11-18-2020, 06:44 PM | #1 |
Rep 8
Bluetooth and ios 14 failure
I have a basic 2012 f30 and now with ios 14 i cannot connect to bluetooth anymore. What can i try to fix it?
Thank you |
11-18-2020, 08:52 PM | #2 |
Rep 6
Bluetooth?
Hello,
can you please describe your issue in more detail? Stock head unit? MMI box? Did you stream music using bluetooth or phone calls only? When you say you cannot connect, did you try to remove the car as a device in bluetooth and pair again? Have you connected a different device to the car? Have you rebooted or even reset your phone since the issue? Are you able to connect your phone to another bluetooth vehicle or audio device? More DEETS!
Stay cool and as always, Thank you!
__Driver__ 'Merica" |
11-19-2020, 12:06 AM | #3 |
Rep 8
What i mean is i cannot connect my phone to the car audio via bluetooth anymore. I cant play music, receive calls etc. the car and phone do not recognize each other anymore. This is after i installed ios 14.
I hope this makes sense |
12-08-2020, 05:38 PM | #4 | |
Rep 6
12-09-2020, 10:52 PM | #6 |
Rep 881
iOS 14 added the new updated Privacy section in Settings. You now have to enable Bluetooth BY APP, and Local Network BY APP, etc. I suspect it's likely that...if everything else is the same as before. You can also see the same new BY APP settings switch for Bluetooth (to turn access on) under each individual App's settings.
You should also be able to see your car listed as a Device in the Bluetooth settings (listed as BMW XXXXX, where those are the last 5 digits of your VIN). It shows connection status, and has the 'Forget This Device' option if needed, when you want to re-pair from scratch with your car. |
