BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY Icam retrofit
proTUNING Freaks
      10-08-2020, 01:19 AM   #1
Maxfusion
Drives: 320I XDrive
DIY Icam retrofit
Hello, guys!
I have a 06/2016 F30 LCI.
Already done retrofit NBT Evo Touch from stock HUentry.
Does it exist anything solution to install ICAM (without trsvc or something encoding blocks) with 06/2016 FEM? I heard that this theme was not approached by ICAM before, only trsvc...
      10-24-2021, 12:58 AM   #2
Maxfusion
Drives: 320I XDrive
Up! I`m interested too
      10-24-2021, 11:36 AM   #3
atzebmw
Drives: Tesla Model 3
I didn't do it but had the plan to do it and made some notices for it.
This was written in another forum...
"Cars before 07/17 have KCAN1 at pins 51/52 so you can use ICAM1 ... you just have to use part number 66539475684 or it’s equivalent, do not use the very similar ICAM 66539109856 as used on the F15 and others ... that won’t work but looks exactly the same.
You will have to fdl code the HU from TRSVC to ICAM ..."
I will probably not do it anymore.
      10-25-2021, 04:49 PM   #4
Tuerkay
Drives: BMW F20
You could use any k-can ICAM, doesn´t matter if it is the k-can1 version from an 3/4- Series BMW or the k-can3 version from an 5/7/X-Series BMW.
the k-can1 version can be connected to FEM 51/52 and be diagnosed/coded with esys/ISTA in car. Also you can easily VO code it.
The k-can3 version on the other hand has to be connected to k-can2 in car. ISTA and esys won´t show it. you have to properly code it on a bench with k-can3 before installing. VO coding won´t work that easily. Need an VO from an car that has icam on k-can3 and then modify camera position vie FDL.
i have an F25 icam in my F20 (2012). If i find an cheap F22 icam, i´ll swap it and place this one in my F25, but these modules will cost you twice the amount of an k-can3 icam.
Edit (11-12-2021): Got my hands on an F22 ICAM (66536995906). It was Factory fitted on an MY2018. Didn´t work on k-can and was shown as k-can3 on bench. Another forum member tried 66539475684 on his 2015 F30 and this one also didn´t show up.
looking for someone who can tell me which ICAM would have k-can instead of k-can3. i´m suspecting 66536999277 and/or 66537951083 but can´t find those around.
SirMoo3.00
      12-14-2023, 12:18 PM   #5
Cedric02
Drives: BMW E64
ICAM E64
Guys, I'm looking to retrofit a trunk actuator (A224) from F12 into my E64 with an I8 iCam for 360 all-round view. I have looked at the diagrams and while the reversing camera sends the video signal on LVDS to TRSVC, the cameras on an iCams are on Ethernet. However, upon looking into this further there is technical documentation that stipulates that the iCams can programmed to work on KCAN. So my question is how do I connect my james bond reversing camera to convert from LVDS signal to the iCam module?
