05-30-2019, 03:56 PM | #1 |
Rep 743
'Best' compromise - springs & shockware vs b14's
Just grabbed a 2018 340i xdrive and the car does not handle the way it should considering it's supposed to come with a 'track' handling package. If you're listening BMW blue calipers don't qualify as representative of a 'handling' upgrade. Anyway so through my research and the budget I want to work with as yes KW clubsports for $4k would be unreal I am seeing the best bang for the buck compromise looking like pairing dinan or ACS springs with the dinan shockware. keeps the adaptive dampers and lowers the car and improves feel and handling all around that works for a winter and summer setup. or there is the very popular Bilstein B14 option. Slightly more money for adjustability and I would assume a slight upgrade in terms of feel and handling for an extra $500 or so.
If you have one of the above mentioned setups please tell me your impressions as i want to choose between one or the other shortly. I will also be swapping the stock 19 inch rims with lighter wheels and replacing the absolutely horrible bridgestone RFT with MP4S non RFT's. Please suggest a suspension setup that you feel is the ultimate compromise between daily driving but getting rid of bouncy bodyroll for around that $1k mark. |
05-30-2019, 06:08 PM | #2 |
Rep 483
Same boat as you. Unfortunately, what you're going to end up getting, instead of a compare and contrast from people who have experienced both setups, is people touting their own setup who haven't experienced the other option. Not exactly an unbiased, educated response.
quikM2371.00 |
05-30-2019, 08:06 PM | #3 |
Rep 3,539
Your goals aren't that clear IMO and what level of "comfort" people deem acceptable for daily driving varies. What level of compromise are you looking for? Do you care more for one or the other? What kind of surfaces do you typically drive one, ect.
I've gone from the Adaptive M suspension, to Adaptive M with Dinan shockware, to Adaptive M with Dinan shockware and Eibach springs, to a bespoke suspension setup and aren't quite sure how to answer your question that would really satisfy what you're after. I've also spent a considerable amount of time testing B14s on a very similar car as mine.
05-30-2019, 08:55 PM | #4 | |
Rep 832
Drives: 2019 G01 X3
05-31-2019, 10:52 AM | #5 | |
Rep 743
05-31-2019, 12:13 PM | #6 | |
Rep 10,256
- Dinan Shockware will be the most practical step forward without investing too much money with multiple suspension changes Dinan Shockware will turn Comfort setting into Sport and Sport into a more controlled (stiffer) setting. Your x-Drive suspension has plenty of travel (compression and rebound) to accommodate poor road conditions. Lowering is a different goal all together and will most likely exceed the target budget of $1.2K (CAD or USD?). Installing lowering springs with OEM softer shocks will not yield desired results as softer shocks will not manage spring oscillations well. The more expensive option is to replace OEM M Adaptive shocks with Bilstein B6 Damptronic shocks which are designed to work with OEM springs. The vehicle will not be lowered however. https://www.bimmerworld.com/Bilstein...Drive-EDC.html Set of 4 is $1.7K. To lower the vehicle while maintaining comfortable ride independent rebound and compression controls will give the opportunity to tune suspension behavior to your specifications. This is a more expensive option: - Coilovers with independent rebound and compression controls (KW V3 is a good starting point for research. The lowering range might be too low for Canadian roads and snow) - Add $: 4 wheel alignment - Add $: EDC cancellation kit (disables M Adaptive ECU functionality) or coding out EDC functionality I also suggest to research Ohlins R&T coilovers which can be set to near OEM height. |
sukhparm.748.00 |
05-31-2019, 12:29 PM | #7 |
Rep 681
All good points above! But replace Ohlins with something from Bilstein simply because Ohlins isn't xdrive compatible.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
05-31-2019, 12:33 PM | #8 |
Rep 681
Also I'll add that Farkie's setup is much more compliant over rough roads and daily driving than my b14s. Since you're running adaptive suspension, I'd likely opt to stay with a set of lowering springs to retain that functionality. Farkie did a lot of testing on adaptive dampers; including running them on a shock dyno to see what kind of range they have. They're more than capable of handling most lowering springs so you'll likely get the most bang for buck there.
Another option if you're looking for something more OEM is to use f8x springs with your adaptive dampers. You'll get a slight drop with a boost in spring rate over the adaptive suspension springs which are stiffer than the base springs despite being the same height as base suspension on xdrive cars.
2006 997.1 C4S |
05-31-2019, 01:51 PM | #9 | |
Rep 10,256
For some reason, 340i xDrive is listed as a compatible vehicle. Perhaps something changed. Phone call to Ohilns would be a good next step. |
05-31-2019, 02:33 PM | #10 | |
Rep 743
05-31-2019, 02:35 PM | #11 | |
Rep 743
05-31-2019, 02:40 PM | #12 | |
Rep 681
2006 997.1 C4S |
05-31-2019, 03:10 PM | #13 | |
Rep 10,256
1. Dinan Shockware first - no suspension geometry changes; no alignment 2. Add Dinan springs later if Shockware doesn't produce desired results: 30% stiffer; will lower the vehicle by 20mm front and rear. 4 wheel alignment recommended. Lowering springs will put more wear and tear on the shock. It's inevitable but may not be a concern depending on how long you plan to keep the car. |
06-01-2019, 11:15 AM | #14 | |
Rep 743
Does the 340 come with the M perf rear sway or is that also an upgrade? If I'm going to have to do an alignment after changing the springs I might as well do the rear sway at the same time and call it a day. |
06-01-2019, 05:00 PM | #15 | |
Rep 681
2006 997.1 C4S |
06-02-2019, 01:33 PM | #16 | ||
Rep 3,539
I thought shockware on the stock springs was a really good point for a daily comfort mode. With shockware and Eibach springs, comfort mode was pretty good too, not quite as much so as before the springs, but enough so that I never thought about the OE springs/shockware/comfort mode again. That said, I felt that eibach springs/shockware/sport mode was too stiff for daily driving and never used it aside from the track or where I needed lots of compression force. Based upon your statement above, B14s might not be comfortable enough for your daily driving, although that would be the best for body roll. You might want to try slightly stiffer springs first, and then shockware later if that's not satisfactory. I guess you need to ask yourself how much you're willing to compromise on those certain streets you drive regularly where you feel you need comfort mode.
06-03-2019, 10:14 AM | #17 | |
Rep 743
06-03-2019, 12:47 PM | #18 | |
Rep 3,539
Another bump stop avenue to consider is using F8x bump stops. They're shorter than F3x, but maintain a similar spring rate. The "dinan" E39/E60 bump stops are much softer than F3x/F8x ones. I've run both the E60 and F8x ones in the rear, and I like the bit better roll support of the F8x ones. I've run stock, "dinan" E39/E60, and rear F8x bump stops. Springs and bump stops is nowhere near 7hrs. It's a 4hr job if you know what you're doing and going at a leisurely pace. Yesterday I swapped my front springs for another iteration I'm trying, swapped my street brake pads back in (I was driving Laguna Seca Fri), and it took me 2.5hrs including setup and cleanup. Over the past few weeks I've done a couple of weeknight rear spring changes after work and those took me 1-1.5hrs including setup/cleanup.
06-03-2019, 01:43 PM | #19 | |
Rep 743
I think I have made up my mind after reviewing all of this and the best overall solution with some compromise here and there is going to be the dinan springs matched with the shockware and lighter wheels with MP4S. I am hoping that will really transform the handling enough to not make me throw my hands up and wish I just did the B14's from the start. |
06-03-2019, 03:18 PM | #20 |
Rep 3,539
If you're lowering I'd recommend going with shorter bump stops or chopping the OE ones to maintain enough damper travel before engagement. The OE bump stops engage pretty early on, and you'll want at least .75" damper travel before engagement. When I first installed my current Bilstein B6-based dampers (with Eibach springs) I did a travel check with the rear OE bump stops and found that at static ride height I was already engaging those bump stops. They're about 3.5" long, and the F8x and E60 rear ones are about 2.5" long.
06-03-2019, 08:42 PM | #21 |
Rep 49
I can confirm... Ohlins does not fit any xdrive F-series vehicle. I confirmed this with their BMW specialist, who is working on the E-series xdrive kit now, so F series will come... but much later.
I can't offer any feedback, but seems like there is quite a lack of options for Xdrive models. I haven't pulled the trigger yet but I am going to pick up the H&R coilovers myself. Add the sway bars and its a pretty complete kit for $2000. I'm stuck with the stock suspension which anything is going to be an upgrade...
2018 440i XDrive MSport Convertible
BM3 Stage 2 93| Dinan CAI | MPE Exhaust |
06-04-2019, 01:19 AM | #22 | |
Rep 3,539
