10-09-2021, 03:44 PM | #23 | |
Rep 60
when you can go into expert mode in the required moduls try it |
10-10-2021, 05:27 AM | #24 |
Rep 26
I appreciate English isn’t your first language and maybe it’s lost in translation but I don’t really understand your reply.
I have tried it using expert mode in BimmerCode and it has worked. I now have cruise control. |
10-10-2021, 02:45 PM | #25 | |
Rep 60
I'm happy when everything works |
10-10-2021, 04:17 PM | #26 |
Rep 26
10-19-2021, 08:15 AM | #29 |
Rep 26
I now have full cruise control. Just had LIM function before which still works (just that the button says SET now and not LIM)
01-13-2022, 04:53 AM | #30 |
Rep 8
Hi. I understand its an old thread and not sure am in the right section (I'm a novice on these threads). Has anyone found an efficient way to retrofit ACC on F30 models?
01-18-2022, 01:33 PM | #31 |
Rep 162
What’s your definition of ‘efficient’? You need to buy all the components of the ACC system. Not cheap and a lot of work, though it is possible.
You need new: DSC pump, ICM ecu, ABS sensors, ACC radar, Steering wheel buttons, and cabling. Coding. |
05-08-2023, 12:04 PM | #32 | |
Rep 9
Replaced hardware left buttons (not the right set) on steering wheel and a wifi antenna added FA 544 (Cruse control) Replacing FA 6NH with 6NS (bluetooth-enhanced bluetooth). then coded the HU_NBTB2, FEM_BODY, ICM, KOMBI can't code FEM_GW (Gateway) as it's graded out. the bluetooth seems to have worked mostly (no text or email yet) but the cruse control still only sets limit on the middle Set button, limit (top left) and cruse control (Bottom Left) buttons do nothing still. As it 1/2 worked (bluetooth worked) (cruse control didn't) I presume I did it correct but unsure why its not worked. is there some thing different on LCI |
05-08-2023, 11:08 PM | #33 |
Rep 2,047
check if the MFL variant is set correctly.
FEM_01 > PfLinSteeringWheel 3140 > LIN_VARIANTE_MFL = DCC_Sports_SLD (this will vary according to your vehicles equipment) |
TheVillager211.50 |
05-09-2023, 12:12 PM | #34 | |
Rep 9
Front Electronic Module 3140 PfLinSteeringWheel LIN_VARIANTE_MFL DCC_Sport_SLD (0x71) ticked after checking them all I did fined the following as not active KOMBI L7_MID > PIA_Einheiten 3008 > HUD_PIA_ACC_DCC = nicht_aktiv (0x00) but as I don't have a Heads up Display I think it's correct Last edited by Darkie02; 05-09-2023 at 12:31 PM.. |
05-10-2023, 02:41 PM | #36 |
Rep 9
05-12-2023, 03:51 AM | #38 |
Rep 9
Not working still. going try changing out the cable and the right set of buttions over the weekend
Edit Did a check and found an error on the multi function steering wheel (wrong variant) changed the cable and right buttons removed the error and CC with brake now works. So there’s firmware in the right buttons that was stoping it working you have to change both. There is miss information on the forums saying only need to change left buttions that is wrong. Last edited by Darkie02; 05-15-2023 at 12:31 AM.. |
05-14-2023, 04:26 AM | #39 | |
Rep 5
Firstly, I want to thank your community for all efforts and knowledge ! I need to introduce myself before jumping into the details, I’m the last owner of an BMW F20 118d ´13 with a LIM option on a Sport leather wheel. I know I’m not on the good forum but Â… I have found here that research : the code for implement via BimmerCode on retrofit CruiseControl. So I after found that post I decide to lunch the operation ! I have found on eBay the part I want the CC + LIM (ref. 61 31 9 316 954 / https://www.hubauer-shop.de/en/switc...319316954.html), because it seems it is compatible with the car, and it is more logical to have a LIM button that a SET button whom act like a LIM button. So I have mount the new part, and write the new code part via le BimmerCode app, some of the lines are already « aktiv », and I have don’t implement HUD lines because the car have the 6.5´screen. But Â… I have some troubles. Firstly, when I start the car an alert message indicate the rear radar detection doesn’t work And despite, the LIM and CC button react, the two system go wrong and create errors. So I try some changes, I pass the line coding option to DCC to ACC : FEM_01 LIN_VARIANTE_MFL = DCC_Sports_SLD >> ACC_Sports_SLD ICMQL C_Fahrfunktion = dcc >> acc_sng And that changes delete the errors, keep the LIM button and action work find ; the CC button lighting up on COMBI but seems to not works. I have try the code in underground carpark, so I will limit to approx. 25 km/h speed and it’s dangerous. So this morning, I will understand the difference between DCC and ACC, and definitively the car have not the component to work properly with ACC. Thus, the good CC option is the DCC (the F20 have the brake assistance on uphill start), but it doesn’t work for me with this coding (quote). After other research, I wonder if a variant of coding is necessary for my case ? I have understand it is possible via Esys to obtain the good coding ? And, on last (very last) possibility, I hope no, the part isn’t compatible. But it seems unthinkable that no existing code to make it possible ? I need your help, and I will be very greatefull for that ! Best regards W. |
05-14-2023, 03:29 PM | #40 | |
Rep 5
To complete my last message I have made some tests to understand and try some code options. So when I code into ICMQL the C_Fahrfunktion to dcc, That create an error to the rear approximity alert : [IMG][/IMG] Traduction : faulty proximity warning if the vehicle drives too close, the system gives no warning I don’t understand why ? But that create this error. Secondly, I have try all the DCC option with SLD (speed limiter I think) : [IMG] symbole téléphone portable clavier[/IMG] And no options works yet. And to avoid the error message I have code ACC mode, and the cc don’t work but LIM yes. Please, if someone know something I will be definitely greatefull for your help Last edited by Wiiiwii; 05-14-2023 at 03:43 PM.. |
05-15-2023, 07:07 AM | #41 |
Rep 2,047
Ignore all acc options, you dont have active cruise control.
If you have LIM button choose SLD, if you have SET dont choose options with SLD. Set LIN_VARIANTE_LRE = nicht_aktiv. Try adding 544 Dynamic cruise control to fa and vo code all these modules ICM KOMBI HU FEM |
05-15-2023, 07:25 AM | #42 | |
Rep 5
Thanks you for your help ! My MF parts have LIM, CC button and +- roller. Here is the coding I have implement via BimmerCode’s expert mode : * FEM_01 > PfLinSteeringWheel 3140 > LIN_VARIANTE_LRE = nicht_aktiv * FEM_01 > PfLinSteeringWheel 3140 > LIN_VARIANTE_MFL = DDC_Sports_SLD * ICMQL > Daten 3000 > C_Fahrfunktion = dcc * ICMQL > Daten 3000 > C_SLD_Funktion = aktiv * KOMBI L7_MID > ERM_Konfiguration 3004 > DISP_LDM_1_ALIVE = aktiv * KOMBI L7_MID > ERM_Konfiguration 3004 > DISP_LDM_1_APPL = aktiv * KOMBI L7_MID > ERM_Konfiguration 3004 > DISP_LDM_1_CRC = aktiv * KOMBI L7_MID > ERM_Konfiguration 3004 > DISP_LDM_1_TIMEOUT = aktiv * KOMBI L7_MID > FZG_Ausstattung 3003 > LDM_VERBAUT = dcc My car have LIM option and PDC rear (only) if that can help ?! But with that code I have error (see above) and cc and lim don’t work I don’t understand where is the problem ? |
05-15-2023, 02:06 PM | #44 |
Rep 5
