12-28-2018, 12:08 PM | #23 |
Rep 765
Code the rem too with vo and changed build date.
12-28-2018, 12:09 PM | #24 | |
Rep 765
12-28-2018, 04:04 PM | #25 | ||||
Rep 16
Thanks |
12-28-2018, 11:22 PM | #26 | |||||
Rep 765
12-29-2018, 09:37 AM | #27 |
Rep 16
12-29-2018, 09:48 AM | #28 |
Rep 765
03-14-2019, 07:20 AM | #29 | |
Rep 7
so where did you put new wires for K-CAN2 in FEM??? for left headlight: Pin 9 from headlight to Pin 21--A173*2B Pin 10 from headlight to Pin 20--A173*2B For right headlight: Pin 9 from headlight to Pin 50--A173*8B Pin 10 from headlight to Pin 49--A173*8B When i'm putting these wires,it didn't work,nothing at all. Even worser,KOMBI,HU-ENTRY are not working. How do You solved that?? F30 2013/07 Thanks. |
03-14-2019, 06:55 PM | #31 | |
Rep 765
03-15-2019, 12:21 AM | #32 | |
Rep 7
Had bad contact on left headlight CAN-Low, everything working fine now,looks amazing,especially with LCI taillights) Thank You |
Jhnblckwood130.00 |
08-07-2019, 09:07 AM | #35 |
Rep 277
I have a problem with adaptieve led retrofit, i have an F34 with adaptive bi-xenon from 2014.
Did the wiring according to newtis info, changed date to 1116, deleted 522 and 524 and added 552 and then vo coded FEM, REM, FLE43 and FLE44. Now the problem, low beam, high beam, direction indicators and vertical aim are working. What is not working is the DRL and adaptive function. On my cluster i get drl defect and if i read out with ista it says open circuit, no error for AHL. Annuone had this problem or know what the problem is and how to fix it? |
08-10-2019, 03:41 PM | #36 | |
Rep 765
08-11-2019, 08:29 AM | #37 |
Rep 277
08-16-2019, 04:50 PM | #39 |
Rep 765
07-30-2020, 06:28 PM | #42 |
Rep 2
FEM help
Hi, I,m new to this forum. I'm attempting to retrofit led headlights as well. My 320i was manufactured on 10/2014. I'm not sure where to install the pins in my FEM. I tried to put them where the PDF stated, but it caused my trunk, interrior lights and AC to stop working. Any help would be greatly appreciated.
08-08-2020, 05:03 PM | #43 |
Rep 2
08-09-2020, 04:51 AM | #44 | |
Rep 765
