideal, but it won't hurt the car, per se. It will just heat soak pretty quickly.
11-28-2018, 11:14 PM | #517 |
Rep 184
Drives: 328i N26
11-29-2018, 01:39 PM | #518 |
Rep 77
I had a quick look into the logs. The intake air temperatures look very nice, so your intercooler is doing its job. There is no significant ignition retardation, only a bit on bank 3 but I see that in my car as well, I guess that bank is just a bit sensitive. The air fuel ratios though the pulls look very good and safe for the engine.
The only think I find a bit strange is the boost pressure. It does not fully reach boost target on higher revs. It is not dangerous for the engine, but you could check the system for boost leaks. If there is one, it is minor. |
11-29-2018, 03:53 PM | #521 | ||
Rep 3,679
11-29-2018, 06:42 PM | #522 | |||
Rep 184
Drives: 328i N26
Yeah I'm not sure either to be honest. The car runs fine and I have EWG. But could it possibly be a leak? |
11-29-2018, 09:07 PM | #523 |
Rep 3,679
Nope, nothing indicates a boost leak. The only weird thing is the boost target being lower than all the other stage 2 logs I've seen, which would be an issue in the tune, not a mechanical issue with the car.
12-01-2018, 09:41 PM | #524 |
Rep 184
Drives: 328i N26
So I did a couple pulls tn for more logs as I just updated to the 4.2 version and wanted to see if I getting closer to boost targets. However when I pulled into the garage I noticed a smell. So I opened the hood and noticed my manifold was red it's not what I would call a lot but is this something to worry about or is it normal after pushing the car so much? The camera didn't capture all the red so there was a bit more than pictured.
12-01-2018, 10:49 PM | #525 | |
Rep 3,679
12-02-2018, 01:33 PM | #526 |
Rep 170
The only thing that irks me with this tune is it seems noticeably rougher than stock when cold. Sometimes when warm there are weird vibrations through the cabin from the engine that I don't think were there on the stock tune. I think it happens occasionally when coming to a stop or shifting from park to drive.
Also is it just me or does the car push a lot more pressure in comfort at low RPMs? This doesn't seem like a good idea for longevity in day to day driving as it seems to push lots of torque at low rpms in a drive mode where I really don't need it. It also seems to take a lot more to get the car to downshift in comfort because of this added torque capacity. Is this just placebo on my part? Don't know if its even possible for them to tune different drive modes to behave as differently as I'd like but I wonder what other people think or if maybe my tune is a little off? EDIT: Today it was warmer and maybe I'm crazy but everything felt a lot better. Last edited by meltbox; 12-02-2018 at 05:03 PM.. |
12-02-2018, 02:07 PM | #527 |
Rep 50
Help? I get a p0234 "overboost condition". Usually happens at highway speeds when gunning it. Stage 1 n20 pwg. No mods.
Should I online recode? Last edited by MrZeeMan; 12-02-2018 at 04:49 PM.. |
12-02-2018, 05:04 PM | #528 |
Rep 170
bm3, bootmod3 |
