07-02-2020, 01:17 PM | #3147 | |
Rep 7,598
2. Well yeah, PWG is totally different boost control method (pneumatic vs. electronic wastegate), and smaller turbo, so some boost tapering off at higher RPM is normal. 3. Not required, no. Its the kickdown, and you can get 100% throttle without depressing it. Its mostly just used to command the lowest gear possible (i.e., got quickly passing a car on the highway). If you run XHP, you can also set custom shiftpoints, etc, based on whether or not it is depressed. 4. Lol, that is actually pretty funny. |
itsrichierich186.50 |
07-02-2020, 02:20 PM | #3148 | |
Rep 1,079
07-02-2020, 03:21 PM | #3149 | |
Rep 7,598
MAF is relatively lower than 40 because it is a stage 1 tune. The 40s peak is for a stage 2/2+ tune. Not sure what you mean by IATs, MAF should not affect IATs, thats just his stock IC not being up to the task. |
07-02-2020, 03:28 PM | #3150 | |
Rep 1,079
EDIT: My MAF usually peaks at around 41lb/min, again just stage 1, however, I do have an aftermarket intake. |
07-02-2020, 04:12 PM | #3151 | |
Rep 7,598
EWG i would say yeah, typically the rule of thumb is +/- 1psi. What you see in his log would definitely suggest a leak for EWG. The BM3 targets are just really aggressive in general, even more so for what a PWG can sustain. For example look at boost control in my recent logs: https://datazap.me/u/thejeremyman9/2...&data=4-5-7-21 Interesting. I think his MAF big just be reading low. It is very erratic as i mentioned earlier. Not sure why it would be like that on stock intake. Perhaps it needs a cleaning. OP - do you use a oiled drop in filter or anything? |
thatBimmerBloke872.50 |
07-02-2020, 05:35 PM | #3152 | |
Rep 1,170
no gap stock spark plugs thats what protunning freaks said to use so i am using oem spark plugs
bmw m2
07-02-2020, 05:48 PM | #3153 |
Rep 7,598
OEM plugs should be fine. You didnt answer my other question... so i would check for codes and shadow codes if you have no already. You need to know if it is from a specific cylinder or what.
07-02-2020, 05:52 PM | #3154 | |
Rep 1,170
Yeah I try to make sputter or misfire like crazy and my car just does not throw any codes I check in my Bm3 for codes and I never get any codes ummm one thing I am noticing and I am thinking it might be the problem is my valve cover the crankcase is maybe bad or the pcv valve I read some where that that can give you misfires idk if that's true I am starting to get a smell of burnt oil on my exhaust and I also ready that maybe that's from the valve cover too And then my oil cap if I try to take it off while the car is on is really hard BECUASE is like a suction cup is just sucking it in and is kinda hard to open it up and I also read that that's another sign that I maybe have a bad valve cover What do you think ???
bmw m2
07-02-2020, 05:56 PM | #3155 | |
Rep 7,598
I have never tried to pull my oil cap off while the engine is running so i am not 100% sure if this car builds vacuum in the crankcase under normal conditions. |
07-03-2020, 12:35 PM | #3156 |
Rep 479
Hello all,
Went stage 1 a few days ago. So far so good but I feel the motor breaking up around 5k. I took two logs, one in comfort and one in sport plus. If anyone could help with the logs and see something I'm missing. Thank you! 2014 335i Xdrive n55 ewg 8at with 56k miles. Vrsf charge pipe Vrsf 5inch HD FMIC Oem plugs with 2k miles on them. Oem intake Oem down pipe Mperformance exhaust Comfort mode: https://www.bootmod3.net/log?id=5efe...0b435631b7d26a Sport plus: https://www.bootmod3.net/log?id=5efe...90c67f338e8c7e |
07-03-2020, 01:12 PM | #3157 | |
Rep 7,598
At the same time, the actual MAP vales are stuck at 100 the entire time, so something is definitely wrong with sensor/wiring, or there is just a weird datalogging bug. I would definitely email PTF to see what they say... Also read this thread in the meantime to learn more: https://f30.bimmerpost.com/forums/sh....php?t=1732327 Finally, you are missing a bunch of parameters to make sure you enable those before logging again. |
07-03-2020, 02:30 PM | #3158 | ||
Rep 479
07-04-2020, 02:39 PM | #3159 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
So I found the boost leak that you guys said I had. Following thejeremyman9 post about making and the process of making a boost leak test cap. It was the chargepipe to FMIC that was leaking (bad).
Big shout out to the o-ring store shipping my order out overnight even though I paid the standard 2 day shipping. However, in the end, none of the o-rings fit my EVolution Racewerks bolt ons. Attached is a picture of the OEM seal ripped as I installed it. I replaced it and tested for boost leak again and didn’t find anything. Here are my 2 logs after fixing my boost leak. Run 1 https://www.bootmod3.net/log?id=5f00...90c60719a21484 Run 2 https://www.bootmod3.net/log?id=5f00...0b431f18a319b3 What do you guys think? |
07-05-2020, 05:57 PM | #3161 | |
Rep 7,598
Having said that if you tested and have no leaks you have no leaks. You can email PTF, let them know you fixed a leak, and ask them if this deviation is normal. |
07-05-2020, 06:47 PM | #3162 | |
Rep 2,639
07-06-2020, 10:53 AM | #3163 | ||
Moto Lover
187
Rep 591
For now, I am going to keep my setup as is. Pretty happy with where it's at. Might look into small things like kickdown stopper and the BMW oil cooler thermostat blocker to keep oil temp down. |
07-06-2020, 11:17 AM | #3164 | |
Rep 7,598
07-06-2020, 11:39 AM | #3165 | |
Moto Lover
187
Rep 591
I might track my car a day or two as I wanted to see how the car would do at Chuckwalla, but I only considered those parts because they're like $50. trying to fill my "mod" needs without dropping $$$. Edit: The thermostat delete will do more harm than good I'm guessing? Last edited by itsrichierich; 07-06-2020 at 11:45 AM.. |
07-06-2020, 11:57 AM | #3166 | |
Rep 7,598
Gains are likely maximized when you also have an intake, or do MPPK airbox mod like i did. Oil T-stat delete is really just unnecessary unless you need it for track duty, and yes, especially if you live in a cold climate, you don't want to run it as you will basically have full oil flow to the oil cooler from startup and it will take forever for your oil to get up to temp (if it even does). |
07-06-2020, 12:06 PM | #3167 |
Moto Lover
187
Rep 591
How's the quality on it? For some reason I thought they were manufactured here in the states but it looks like it comes from Taiwan.
To keep things on topic, hows the BM3 trans flash? I currently have the Sport Auto Trans (2TB) which is butter smooth, almost DCT smooth, so I don't want to ruin it with the BM3 trans flash if it doesn't help. |
07-06-2020, 12:18 PM | #3168 | |
Rep 7,598
Can't comment from personal experience on the BM3 trans flash, but from what i have heard, XHP is definitely the better/more refined option. I don't think there are any problems with the BM3 one persay, but i believe some people reported slow paddle response and just overall not on the same level as XHP. I have the same trans and XHP was a big improvement over stock, just did it myself a couple months ago. |
