08-06-2020, 12:45 PM | #1 |
Rep 147
Spark plugs for N55
Sorry if this question has been asked so many times but I searched around and couldn't put together a definite answer so I'm asking for assistance.
I have a 2014 335xi with the N55 engine (of course) I'm running FBO with MHD stage 2+, stock turbo and stock HPFP I've read a few threads that say that I have to use a 1 step colder plugs but: 1. Don't know which ones are 1 step colder 2. Are there any pregapped at 0.022 which is the gap I seen recommenced Can someone enlighten me |
08-06-2020, 12:51 PM | #2 |
Rep 7,555
Just read this thread and my posts there: https://f30.bimmerpost.com/forums/sh....php?t=1709198
I basically show everything you need to change the plugs and which ones i ordered. You dont need colder plugs and you dont need a smaller gap unless you specifically have issues with the OEM plugs. As i tell everyone else, try a new stock set first and then go to the NGKs with a smaller gap if necessary. I run OEM Bosch plugs with stock gap (0.030'' out of the box) with no issues on MHD stage 2+ 91 and E20 maps. I just change mine like a month or two ago. Car ran fine even with the original plugs with 45k miles on them before i changed it. |
WaleeF3040.00 |
08-06-2020, 01:11 PM | #3 | |
Rep 147
08-06-2020, 01:28 PM | #4 |
Rep 7,555
If the rough idle started immediately after that service, then yeah, i would be suspicious of the plugs or anything else they touched. If not, it could be variety of other things... are you running an intake or did you disable cold start?
08-06-2020, 01:37 PM | #5 | |
Rep 147
I was thinking about that "reduce startup noise" option, is it bad ? |
08-06-2020, 01:44 PM | #6 | |
Rep 7,555
If you are getting rough idle i would also check for shadow codes and see if you get anything. |
08-06-2020, 01:56 PM | #7 |
Noob
70
Rep 254
Like thejeremyman said it is kind of a hit or miss in terms of that option causing a rough idle, for me it did a few times (after I selected "reduce startup noise") in the beginning but then I also enabled engine startup roar and I haven't had a rough idle since the winter I think.
FBO, MHD Stage 2+ E20, Xhp Stage 3
WaleeF3040.00 |
08-07-2020, 12:45 PM | #9 |
Rep 94
I have basically the same setup as you, just with 2 less doors, I have theses https://bmwsparkplugs.com/products/b...er-spark-plugs
gapped to .0200, runs great on them, only reason I did this was I was at 30K and wanted to do the plugs, but as mentioned above you can probably do stockers too. |
WaleeF3040.00 |
