09-08-2019, 03:23 PM | #1 |
Rep 40
2013 335i xdrive N55 70K Miles Common Issues
I am new to BMW. What are the common issues for a 2013 with 70K miles I should specifically look for?
What tech option is the first to cause issues? Adaptive cruise? Adaptive M suspension? The display control system? Thank you in advance. |
09-13-2019, 08:25 AM | #2 |
A family of bimmers
2745
Rep 7,741
Things i've had on mine which currently sits at 85kmi
Oil Filter Housing Gasket Valve Cover Gasket Electric Radiator cooling fan Front adaptive shocks Control arm bushings Both Front Door Lock Acutators Charge pipe Rear Differential leak Transfer case
09-22-2019, 08:12 PM | #4 | |
Rep 40
Engine gaskets don't currently leak but monitoring. What specifically on the front shocks failed? Do I recall the charge pipe is plastic, replaced with metal? |
10-10-2019, 03:00 PM | #5 |
Rep 225
Had any specific issues when you noticed shocks and bushings?
10-22-2019, 08:58 AM | #6 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
Thrust arms.
10-22-2019, 12:56 PM | #8 |
Rep 1,934
What caused you to change the cooling fan? Weird drivetrain error, fan staying on max u til you turn off the car, or both????
10-22-2019, 03:13 PM | #9 | |
A family of bimmers
2745
Rep 7,741
