06-20-2019, 10:19 AM | #23 |
Rep 325
Drives: 2016 F36
The reason cutting is involved for any axle back is because the factory exhaust is one piece from the downpipe back. If you are changing just axle back or just midpipe, you need to cut. If you are changing both no cutting required, just drop it out. I will add, that the AWE axle back is just another resonator, not so much a muffler. It's flows well but does sound incredibly loud with a catless DP. I installed my stock CAT back and love the sound now. Still on the loud side, but stock CAT, AWE midpipe and AWE axle back allows for plenty of growl and burbles (even without a tune like BM3). For a more refined sound with a catless DP, go with AWE midpipe, BMW MPE.
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
esoj37156.00 |
06-20-2019, 10:36 AM | #24 | |
Rep 461
HS S55 F87
MG B58 F30 - Gone MG N20 F30 - Gone |
Noelified228.00 |
06-20-2019, 12:46 PM | #25 | |
Rep 3,679
As a sidenote, you wouldn't be interested in trading your AWE muffler for my MPE would you? Sounds like you thought AWE and catless was too loud, so we could swap so you get quieter and I get louder... Just a thought
Noelified228.00 |
06-20-2019, 07:58 PM | #26 |
Rep 77
I've been thinking about getting an AWE catback, but I already have ER catless DP + Remus axl back. I want to get rid of the 2nd cat (mid pipe) does AWE sell just the midpipe or u would actually have to get rid of the Remus an go with the AWE catback?
06-20-2019, 08:24 PM | #27 |
Rep 461
You can buy the midpipe by itself.
HS S55 F87
06-21-2019, 11:47 AM | #28 | |
Rep 77
06-21-2019, 11:58 AM | #29 | |
Rep 461
I plan on getting the AWE midpipe and an AA exhaust. I am hoping I dont have to do any cutting, but if the tips on the exhaust stick out too much, I got my dremel ready.
HS S55 F87
06-21-2019, 12:04 PM | #30 |
Rep 461
I think you will be fine, honestly. Maybe, one of the guys with more experience on 328i exhaust set ups will chime in.
HS S55 F87
06-21-2019, 12:11 PM | #31 |
Rep 325
Drives: 2016 F36
You should easily be able to go AWE midpipe just bolt in. How was your Remus axle back put on? Did you DIY or did a shop do it. If it wasn't welded up to factory midpipe you should be fine. The factory muffler had to have been cut to remove it. I'll take a pic of factory Cat back so you have an idea what I'm talking about.
06-21-2019, 12:15 PM | #32 | ||
Rep 325
Drives: 2016 F36
esoj37156.00 |
06-21-2019, 12:16 PM | #33 | ||
Rep 325
Drives: 2016 F36
06-21-2019, 05:55 PM | #34 |
Rep 3,679
That would be awesome Let me know what you decide on doing... We're local-ish, I'm sure we could work out a meet-up.
Noelified228.00 |
06-22-2019, 04:06 AM | #36 |
Rep 184
Drives: 328i N26
CandyRedRC46242.00 |
06-22-2019, 04:10 AM | #37 |
Rep 184
Drives: 328i N26
Here's my setup with an ER catless dp and MPE with burbles turned up to max
06-23-2019, 12:57 AM | #38 | |
Rep 77
06-25-2019, 10:05 AM | #39 |
Rep 785
For what its worth, I love my DINAN axle back, sounds deep and "thick".
Only thing is it is quiet at high RPMs. Curious to add a catless DP one day but keep my 2nd N26 cat to see how it sounds. |
06-25-2019, 02:37 PM | #40 |
Rep 77
I run the Remus axle back + ER catless DP an 2nd cat stock. It's pretty loud but not awe loud.
06-25-2019, 02:48 PM | #41 |
Rep 420
I am running the Dinan axle back too and loving it. Even with a catless down pipe it is still a very mature and smooth tone. It is almost too quiet, but I am happy its not any louder late night and early morning. The cold start is pretty loud, but it settles down nicely after a minute.
06-27-2019, 01:27 PM | #42 | |
Rep 785
Did you say you installed one for a 330i on your 328i? |
06-27-2019, 02:05 PM | #43 |
Rep 420
I believe it was for a 430i, but could have been a 330i, I forget, but it definitely was not being advertised as for a 328i. It looked like a really close fit and was listed at $500 on ebay, so I jumped on it. I figured if it was off by a few inches or degrees the exhaust shop would be able to sort it out. It fit perfect.
06-27-2019, 02:26 PM | #44 | |
Rep 420
https://f30.bimmerpost.com/forums/sh....php?t=1464771 |
