10-16-2021, 08:07 AM | #1 |
Rep 22
I pushed E-sys button DO NOT USE!!! What now?
Hello guys, I was doing usual FDL coding and by mistake pushed DO NOT USE!!! Button. Esys coded my nbt. I would not dare to unplug coding cable and let it finish.
After this I had only few options in nbt and picture was small. I have 8,8" screen. I shut down my car and after restart screen went to normal. Only issue now is that i do not have my apps etc under connected drive. Other things seem to work as usual. Also cant code drl ligh switching under the lights menu. 2015 f36 is the car if it makes any difference. Thanks for help. |
10-16-2021, 10:33 AM | #3 |
Rep 22
Well. I did this.
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. But this did not help. If I code any fdl code like drl settings to apperar in menu, then it codes successfully but i do not see any changes in menu. And connection seems to be lost for connected drive because there is no automatic time setting available. Uh I messed up bad. |
10-16-2021, 11:24 AM | #4 | |
Rep 2,302
But it doesn't always have to end badly. Stupid question, but after coding the DRL settings you press the "FDL Code" button and not the "Code" button? Somewhere in the IDrive there is a menu item "Update services". This could help bring your apps back. I think under "ConnectedDrive" and then "Option" there is this item. |
10-26-2021, 01:17 AM | #7 |
Rep 22
Sorry, did not have time to response sooner.
But solution seemed to be following for me: 1. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. 2. Updated services in NBT options menu. All works like before, apps etc. Today I had time and tested FDL coding, it works also like it should. Thanks for help everyone. |
