12-14-2017, 10:36 AM | #1 |
Rep 247
How I Am Choosing Tires
Considering the number of people who post on this board, I was surprised at the lack of consensus for proper F3x tire sizes. So, I analyzed my situation based upon information I’ve gained from this and other sites to make a tentative tire size decision. Now I understand why there isn’t the perfect set of tires for us. Please fact-check my analysis and tell me if you come to a different conclusion. This is a lengthy post, so feel free to skip to the bottom to read what I have come up with.
I recently purchased larger width rims to replace the 19x8 and 19x8.5 Type 403 wheels on my 335i M Sport with Dinan springs (about .5” lower than M-Sport suspension). My new 305Forged wheels have the specifications below. Front: 19x8.5 ET 32, 21.6 lbs Rear: 19x9.5 ET 40, 20 lbs The qualities I’m looking for in tires are indicated below by order of importance. In other words, I want the widest tires that will fit without rubbing or interfering with my speedometer reading.
There seems to be a general consensus on:
There is less consensus on:
I placed my front and rear wheels on ramps and attempted to measure the clearance from the tire to shocks and tire to fender. While I tried to get accurate measurements, I ran into a problem: suspension clearance gaps differ as suspension compresses in real-world driving, as does fender clearance gaps. Gaps in the rear were particularly problematic because the 12’oclock position has a lot more potential travel/clearance then the 3 and 9 o’clock positions. I had to eyeball and estimate these gaps, but I wouldn’t place a high level of confidence on their accuracy. Also, I couldn’t check on suspension clearances while turning. Clearances: Front -Inside: 19mm -Outside: 19mm Rear -Inside: 18-20mm -Outside: 18-25mm I used the websites below to calculate the height, suspension clearance, fender clearance, wheel diameter difference, likely speedometer error, and how much (or little) the tire will protrude from the rim as compared to the stock tire and rim. rimsntires.com tiresize.com I considered many different tire sizes Front Wheels Rear Wheels The charts show that there is no perfect tire size that matches every specification of the stock tires. But based upon my analysis, I am inclined to choose 255/35 x 19 for the front and 265/35 x 19 for the rear, even though there are problems with these sizes. This is my reasoning. Front: 255/35
Rear: 265/35
Do you agree with my analysis? Why or why not? **EDIT** I ordered Michelin PS4S 245/35x19 tires for the front and 264/35x19 in the rear. I chose not to get the 255s for the front because 1) I learned that matching diameter sizes isn't as important in the front, and 2) I don't want to risk rubbing during turns. **EDIT** I've been driving with my new wheels and tires for about two weeks now. Because the diameters of the old and new wheels are almost identical, there is very little difference in the stance or wheel gap of the car. The 245/35s are much wider than the 225/40 and I haven't encountered any rubbing. I have driven with four passengers without any rubbing in the rear or front. Wheel gap remains the same with Dinan springs as with my stock 403M wheels. I must say that I am very pleased with new wheels and tires with the sizes that I chose. Last edited by lkstaack; 01-08-2018 at 11:35 PM.. |
12-14-2017, 11:35 AM | #2 |
Rep 4,325
glad to see you're detailed. i'm pretty detailed myself but you're next level.
from the factory bmw speedos tend to read high. indicated speed is higher than actual speed. i believe the speedo gets it's signal from the rear wheels. a larger than oem diameter in the rear will cause the speedo to read closer to actual. 255/35/19, 265/35/19 will work, tires will have slight bulge up front, perfect rear (no bulge or stretch) 245/35/19, 265/35/19 perfect fit on both but front diameter and sidewall height is less than rear. bmw M-cars sometimes have staggered diameters like this causing somewhat of a foward rake. a typical set up for 19x8.5, 19x9.5 is 235/40/19(F), 265/35/19(R), 10mm stretch up front, perfect fit at rear. personally this is what i'd get |
12-14-2017, 11:50 AM | #3 |
Rep 247
12-14-2017, 01:37 PM | #5 |
Rep 247
12-14-2017, 07:48 PM | #6 | |
Rep 4,325
235/40 is 10mm undersized (stretched) for a 8.5" width (barely noticeable) however it is 0.6" or 15mm taller than the 245/35 so the fenderwell gap is reduced and the front and rear is diameter is the same 26.4F/26.3R. you could also do 255/265, 255/275 or i've seen 245/40, 275/35 . personally i don't like stretched tires. 235 is more for looks and 245 is performance. it's really close so either way will work okay. http://f30.bimmerpost.com/forums/sho...+265%2F35%2F19 http://f30.bimmerpost.com/forums/sho...+265%2F35%2F19 |
12-15-2017, 12:38 PM | #7 |
Cheapskate
4447
Rep 4,993
I usually try to reference performance companies that build aftermarket wheels. Dinan and APEX for us helps understand the best wheel/tire fitment for performance. Of course you can make a lot of things fit with stretched tires and/or an aggressive alignment. But for a good street car with less than 2* of camber, they seem to have very good options with more than enough tire.
The only reason i'd say more tire isn't always better is because a wider, stickier tire will also increase your rolling resistance. It's kind of like performance aero (wings, canards, etc). It can help, but only add it if you need it. Otherwise the penalty isn't worth the "improvement" if any is even there. And clearance to your suspension should no decrease under compression. as the damper moves, so does the hub/wheel. |
12-15-2017, 12:57 PM | #8 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
I currently have 235 on an 8.5" wheel and my wheels have paid the price for it. Do not go lower than a 245 on an 8.5" wheel. I'll be getting my wheels reconditioned and moving to a 245. |
12-15-2017, 08:36 PM | #9 |
Curmudgeon and Pedant
690
Rep 3,489
Actually, we can confirm the opposite. It's an average of all 4 tire rates, pulled from the ABS sensors.
12-15-2017, 09:40 PM | #12 |
Rep 247
12-15-2017, 09:47 PM | #13 |
507
Rep 1,005
12-16-2017, 09:08 AM | #14 | |
Rep 247
So, if the fronts were 1% smaller than stock and the rears were 1% larger, would the speedometer interpret that as stock? |
12-16-2017, 10:02 AM | #15 | |
690
Rep 3,489
2% difference in wheel/tire sizes is probably too much - especially on an xDrive car. But it's probably some sort of average - after all, that's what DSC has to do to decide whether to brake a wheel. |
12-16-2017, 12:01 PM | #16 |
Rep 243
That's not convincing to me that it's an average of all 4.. They could still take it from one wheel or one axle.
12-16-2017, 09:29 PM | #17 | |
507
Rep 1,005
I went to 19" 437M reps with 235/35 front and 275/30 rear; I noticed a distinct increase in the rate at which the odometer started adding up the miles. 10-minute drives around town (not on highways or interstates) would show I'd traveled 20 miles. While not concrete evidence in itself, it does suggest this theory of "averages" may play into this equation somewhere. Again, just pure speculation based on ancedotal evidence. |
12-17-2017, 09:37 AM | #18 |
Rep 243
I dunno.. you're talking about a difference of 2% here. You're not going to notice an odometer difference unless you consistently drive the same long route (500+ miles) and notice that you're now traveling more/less miles.
12-17-2017, 02:37 PM | #19 | |
507
Rep 1,005
I suspect the 235's being mounted on an 8.5" wheel caused them to be stretched and lose some height, thus throwing the equation off. For comparison:
All cars above saw the same daily drive, with comparable weekend driving; used a different car for long trips (good old 2006 E90 325i). Again, just pure speculation. |
12-17-2017, 03:03 PM | #20 |
Rep 243
You're just driving a lot. You're talking about doing 2.5k miles/year vs 16k miles/year. This is in no way explained by tire size differences...
12-18-2017, 07:23 AM | #21 |
Cheapskate
4447
Rep 4,993
that's really bad lol. you probably either a. want to get that checked or b. put a dash cam in the car and see who's stealing it every night
12-18-2017, 07:50 AM | #22 |
Rep 247
I have researched multiple BMW related websites now. Those that address speedometer sensors point to one location. Even though ABS sensors calculate wheel speed for each wheel, only the speed from the left rear wheel is used for the speedometer. Can you provide information that disputes this?
