07-19-2019, 07:51 AM | #177 | |
Rep 891
If you go down this route and have a similar setup to mine, remove the tab BEFORE the roll and you won't have my problem.
07-19-2019, 04:11 PM | #178 | |
Rep 2,044
RCT Performance, Westbury. I did the LCAs myself, and was able to get a good enough alignment with a tape measure for me to drive to the shop for a real alignment. Murf Last edited by Littlebear; 10-30-2021 at 06:02 AM.. |
08-08-2019, 02:46 PM | #179 |
Rep 233
My parts finally came in. I ordered the Lemforder units from www.onlinecarparts.co.uk. They look like they are the OEM parts with the //M logo ground off. Ordering was easy and shipping was pretty fast (6 days) considering parts came in from Berlin.
All in with shipping it was about $400 for the LCAs and TS. Not bad considering the OEM LCAs are $400 on their own. I got the summit racing spacers as well and now I'm only waiting for the replacement hardware and headlight leveling rod. |
Dylan861330.00 |
08-13-2019, 04:16 PM | #180 |
Rep 2,044
Hello BMW Experts!
It seems most people here are doing the F80 LCA, then the F80 TS.... I want to try this setup: Correction hubs with stock F30 LCA & F80 TS, or F30 TS with monoball bushings or Meyle HD bushings. Anyone see probs with this setup, pls? TIA! Murf Last edited by Littlebear; 10-30-2021 at 06:02 AM.. |
08-13-2019, 06:25 PM | #181 |
Car Hypochondriac
335
Rep 903
I'm really curious about the meyle HD TS bushings. People said great things about them for the E90s, but I haven't heard of anyone with an F3x trying them yet.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
08-14-2019, 06:20 AM | #182 |
Rep 2,044
08-14-2019, 08:21 AM | #183 |
Car Hypochondriac
335
Rep 903
Ok, so I was doing research on these, and found that they are available from fcpeuro for $80~/each.
More importantly, I found this info in the description: "This control arm features an all steel ball joint and solid rubber bushing" I think this may be the ticket, gentlemen. For only $170, I think I may try these before stepping up to M3 or kmac. Seems like a good middle ground, stiffer than originally designed, but also not completely solid like a monoball and should still be comfortable on the street. Not to mention the fact that they have a 4 year warranty and if you buy from fcpeuro, you could replace them for "free" (minus shipping costs).
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 Last edited by Eschmacher; 08-14-2019 at 08:31 AM.. |
08-15-2019, 01:11 AM | #184 | |
Rep 1,292
F30 ts or f80 ts with monoball bushings would be the best (remember f80 ts with their original bushings don't fit the f30).
2017 M550i | Sophistograu
08-16-2019, 02:10 PM | #185 | |
Rep 99
08-16-2019, 03:37 PM | #186 | |
Car Hypochondriac
335
Rep 903
I can't find the correct ones sold in the US. Here are the part numbers: 3160500066/HD 3160500067/HD |
08-16-2019, 03:51 PM | #187 |
Car Hypochondriac
335
Rep 903
On ebay you can get a pair of meyle hd arms from england for about $240 shipped. Still cheaper than $300+ for the M3 arms.
Edit: found another seller and they are about $200 shipped. Last edited by Eschmacher; 08-20-2019 at 04:38 PM.. |
08-16-2019, 04:13 PM | #188 |
Rep 99
08-25-2019, 04:13 PM | #189 |
Rep 1,134
I got the F80 LCAs installed. Firestone tried to get the alignment correct twice and they couldn't. The car steers to the right although the toe-in values are correct. What do you guys think?
08-25-2019, 09:48 PM | #190 |
Car Hypochondriac
335
Rep 903
08-26-2019, 11:13 AM | #191 |
Rep 99
08-26-2019, 06:42 PM | #192 |
Car Hypochondriac
335
Rep 903
08-26-2019, 07:23 PM | #193 |
Rep 75
What advantages do mayle arms have? Can you put an ebay link where to buy them?
Edit I have already found the ebay link but I don't see any description is there more camber? What advantage does it have? Last edited by madriz; 08-26-2019 at 07:30 PM.. |
08-26-2019, 08:40 PM | #194 |
Car Hypochondriac
335
Rep 903
Stiffer bushings. Will decrease deflection and changes in geometry, and increase steering feel and precision.
08-27-2019, 07:42 AM | #196 |
Rep 787
Please post your opinions when you get around to installing them. Anyone else have these meyle arms on their f30 that can share their thoughts? The price is so low compared to the alternatives.
08-27-2019, 08:19 AM | #197 |
Car Hypochondriac
335
Rep 903
The only other feedback i could find was from e9x guys, and they were very positive. I expect this to be similar to the m3/m4 TS, but with the same geometry as stock.
08-27-2019, 10:11 AM | #198 | |
Rep 787
BTW, anyone here with 19" wheels install the m3 arms? I hear the overall wheel/tire package isn't much larger than the 18s because the 19s tire profile is lower, but I'd hate to buy the parts and get them installed only to find out I don't have enough clearance. I'm stock on m-sport adaptive dampers and springs. Rwd, no plans to lower the car any time soon. If I do, it would only be a 10mm drop via Dinan springs. |
