BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Speed limit info - Retrofit
      06-10-2019, 06:33 AM   #1
antonius2018
Drives: BMW F32
Post Speed limit info - Retrofit
In my 2015-F32 I got
- S5ASA Driving Assistant
- S5ALA Active protection
- S6WAA Instrument panel with extended scope
- S6S3A Language version – Portuguese
For what I read this means I got the needed KAFAS2 camera.
But ... I DON’T have any kind of OEM navigation, I only got the 6,5” HU_ENTRYNAV (business radio without navigation). Afterwards I installed the AVIN USA Android 10,25.
Does anyone know if I can get the speed limit info retrofit?
If so, can anyone help me on how to do it?
      06-13-2019, 08:55 AM   #2
justsuvi
Drives: 2017 330ix
Not sure but as i know you should be able to install the maps and after that code the car to use this feature
      06-13-2019, 06:11 PM   #3
MarkoSK
Drives: BMW 3 GT
I think the speed limit requires professional nav, but I'd appreciate if someone would prove me wrong
https://f30.bimmerpost.com/forums/sh....php?t=1541914
Originally Posted by Sean750 View Post
This SLI retrofit only applies to F3x models that have the following options:
- Lane departure warning, collision warning: this option includes the KAFAS2 camera. You now that for sure if you have 'connectedDrive' stamped on the KAFAS2 camera, visible from the outside of the windscreen above the rear view miror. In my country this option is called 'driving assistent' 5AS
- Navi Prof 609
- 6WA or 6WB instrumentcluster
      06-14-2019, 05:28 AM   #4
antonius2018
Drives: BMW F32
Yes, I also suspect so, because, as far as I read, the system also reads the signs from the maps, so, with no maps, no system.
      06-14-2019, 05:29 AM   #5
antonius2018
Drives: BMW F32
The problem is I don't have maps as I don't have OEM NAVI (I have maps but on my Android system but that doesn't count).
      06-14-2019, 05:53 AM   #6
justsuvi
Drives: 2017 330ix
try to ask your dealer if they can install maps on headunit if yes it will cost you quite otherwise there is a way to install them diy
      06-14-2019, 02:41 PM   #7
antonius2018
Drives: BMW F32
They say there is no chance as the car doesn't have NAVI, but I'll ask them again.
