BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > How to fix Wastegate rattle on 2012 328i?
      10-02-2018, 07:31 AM   #23
Montaxx
Montaxx's Avatar
Drives: F30 328i
Originally Posted by Solidjake View Post
Damn so you have the same thing.
Looking at the bootmod3 dashboard in sport the car has more PSI/boost so I assume the wastegate is open? Then in eco/comfort there is almost no PSI so I assume the wastegate is closed. With it being worn out and in the closed position it has that play and rattles. Having it in sport mode keeps the wastegate open a bit so it's not touching the turbo housing.... what a shame. Looks like we might need new turbos
I had my turbo replaced by the dealer 2 times. Rattling is still there
      10-02-2018, 09:14 AM   #24
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
Well..... that is a good thing if the sound you have it what I have so I don't have to spend the money on a new turbo.
The sound seems like it's coming from underneath the car? I'm driving out to a secluded area so I can attach my gopro to the car at various points to record the sound
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      10-07-2018, 07:15 PM   #25
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Can confirm this. Most rattle is in Eco and Comfort. In Sport it's almost gone.
Interesting gentleman. My car would rattle ever so slightly at low rpm in eco mode only. I am having my turbo replaced by the dealer for the exact same reason. We'll see what I end up with Tuesday when I pick it up. They've had my car for almost a week now.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      10-08-2018, 06:08 AM   #26
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
KC328_F30 awesome please keep us posted. I'm looking at options on how to put a high temp washer between the wastegate arm and the flange it attaches to on the turbo to reduce the space there and possible get rid of the rattle if it's that.
      10-08-2018, 07:53 AM   #27
kobluna
Drives: 320i
Do you guys also have very loud rattle at cold start? I have rattle every time I start the car and it lasts as long as cold start sequence so something like two minutes. It does not sound nice so I would like to fix it but I have not found definitive answer if it's really a wastegate or something else.
I've tried to hear where it's coming from but it's hard to say. It sounds like it's coming below the car and that's why I'm wondering if there is something loose in exhaust system? I don't hear any rattle when I'm driving but then again the rattle is not audible inside the car anyway. I only hear it if door or window is open.
Like you would probably guess, the dealer has no idea what it could be... I have tried to keep the wastegate actuator at still by hand but that doesn't make any difference in rattle. But I guess the rattling is happening inside the turbo anyway, right?
      10-08-2018, 08:49 AM   #28
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
kobluna If you have the stock exhaust check the flap that's in the exhaust tip and also the valve that moves the flap. Usually the clip that's there goes missing. That get loose and create a rattle. In my case I have an aftermarket exhaust with no flap.
Look at this thread on that
https://f30.bimmerpost.com/forums/sh...d.php?t=972489
      10-09-2018, 01:13 AM   #29
kobluna
Drives: 320i
Solidjake I should have emphasized it but I have 320i so I don't have exhaust flap. My exhaust is stock at the moment but I'm planning to get aftermarket dual exhaust at some point.
      02-02-2019, 05:14 PM   #30
Norbertino
RWD - positive
Norbertino's Avatar
Slovakia
Drives: Bmw F31 328i
Hello there, is anybody who found replacement for this wastegate flap and pieces around?
Thank you in advance guys.
      05-21-2019, 11:34 AM   #31
nico31
France
Drives: 328i F30
@solidjake
Hi, I’ve got the same issue, have you solve it ?
      06-03-2019, 10:34 AM   #32
fate_f30
fate_f30's Avatar
Drives: 2014 Glacier Silver F30 328i
I've just started noticing the rattle in my wastegate arm as well. I'm 2014 328, N26, EWG, and around 44K on the car. I hear the rattle when the car is at idle and it visually has "play" in the arm. Did I hear earlier in this thread that because of this my turbo may on its way out? Please confirm
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
      06-03-2019, 04:17 PM   #33
MacklinUSOB
Drives: f30 328i 6MT Sport
If you listen to any N20 or N26 car you'll hear the signature jingle. I've had it looked at by two independent Euro shops and both told me that unless you hear rattle on acceleration, it is working as designed. They also said that (following other commentors experience) the rattle would come back pretty quickly with a new turbo. Only way I could think of "fixing" it would be to have an aftermarket wastegate system fitted that doesn't slacken up so much when off throttle.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      06-03-2019, 08:07 PM   #34
fate_f30
fate_f30's Avatar
Ok, that puts me more at ease. Thanks
      06-18-2019, 05:21 PM   #35
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Any update anyone? Looking at the Bimmerworld MHI turbo as a turbo replacement for this year. But the questions is does that one suffer from the rattle as well?
https://www.bimmerworld.com/Exhaust/...-F22-228i.html
      06-18-2019, 05:56 PM   #36
MacklinUSOB
For those with EWG this may help but I'm unsure. For PWG surely not because they said you need to bolt on the existing wastegate assembly. Definitely would be cool if someone with real world experience can chime in because I too am curious.
MHI seems like the best option regardless of this issue, though.
      06-18-2019, 06:19 PM   #37
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Thanks mack. Yea mine is the electric one
      06-18-2019, 06:40 PM   #38
MacklinUSOB
No prob. If you don't get a response here I would totally reach out to BW and ask, they're cool guys. Maybe they take some measure to prevent the actuator from going totally limp off throttle. At the very least it's a whole new assembly and should be more quiet. Good luck.
Solidjake945.00
      06-25-2019, 03:57 PM   #39
328iking
Drives: 328i
Hi guys. I am from UK and have exact same issues as you guys. Had the car 9months. Thought exhaust sounded rough and got rougher. I had the timing chain and a new wastegate actuator fitted which eliminated most noises. But I am still getting the exact same noise as described here it’s driving me mad. I hear it lounly on cold start ups and it’s not coming from the wastegate (Cos I started with bonnet open) unless the sound literally travels down so I hear it under car but this doesn’t make much sense???
In comfort I hear the tinny rattley sound also coming from the drivers side (pass side in USA) front wheel under the car. I mainly hear it when driving down en closed roads whereby the sound echoes off the walls or surrounding bushes/trees etc (quite enclosed, I also reckon you could hear it while in a drive through too).
The bmw specialist thinks I am mad. Howver, soon I put it in sport mode the sound is nearly gone. Change back to comfort and instantly the tinny rattley noise returns. The bmw spec thinks it’s normal and is just a little play in the actual watergate flap which will not damage the turbo etc. The wastegate noise sounds more like a light knocking or a simmering pot and the lid is rumbling.
Personally I think there is something in dp or middle silencer that’s caught/stuck and rattling or the sound resonating from the flap in the tips and is coming back up the exhaust system. Anyway it’s driving me mad.
Doesn’t make sense but expect better than my £15k car to sound like an battered french car.
      06-25-2019, 04:33 PM   #40
CarlosC
Drives: 2012 BMW 328i
I had this same issue on my car. Had the entire turbo/wastegate replaced recently and I would say the rattle is about 90% gone to the point where I can drive with the windows down and its not annoying.
      06-25-2019, 04:36 PM   #41
328iking
Drives: 328i
I don’t think I can afford a new turbo and the mech said the turbo is fine and that any wastegate rattle won’t damage the turbo
      06-26-2019, 12:05 PM   #42
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Tried to get a vid from in car (didn't have time to put the gopro somewhere in the engine bay) you can hear it best towards the end of the vid. That rattle/rasp/zzzzzz sound. Is that what you guys have?
I'm going to tighten my actuator arm a little bit tomorrow and make a vid of the process
      06-26-2019, 12:13 PM   #43
MacklinUSOB
Yeah, that's the noise. Mine is far worse than that
Definitely let us know how adjusting the arm goes, I believe the arm adjustment is the same on EWG or PWG so that'll be universally helpful.
      06-26-2019, 12:16 PM   #44
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Man I can't imagine how it is for you. It's driving me mad. I will definitely let you know. Results are immediate when adjusted so crossing my fingers. Just need it tight enough to remove any slack in the arm.
