06-13-2019, 02:16 PM | #23 | |
Rep 296
Also: 1) do you guys think a different map could fix the down-low problem the CSF seems to have? E.g. pushing the smaller turbo more. When I looked at my current map, the power curve up until 2,000rpm is same as stock. So maybe there is a way? Link to my map: View post on imgur.com 2) For the Wagner - I assume it makes sense to go the v2 route. Any perspective on Performance vs Competition? Aside from the fact htat the Competition is 3kg lighter that is Thanks a ton! Last edited by luke1990; 06-13-2019 at 02:37 PM.. |
06-13-2019, 03:33 PM | #24 | ||
Rep 3,538
That said, in daily driving you'll certainly notice the lag more as luke1990 has. Quote:
2) I don't think you'd be happy with the Wagner EVO 1 line (and if that's the level of cooling performance you're after there are lots of others in that space that offer better value). For the EVO 2, I don't have any experience with the performance model, but it looks like there's less that differentiates it from its competitors, vs the Comp, doesn't really have any other direct competitors with respect to flow, weight, and construction. BTW, on your 20-40, 40-60, ect tests were those done standalone, or calculated as part of a 0-100/200 run? I believe its the later, but wanted to check.
luke1990132.50 |
06-13-2019, 05:22 PM | #25 | |
Rep 8,492
06-13-2019, 05:47 PM | #26 | |
Rep 3,538
For the EVO 2 Competition, nothing else out there really has the same combination of weight, construction, and flow from what I've seen (I'd be happy to be shown I'm wrong on this). You're going to have to compromise on some of those to go with a different unit, so it comes down to what your priorities are. If it's weight and flow, the EVO 2 comp is really hard to beat. If it's mainly cooling performance though, then you have options and the EVO 2 comp's price doesn't justify itself. For me it was lag during daily driving and cooling performance (for the track). The extra weight of the ATM didn't bother me. In daily driving both had lags that were acceptable to me, even though one was better than the other. On the track my data showed higher top speeds with the ATM, so since the two were equal per my thresholds elsewhere, that's what I chose.
luke1990132.50 |
06-13-2019, 06:34 PM | #27 |
Rep 8,492
Cheers FaRKle!
06-15-2019, 11:37 AM | #28 |
Rep 296
Hi all, thought I'd give you an update.
I tested yesterday at almost same temperature and both runs were with hard brake, peddal down, but no flag showing (for some reason my car just half the time doesnt properly LC :/). I'm using Dragy so keep in this in mind - it means that the times are in reality overall lower because dragy starts measuring when it feels car move which it does a bit before it launches without the flag. I'd say 0.2s. And the result are slightly adjusted, but I think overall with same message. You can see here that there is not that much of difference in 0-20 now. But overall still holds true that its slower down and better top. For me however the 2nd graph is more important as it represents the real world scenario - you won't be launching everytime you want to accelerate. And there you can see that the CSF just doesn't cut it. Also yes - all times are part of single run . So 0-20 followed by 20-40 etc. |
FaRKle!4016.00 |
06-15-2019, 11:41 AM | #29 | |
Rep 296
So - does the Wagner Comp 2 provide enough benefit over stock, or do you need to go to ATM to see those - real life I mean? |
06-15-2019, 10:29 PM | #30 | |
Rep 3,538
On the track the Wagner EVO 2 Comp is definitely worth it over stock. In daily driving you'd have to see what your charge air temps are getting to, to figure out whether it'll be worth it. Likely in commuting it won't make a difference, but what do your temps look like on the back/canyon/twisty roads you drive?
luke1990132.50 |
06-16-2019, 03:24 PM | #31 | |
Rep 296
Its central europe - so over summer its gonna be 25-35C (77-95F) - which is I think where it will make difference |
06-16-2019, 08:26 PM | #32 | |
Rep 3,538
06-17-2019, 02:01 PM | #33 | |
Rep 296
06-18-2019, 11:54 PM | #34 | |
Rep 3,538
How would you describe the lag you saw with the CSF?
06-26-2019, 09:40 AM | #35 | |
Rep 296
For me CSF felt like there was no power down low - even if I smashed the pedal to the floor, it didn't put you back to your seat until 3,000 RPM when it either pressurized, or the big turbo kicked in. So thats why it was much less enjoyable. I might still give it a chance with an Evolve tune - talking to Imran now. For the ATM btw - do you know if for the x35d you should get the one for 135/335i, or the one for 328d? I sent them two emails but didn't get a reply :/ I'm thinking the first, since the second is for N47 engines? |
06-26-2019, 12:27 PM | #36 | |
Rep 3,538
The N47/328d version of the ATM intercooler is the one that's compatible with your vehicle (fits N20/26/55/47/57 engine cars).
luke1990132.50 |
06-26-2019, 12:36 PM | #37 | |
Rep 8,492
As the ATM and the CSF units are, as far as I've read, almost identical in terms of external dimensions, and the CSF unit is a straight fit to the 30d/35d, it should be the case that the ATM IC for the 35i will fit the 30d/35d. We just need a guinea pig, correction "willing volunteer", to try it
luke1990132.50 |
06-26-2019, 01:49 PM | #38 |
Rep 3,538
I just re-looked at the ATM product pages.
Actually either of those two listings will work. I confirmed a while ago that the "BMW F20 F22 F30 F32 N55 135I/328I/335I INTERCOOLER 2012+" and "BMW F30 F31 N47 328D/DX INTERCOOLER 2014-2017" are the same intercooler. They just made separate listings for gas and diesel. When you originally said 135/335 intercooler I thought you were referring to the "BMW E80, E82, E9X N54/N55 135I/335I INTERCOOLER" listing, which definitely won't work as the inlet/outlets attachments are different.
06-26-2019, 05:02 PM | #39 | |
Rep 296
06-26-2019, 06:02 PM | #40 |
Rep 3,538
Yup.
luke1990132.50 |
06-27-2019, 08:56 AM | #41 |
Rep 296
Thanks!
And lastly - is there anything else worth getting from their shop? I heard a while back good references on their air intakes - but not sure they are even compatible for the F30 |
06-27-2019, 02:27 PM | #42 | |
Rep 3,538
luke1990132.50 |
06-28-2019, 11:10 AM | #43 |
Rep 296
So made an order today for the ATM FMIC. Hopefully the results will be good . Btw - I the cheapest shipment to mainland europe was $212 so not cheap. The most expensive one was >$900 .
On the flipside - I found one coupon that still works: BIMMERFEST10OFF - its 10% off the product (not shipping unfo). Its like 2 years old but still rocking - if anyone was thinking of ordering something |
visionaut1305.50 |
06-28-2019, 02:04 PM | #44 | |
Rep 3,538
