06-13-2019, 08:02 AM | #1 |
¯\_(ツ)_/¯
945
Rep 1,762
Advice needed for body roll reduction/new struts-shocks
Hey guys. My stock m-sport struts/shocks are due for replacement and after this past weekends autocross event I can see how the car behaves in high speed tight turns. I do track the car maybe twice a year so any suggestions for a comfortable ride without dropping the car more than 1/2" would be great. I do live in NYC and the roads/speed bumps do suck. I already scrape on speed bumps as is with the lip.
I saw that there are Bilstein B6's but their site states it's for non-sport suspension. For sport suspension they recommend B8's. I assume the B4 sport model would still result in the body roll or at least reduce is since the stock suspension is dead. As for sway bars I think I will do that later on as well. I did see a good tread on it and saw that H&R/Eibach are good options. The Hotchkins looked to be too stiff. Thanks for any help.
06-13-2019, 10:59 AM | #2 |
Rep 4,329
MacklinUSOB518.00 |
06-13-2019, 02:40 PM | #3 |
Rep 10,256
What's your budget for the suspension upgrade?
You mentioned several requirements which I think will warrant a closer look at adjustable coilovers: desire to maintain comfortable ride in NYC, occasional visit to the track, body roll reduction. |
06-13-2019, 08:11 PM | #4 |
Rep 2,036
06-22-2019, 08:46 PM | #5 |
BMW CCA Member
488
Rep 808
BEFORE you do any of that... have you replaced the Control/Thrust arm bushing?
If you have over 50k miles, you may be extremely surprised with a replacement... how the car loses the floaty feeling, gets a crisper turn-in, and lose that weird oversteer. I just added the Turner Monoball and holy smokes, it made me rethink suspension work on our F3X platofrm altogether. If ride quality is an issue, then consider poly or just replacing the old ones. |
06-23-2019, 10:33 PM | #6 | |
¯\_(ツ)_/¯
945
Rep 1,762
06-25-2019, 09:50 PM | #7 | |
Rep 785
06-26-2019, 02:42 PM | #8 |
BMW CCA Member
488
Rep 808
JVac:
I started a thread around the monoball set-up here... https://f30.bimmerpost.com/forums/sh....php?t=1624895 But even stock... you might be able to start noticing things: 1. Go into a sharp turn - does your car feel like it wants to oversteer 2. Excessive movement going over things like a speed bump 3. Vague turn-in feel For me, I bought the car at 49k miles so the bushings were almost within 10%-15% of their life (assuming destroyed by 60k). A monoball or even poly bushing is going to product some/more noise/vibration/harshness (NVH). For me, the noise is if I actually drive over something... like a road divot or rough pavement, but not road surfaces that are smooth-ish. No real harsh ride quality. Some vibration is the road surface undulates. But against handling and steering, you'd swear you were in a well tuned M car or God-forbid, a Miata or BRZ. |
Solidjake945.00 |
06-26-2019, 04:41 PM | #9 |
Rep 785
Many thanks for the update. I have read the other thread as well and it all sounds good to me. Vague turn in is the biggest annoyance for me. There is a long moment of uncertainty before it becomes obvious where the car will go and sometimes that requires a secondary input. Would be nice to have a more direct feel and be able to place the car consistently on the mark straight off, instead of playing the guessing game. My car has the LSD now, so oversteer is a different deal- I can induce it pretty easily with power input. Corner grip is much better and predictable up to the limit though and I don't remember seeing the dsc light up once in the 1200 miles since I got the diff in. Removing the abrupt, unsettling response from nanny dsc (or delaying it too a much higher threshold) was a great change. Together with monoballs I could rule the world! Lol
