12-30-2021, 04:02 PM | #23 | |
Rep 664
Drives: 2013 BMW 335i
01-01-2022, 07:26 AM | #24 |
Rep 107
I went with the turbosmart diverter with a injen/greddy hybrid intake. Its the best sounding on a bmw that i have ever heard, and there is no beating foam element filters.
2014 435i/VRSF CATLESS DP/AWE MIDPIPE&EXHAUST/VRSF CHARGE PIPE/BMS INTERCOOLER/TURBOSMART BOV/INJEN INTAKE/MHD STAGE2+ |
01-01-2022, 07:31 AM | #25 |
Rep 107
Paper filter - smallest particle filtered 30 micron. Dust clogs paper rapidly and by 15k miles flow can be reduced by as much as 70%.
Oiled cloth - smallest particle filtered 45 micron. Lets a lot of dirt through but flows well when clean. Oiled foam - smallest particle filtered 5 micron. Foam provides better filtering and has a greater filtration depth so doesn't clog as quickly as paper. 5000 miles cleaning interval recommended.
01-01-2022, 07:40 AM | #26 |
Rep 107
Most my friends drive bmw's and they have all switched to foam element. Here is a N54 during an engine swap with ramtech foam element filters.
01-01-2022, 10:58 AM | #27 |
Rep 190,597
Looks good
01-03-2022, 12:06 PM | #28 |
Rep 7,591
I don't run a scoop. It might direct some more "cold" air into your intake area if you aren't running a closed intake setup but its effect is probably going to be negligible.
alohasurftoad3069.00 |
01-03-2022, 12:18 PM | #29 |
Rep 664
01-03-2022, 08:40 PM | #30 |
Rep 107
I will get them sometime tonight
01-04-2022, 09:53 AM | #31 |
Rep 190,597
01-04-2022, 04:53 PM | #32 |
Rep 4,130
I'll believe it when I hear it. New BMWs sound like vaccum cleaners, and my buddies E30 325i with the M20B25 sounded like a sewing machine. I loved it.
Mods: Yes.
01-05-2022, 10:32 AM | #33 |
Rep 211
I've never understood the appeal of a loud sucking sound, unless its tolerated for the benefit of power gain. But, obviously many disagree as intakes seem to sell quite well.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
01-05-2022, 10:52 AM | #34 | |
Rep 4,130
Newer cars just sound so artificial and kinda boring - or they are all intake noise with nothing from the exhaust.
Mods: Yes.
01-05-2022, 10:59 AM | #35 | |
Rep 5,391
https://afepower.com/afe-power-54-12...amic-air-scoop |
01-05-2022, 11:18 AM | #36 | |
Rep 4,130
Mods: Yes.
01-05-2022, 11:45 AM | #37 | ||
Rep 5,391
01-05-2022, 12:13 PM | #38 |
Rep 4,130
https://www.evolvetuning.us/catalog/...f20-f21-m135i/
Let me take a picture. I paid WAYYYY less (as I just bought the scoop from another member.) We should make one out of ABS plastic or 3D print it. Edit: pictures. And yes, it’s very dirty.
Mods: Yes.
01-05-2022, 12:47 PM | #39 |
Rep 7,591
Those scoops might have some sort of a ram air effect at high speeds with a closed airbox but if you have MPPK or anything else that would be negated. I would be seriously surprised if you could see anything quantitative in testing. There's also discussion about removing the OEM grate at the airbox intake to reduce restrictions, but i find both unncessary with MPPK airbox since you have the 2nd opening. I dont want to be forcing debris or rain or anything into my airbox anyways.
01-05-2022, 01:01 PM | #40 | |
Rep 4,130
All I Can say is that I ran it with the Dinan, and dryflow and that area was particularly dirty when it came time to clean the filter. I got it because it mostly looked cool, but I never noticed anything when I added it. You'll also not in the picture it looks like it blocks a portion of it, but when I installed it, it looked pretty flush.
Mods: Yes.
01-05-2022, 01:28 PM | #41 | |
Rep 5,391
I wouldn't want a grill mounted scoop directly attached to my airbox for fear that in a flood situation with water splashing into my grill that an attached scoop could force water into my engine. |
01-05-2022, 01:50 PM | #42 | |
Rep 7,591
The whole "cold air" thing is another area of debate. All my intake testing showed that the temperature of the intake air had zero impact on IATs measured post-IC, so a open air underhood intake didnt show higher IATs than a closed box intake. In theory i would argue if you are sucking in very hot air (imagine a filter right on our turbo which is next to manifold) then you might heat soak your IC faster but under most conditions the air temp at the filter seems to not be relevant for IATs |
01-05-2022, 02:23 PM | #43 | ||
Rep 5,391
Haha, it's too cold right now or I would go outside and start taking my car apart.😀 |
01-05-2022, 02:32 PM | #44 | |
Rep 4,130
Mods: Yes.
