08-16-2019, 10:46 AM | #23 | |
Rep 716
I do have a transfer pump but I did not want to be under the car to pump the oil up in the tranny. Instead, I went to Home Depot and got some flexible tubing to fit my funnel. I put the funnel up in the engine compartment and routed the tubing into the transmission filling hole. This was a cheap, easy and effective way to fill the transmission. |
08-16-2019, 12:39 PM | #24 | ||
Rep 1,217
09-03-2019, 03:14 AM | #25 | |
Rep 69
It makes sense to work on a cold engine and then go though the gears and lastly warming up to trigger the thermostat to open. |
09-03-2019, 07:02 AM | #26 | |||
Rep 3,947
My belief is that it is far more harmful for the transmission to be low on ATF than for you to overfill it by a small amount. |
09-07-2019, 05:38 AM | #27 |
Rep 70
It does not require a cooldown. You just have to get the trans fluid up to a certain temp, which is between 86-104 degrees.
