08-19-2019, 08:00 PM | #67 | |
Rep 1,286
But I could just do the methanol kit anyway + custom tune, right? I'm sure I can buy methanol somewhere and that doesn't require constant filling I presume...
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
08-19-2019, 08:07 PM | #68 | ||
Rep 1,375
I drive me car till there's about 20 miles to empty, add in about 11 gallons, head home and add 4 gallons of E85. That rotation keeps me at roughly an E30 blend. Four 5 gallon containers fit in the trunk pretty easily as well. |
McLaren720s1476.00 |
08-19-2019, 08:09 PM | #69 |
Rep 1,375
Methanol usually is easier to locate and yes depending on the nozzle size and how often you join your car, a tank will last a while.
08-19-2019, 08:24 PM | #70 | |
Rep 1,286
You don't ever keep ethanol in your car, right? You keep full extra containers at home? And once I put ethanol in, I would immediately flash the Stage 2 E30 map?
08-19-2019, 09:15 PM | #71 | |
Rep 151
There is also the Shell in Thrashers Corner that sells 100 octane ($10-11 though last time I checked). P.S. thanks again for the Costco recommendation Halim says it is a lot better gas than the shell or chevron.
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
08-19-2019, 09:41 PM | #72 | |
Rep 1,286
08-20-2019, 10:19 AM | #73 | |
Rep 25
08-20-2019, 10:13 PM | #74 |
Rep 1,286
I am contemplating using E30 with the Stage 2H 91. Would that help it run better? I'm thinking it might get rid of the knock and improve ignition timings...
08-20-2019, 10:16 PM | #75 |
Rep 7,602
Wouldn't this make it run lean? Ethanol has a lower energy density than gasoline. It has a higher octane but requires a great volume of fuel to be supplied for a given lambda (AFR) target.
08-22-2019, 07:14 AM | #76 |
Rep 1,375
Yes, the HPFP would have a harder time keeping up because the fuel commanded between E30 maps and non-E30 maps should have different commanded fuel mapping.
08-22-2019, 07:28 AM | #77 |
Rep 1,375
Got a log this morning with the VP Racing X98 (98% Ethanol / 2% Methanol). There was about half a gallon of the Snow Boost Juice (50% Methanol / 50% Water) left in my tank when I added a gallon of the X98 yesterday. Not sure what the alcohol percentage I would be spraying now is but I think it should be somewhere in the area of 75-80% Alcohol/20-25% water. Anywho, here's the log:
http://www.bootmod3.net/log?id=5d5e779ac090c6408ae03074 Side note: Does anyone know what the difference is between these two PID's? 1) Lamda[AFR] 2) Lamda Control Factor (Bank1)-Faster[ARF] I believe #1 is commanded AFR based on what STFT are being commanded which is kind of misconceiving. I think #2 is the actual AFR. If I'm correct, a custom tune should bring a VERY nice amount of HP/TQ considering the extra fuel/rich AFR from the X98/water. Anybody think or know differently? -Nick |
08-22-2019, 01:27 PM | #78 |
Rep 1,499
Log looks good. This log seems to run a bit more rich, which makes sense spraying meth but that's probably a good thing. I feel like these engines run pretty lean for FI in the higher RPMs. Here is my Stage 2 E30 log from a few weeks ago for comparison.
http://www.bootmod3.net/log?id=5d337b7dc090c63991f042dd
08-22-2019, 04:49 PM | #79 | |
Rep 1,286
Also, chaungo was saying that my WGDC was bad on the Stage 2H map I ran but yours hits over 90% as well, so I'm confused...where should this WGDC be at?
08-22-2019, 06:49 PM | #80 | ||
Rep 1,375
WGDC should normally be anywhere from 75-90% during WOT. The 2H maps demand a little higher psi in the upper RPM's where the small stock turbo is pumping harder to push out the requested psi. I've been speaking to a couple custom tuners and both have said that they will target 20-21psi at 12-13 degrees of timing advance with my current mods in my sig. So there is clearly A LOT of room for performance with these cars and the OTS maps. |
08-22-2019, 09:18 PM | #81 | |
Rep 1,286
So then what made my Stage 2H map not run “great”? (Car felt great and first guy from PTF said log was fine). Would higher octane improve it? Better spark plugs?
08-23-2019, 05:16 AM | #82 | ||
Rep 1,375
A water methanol kit would greatly help you in your situation. |
08-23-2019, 07:46 AM | #83 |
Rep 1,499
I believe 20-21PSI is way outside of the efficiency range for this turbo. Does anyone have a compressor map for the stock EWG turbo?
08-23-2019, 08:25 AM | #84 | |
Rep 1,286
So, I need to get me a methanol kit. Can you explain to me what exactly I need for a methanol kit and what’s the install like? And can I still run 91 octane with a meth kit? I am still thinking about giving E30 a try and see if it’s maintainable.
08-23-2019, 08:36 AM | #85 | |
Rep 1,499
This is a simple kit from AEM. Yes you can run it with 91 octane. Fisrt things first though, do you have stock or aftermarket FMIC?
https://www.aemelectronics.com/produ...soline-engines Installation is pretty pretty straight forward if you have an aftermarket charge pipe with 2 bungs Install tank Install pump Screw pressure sensor into CP at bung 1 Screw injector nozzle into CP at bung 2 Mount controller and make necessary electrical connections (pump, 12V power, etc.) Run supply lines from the pump to the injector (recommended to install anti-siphoning check valve on supply line near the injector) Test flow Screw pressure sensor into CP at bung 1 Screw injector nozzle into CP at bung 2 Set starting PSI and end PSI on the controller Log Quote:
08-23-2019, 08:39 AM | #86 | |
Rep 1,286
I have the BMS FMIC upgrade and CTS Turbo charge pipe upgrade. Would these be acceptable?
08-23-2019, 12:25 PM | #87 |
Rep 1,499
You would want Part Number: 30-3300 - V2 Water/Methanol Injection Kit, Standard Controller - Internal MAP with 35psi max, 200psi WM Pump, 1 Gallon Reservoir, Conductive Fluid Level Sensor
Price: $491.77 Yes you'll need to buy the inline filter and solenoid check valve separately. I'm surprised to see the BMS FMIC not performing better. You shouldn't see temps more than 20F over ambient.
08-23-2019, 12:38 PM | #88 | |
Rep 1,286
Initially I was going to get the VRSF 5” but XHP was out of stock so I pulled the trigger on this junk and regret it. Now, I need to find a shop that can install the meth kit
