08-06-2019, 11:13 PM | #1 |
Rep 1,286
Coilover install labor cost quote
I’m getting my B14s installed in about 4 weeks and a shop just quoted me about 6 hours of labor and $800.
Does that sound about right?
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
08-07-2019, 12:41 AM | #2 |
Rep 681
Sounds about right. Depending on your location anyways. I was quoted around that in SF, CA but I ended up just doing it myself. Took me about 6 hours to do myself but I was also doing my BBK at the same time.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
exE36M3487.50 |
08-07-2019, 08:30 AM | #4 |
Rep 1,286
Yes, they said there is an alignment included for the first 1000 miles, but won’t be performed unless needed, as some coilovers do not automatically require alignment and this is to be evaluated after the suspension settles in a few days.
08-07-2019, 12:41 PM | #5 |
Rep 3,539
With an alignment it seems believable to me (I don't know what market you're in), without an alignment the labor hours and price is too high IMO.
sspade2464.50 |
08-07-2019, 01:04 PM | #6 |
Rep 463
That's ridiculous. Spring/Coilover install + alignment should run 500. This "BMW tax" is out of control. I was quoted 475 to install KW V1 + alignment from 2 shops in the area last year.
08-07-2019, 01:31 PM | #7 |
Rep 1,286
Interesting. I’ll try calling a couple other shops to see if I can get a better rate.
08-07-2019, 03:43 PM | #8 |
Rep 1,286
Just called 2 more shops. One quoted me $850 and the other one $1100. Lol
08-07-2019, 03:47 PM | #9 |
Rep 928
I got quoted 4 hrs labor plus alignment
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
08-07-2019, 05:17 PM | #10 |
Rep 1,127
The should certainly check the alignment after putting in new suspension. Coilovers need ride height to be set, but the alignment will probably not to be too out of spec if you keep the same ride height or close.
800 sounds reasonable to me. There is always someone who could get it done cheaper etc etc. Its the internet after all. |
08-07-2019, 05:51 PM | #11 | |
Rep 1,286
08-07-2019, 09:47 PM | #13 |
Rep 1,127
TBH I am not sure what they can really adjust on the front without additional hardware, like camber/caster plates and/or ecentric bushings. The back they can adjust camber a bit, but the front really has little adjustment from what I understand about it.
08-09-2019, 08:33 AM | #15 |
Rep 1,286
A shop quoted me $500 but they said they don’t work on BMWs nor have they done a coilover install in years so that makes me uneasy.
08-09-2019, 09:43 AM | #16 |
Rep 743
You have xdrive. 6 hours labour is more than fair. And yes you will want an alignment whether it 'needs' it or not. Getting the most negative camber out of the fronts as possible as there isn't much there and then depending on how you like turn in feel and if you want to help the car rotate better you can actually dial the rear negative camber back closer to -1 - 1.25. closer balance will help the driving dynamics and help that back end. i did that based on a recommendation from Farkle when I put my dinan springs in and it makes a difference and feels way better than the stock oem alignment specs.
McLaren720s1476.00 mcintoshf30184.00 |
08-09-2019, 04:49 PM | #17 | |
Rep 1,286
08-10-2019, 08:01 PM | #19 |
Rep 1,286
But can they dial in negative camber for the rear during alignment?
08-10-2019, 10:14 PM | #20 | |
Rep 743
Front toe: 0.03 to 0.1deg toe in each side Rear camber: -1 to -1.25deg each side Rear toe: 0.1 to 0.15deg toe in each side Farkle's Explanation: Front Camber: You want as much as possible so the front end grabs during cornering. BMW doesn't offer nearly enough, so max out what you can. M-cars come with around -1.5deg each side from the factory, so there's plenty to go. Front Toe: BMW (and other mfgs) typically spec more toe than required so the car tracks straight when you take your hands off the wheel and for more straight light stability. When the toe is excessive however it hurts turn in response. Even at 0.03deg toe in each side the car tracks straight IME and turn in response is much quicker. Your car will fee much more nimble than before. You don't want to go too close to 0 or toe out though, because then the front end will want to "dance" around and will require more steering corrections. I made that mistake once when I tried having it aligned to 0.01deg in each side. Rear Camber: The rear actually has a lot of adjustment available from the factory. The -1.5 to -2deg from the factory would make sense if the front camber were more negative, but is just out of balance when you're limited to -.7deg in the front. They do this so the rear has more grip and your car understeers. Going to -1deg in the rear will better balance the front to rear and allow the car to rotate better. Rear Toe: Rear toe in will keep the car more stable on launching. I like it a bit higher than front toe, but not excessive. |
08-11-2019, 07:38 AM | #21 |
BMW CCA Member
488
Rep 808
FWIW, don't dwell too much on the cost - because on this forum, we are ALL over the globe. The labor rates in Northern California are from $150-$255/hour. So a 4 hour job can range from $600-$1020.
General rule of thumb is about 1 hour per wheel for most suspension work. A LOT of shops will quote a "book" price, it's that safe number for them where maybe a master tech can do a job in 1 hour but the apprentice 3. So book comes in at 3. Most BMW indy shops tend to quote at the master rate because it's the owner and he knows his stuff. It's already been said... but if the range is 4-6 hours for this job, just multiply the labor rate accordingly. |
McLaren720s1476.00 |
08-11-2019, 03:10 PM | #22 |
Cheapskate
4447
Rep 4,993
There has to be a shop or local enthusiast that'll do the work for less than $100 per hour. Here most indy shops are $75/hour. Even a regular tire shop can do it, our cars aren't that complex.
