BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F15 10.2" Monitor installed to F30 car
      05-17-2019, 11:24 PM   #331
ADG@1979
Drives: E90 2016
hey I saw your post with the upgraded screen. I got a screen on ebay 65509296939 can this work on 2016 328i Entry_nav?
      05-20-2019, 01:34 PM   #332
SantaEugence
Drives: F30 330d xDrive Auto
Originally Posted by IK6SPEED View Post
Originally Posted by jaydaman93 View Post
anybody have broken screens to test cut the housing? to fit on dash without cutting dash? i have a 10.25 screen coming and would like to test cut on a dummy screen first.
I have test units available for sale which I highly suggest trying the cuts out on.
I went through 3 before I felt confident enough.
Are these broken units or complete ones? I've got one fitted but the previous owner wrapped it in black (badly) and also managed to snap it slightly in the process so I'm after a replacement surround piece...
      05-20-2019, 01:47 PM   #333
IK6SPEED
Drives: BMW M3 / AH3
Yes, they are the complete units but the screens do no work (as far as I know).
They can be used to replace the trim, test cut the trim....or even experiment painting or removing the silver/chrome trim from the exterior.
      05-20-2019, 02:35 PM   #334
SantaEugence
PM'd
      05-31-2019, 07:23 AM   #335
SantaEugence
Anyone else in the U.K. interesting in purchasing 10.2" surrounds to use as blanks or test pieces? Hoping to get a few on board to save on the shipping costs!
      06-20-2019, 02:58 PM   #336
714f30
Drives: 2015 328i
This is def one of my favorite mods. Full screen CarPlay is awesome!
      07-16-2019, 08:57 PM   #337
xxxjecxxx2
xxxjecxxx2's Avatar
Drives: F30 335i M Sport
2013 F30 335i  [0.00]
2015 F15 X5  [0.00]
2017 G30 540i  [0.00]
I have two 10.25 screens for sale. Tested with no damage .
https://f30.bimmerpost.com/forums/sh...8#post25035228
      07-20-2019, 09:38 AM   #338
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
Hey - Forgive me, not trying to be rude, isn't this as simple as popping out the trim with the air vents and undoing the 2 screws, sliding the screen out, then sliding the new one in? Optionally can trim the dashboard for a great look?
Is there something I am missing here? Is the screen way too large when driving? Looks like an easy win/win, no?
      07-20-2019, 03:01 PM   #339
IK6SPEED
It's a little more complicated trimming the CID and/or Dashboard than you are making it out to be.
But it's not a slide in and out retrofit.
That's why I suggest experimenting with a dead CID before operating on your good one.
      07-20-2019, 03:55 PM   #340
CntryClub007
490
Thanks for the reply, very helpful and appreciate it.
      08-16-2019, 10:37 AM   #341
dugarteb
Chile
Drives: BMW 430i
Originally Posted by yjypm View Post
no this only works with nbt evo. It uses a different input method (apix2 vs apix1) and a different voltage. You need to do a HU retrofit and that's a big project.
The best solution would be using 65509347878 which is plug n play for your car and is much cheaper.
Hallo, Please help me. It is possible to use BM 681638702 (BMW X5) screen in a BMW 430i, year 2018, VIN BA27941 ?. Thanks.
      08-16-2019, 11:55 AM   #342
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
Yes it's the one I'm using right now on my 18 m3. Some simple coding is needed.
Instagram:catpupu_f80
      08-16-2019, 03:12 PM   #343
dugarteb
Chile
Drives: BMW 430i
Thanks !! The assembling its really plug an play. It fit correctly ? (diferente car X5 to 430i).
Wich type of coding is needed. How can i do it ?
In this case work the touch panel ?
Thanks again.
Regards Daniel
      08-23-2019, 12:54 AM   #344
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
Thanks again.
Regards Daniel
You do have to trim some plastic on the back of the x5 display, be prepared to have a dremel and spend 3+ hours fitting it.
Coding is relatively easy, on my 18 m3 which comes with factory touchscreen just change the screen resolution to 940x1440 with BimmerCode. On 4 series LCI I've heard your factory touchscreen is disabled so you might have to turn it on somehow but it shouldn't be hard.
      08-23-2019, 08:20 AM   #345
Mikael335i
France
19
Drives: BMW 335i F30
Dear All,
Did this modification during this August during vacations
It was not so long to do it, around 2h30, with lot a patience!
I'm very happy, to have a bigger screen is now better, especialy for the GPS and watching somes videos and TV!
david51537.50
      08-24-2019, 03:27 PM   #346
dugarteb
Chile
Drives: BMW 430i
Hi, thank for your answer. Finally I decided to buy a 8,8" touch screen. My current 8,8" screen is not touch. I installed the new screen but the touch function is not activated. Pleas tell me how can activate the touch function. Thanks a lot.
Regards Daniel
      08-25-2019, 06:15 AM   #347
gecko.ch
gecko.ch's Avatar
Switzerland
17
Drives: G01 M40
Regards Daniel
Hi
Try this 2 valuea on the hu nbt:
CID_TOUCH to active
CID_HMI_TOUCH to active
      09-12-2019, 08:28 PM   #348
dugarteb
Chile
Drives: BMW 430i
Hi:
Thank, but how can I change this value ?
Is possible to do a hard reset in my NBT Evo ID6 to go back to the factory condition ?
Thanks again.
      10-14-2019, 11:36 AM   #349
gecko.ch
gecko.ch's Avatar
Switzerland
17
Drives: G01 M40
Hi:
Thanks again.
With e-sys or bimmercode app.
      12-16-2019, 11:26 AM   #350
mastrchee
mastrchee's Avatar
Drives: i4 M50
I have a F22 2016 NBTEvo B142 with ID4 and got a 10.25 screen from a 2015 X5, part number 9347878, but it doesn't turn on. At one point it just showed "No Signal", now nothing comes on.
Do I need coding to enable it? Any advice would be much appreciated
      12-17-2019, 02:35 AM   #351
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
https://f30.bimmerpost.com/forums/sh...;postcount=275
https://f30.bimmerpost.com/forums/sh...hlight=6816387
      12-17-2019, 03:51 AM   #352
mastrchee
mastrchee's Avatar
Drives: i4 M50
Thanks, I saw them. My HU is HW 2.3 and B142, so that's APIX1 right?
