07-28-2020, 09:27 PM | #1 |
Rep 625
Best upgrade for HIFI Audio?
So I've had harman kardon before and the volume mids and highs were decent but needed a little more
What is the best option for hifi without putting a hole in my wallet? I've looked into bimemrtech bavsound etc which easily add to 1500+ |
07-28-2020, 10:15 PM | #2 |
Rep 5,457
Drives: F30
Im no sound engineer but Ive heard that a quality amp alone will be a significant improvement over stock HiFi setup. Supposedly the speakers are sufficient for most ears just not powered to their fullest capabilities.
Im going off Billfitz expertise... hopefully Im remembering correctly as I plan to upgrade my HiFi system someday as well. |
07-28-2020, 11:30 PM | #3 |
Rep 2,805
Drives: F33 430 and F39 M35i
For plug and play, Match 7UP or Bavsound Revenant. Both are under $1000.
7Up allows you to fine tune. Revenant is just bam, more power easy setup. i went with the Revenant in my F33. Music is loud and clear with the top down on the freeway. |
Billfitz8243.00 |
07-29-2020, 12:13 AM | #4 |
Rep 500
Depends on your budget below would be upgrade priority (which I had done to my wife X3).
1. UP 7BMW (Tuning is important to get the most out of the DSP amp) 2. Speakers and underseat sub. 3. Trunk Subwoofer. |
07-29-2020, 07:20 AM | #5 | |
Rep 625
So you think the factory speakers are okay with those amps? My problem right now is they sound really high and too boomy |
07-29-2020, 09:34 AM | #6 |
Rep 16,082
Garbage in, garbage out. When the only control over what goes in to the speakers is bass and treble you can't get a fine tuned result. Even if you had speakers that are better than stock no speaker can overcome the lack of a good DSP EQ. Match 7Up is what I'd use.
07-29-2020, 09:47 AM | #7 | |
Rep 5,392
My friends/family seriously thought that I had upgraded the entire audio system. This setup fills out the bass like it should have been from the factory. |
07-29-2020, 11:04 AM | #8 | |
Rep 625
Should I do speakers as well? I want a nice filling sound with notes I can feel! |
07-29-2020, 11:54 AM | #9 |
Rep 16,082
See the post above from johnung. The Match 7Up has enough power to drive Earthquake SWS woofers. Get the 2 ohm version. There's nothing to be gained with changing the rest of the speakers, but adding tweeters to the rear doors is worthwhile.
08-04-2020, 06:12 AM | #10 | |
2021 X3 M40i
Rep 38
@johnung I tried to PM you but your inbox was full! |
08-04-2020, 07:00 AM | #11 |
Rep 1,245
Match 7UP
I went to a very highly regarded auto audio shop asking for new speakers. Owner laughed at me and said I didn't need new speakers - I needed a new amp. He suggested the Match 7UP, and it was like night and day. And it's something you can take with you when you sell the car. I went from a '14 F30 to an '18 F34, and the BMW dealer swapped amps on the cars for me while I waited (great dealer - BMW of Reading (PA)). After I got home, I changed the tune with my PC to the Match 7UP's default GT settings, and it was even better. |
08-04-2020, 08:20 AM | #12 | ||
Rep 5,997
08-04-2020, 09:11 AM | #13 | |
Rep 625
Did you get more volume out of the system? Did the underseat subs stop sounding like they were "farting" at high volumes? Does 7bmw amp have an option to emulate surround? |
08-04-2020, 03:27 PM | #14 | |||
Rep 5,392
08-04-2020, 03:30 PM | #15 |
Rep 2,805
Yeah. Pretty much standard setup.
Even my daughter’s 13 year old Chevy has the amp in the left rear. |
08-04-2020, 04:00 PM | #16 |
Rep 1,425
Another vote for the Match UP7BMW amp. It's simple plug-and-play, and your best bang-for-buck option for the HiFi. With the DSP, you can tune it exactly to your liking.
Regarding the surround sound option... not exactly (but close). There's a "StageXpander" feature to widen the front processing, adjustable in the DSP. You can also tweak the blend of the center channel related to left/right. Here's a link to the manufacturer's site: https://www.audiotec-fischer.de/en/m...ifiers/up-7bmw . Inside, there's a link to download the DSP software (DSP PC-Tool V4). You can run the software without the amp in demo mode to get an idea of the format and capabilities (select the proper amp before choosing demo).
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired Last edited by eleven11; 08-13-2020 at 07:27 PM.. |
wilbur_the_goose353.00 |
08-13-2020, 12:08 AM | #17 | |
Rep 90
Drives: 2013 BMW 328i
08-13-2020, 02:35 PM | #18 |
Rep 121
Another vote for the Match Up 7BMW, it really transforms the HiFi (S676A) system. I appreciate all the various threads and advice esp Billfitz. Equalizing the DSP is intimidating but other forum members have kind of already done it for you (link here - the PP82DSP settings are compatible).
Equalizing is tricky, but turning the "effect" features on and off are simple. Bass expander, center signal processing etc. And you can get a tape measure out, measure distances to your speakers and input them into the software, and it will calculate delays so you have the soundstage. Before I started research I contemplated replacing speakers, but now I don't think I will. If I decide to spend more money, it will probably be on a calibrated microphone, crossovers for the front doors, and/or the wifi control module. |
wilbur_the_goose353.00 sick_guy18.50 |
08-13-2020, 07:31 PM | #19 | |
Rep 1,425
Crutchfield (one of the only authorized online dealers) has it currently for $999. You can also find them on eBay.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
08-15-2020, 01:37 PM | #20 |
Rep 2,805
open trunk.
remove paneling. amp is left side. unscrew mount stuff remove amp replace amp put stuff back together this is in my f33, it will be much easier for everyone else, no convertible mechanism to get in the way. it took me longer to get around it then it was to swap the amps. I didn't even disconnect the battery. |
