08-07-2020, 04:34 PM | #1 |
Rep 27
Activehybrid 3 F30 N55 JB4 or BM3?
Hello folks currently driving a 13 Activehybrid 3 has the n55 with just the bms charge pipe will be adding bms intake, Wagner catless dp, csf fmic next week. My question is which tune would work best for something with my mods the JB4 or the BM3. I don't plan on upgrading the turbo anytime soon would really just like to get as close as possible to 400 hp. Will only track 2-3 times a year. Daily driven. Thanks in advance!
08-07-2020, 05:07 PM | #2 |
Rep 7,602
1. Skip the intake unless you just want noise, and get a dry drop-in filter. Consider a turbo inlet if you want to actually improve throttle response (MST V2).
2. Go flash tune if they are available for AH3 (i.e., BM3 or MHD). No need for JB4 unless you plan to add meth or need it for some other specific reason. 3. Ignore xxx HP goals. P.S. Car is clean for a 2013 |
AH35094.00 |
08-07-2020, 05:35 PM | #3 | |
Rep 27
08-07-2020, 05:46 PM | #4 | |
Rep 7,602
08-08-2020, 06:15 AM | #5 |
Rep 73
Ran JB4 on my e92 335 and it worked great. Got my 13 335 and decided to go with JB4 again(against others that had F30s) and regretted it because I always had to be fine tuning it. Switched to MHD and haven't had an issue since. With a flash you can just flash it and go without thinking about it. With JB4 you would need to keep tweaking it until you get your desired results.... If you actually do
08-08-2020, 04:28 PM | #6 | |
Rep 27
08-08-2020, 07:18 PM | #8 |
Rep 7,602
08-11-2020, 11:23 AM | #10 |
Rep 7,602
I recommend you also check MHD. I am not entirely sure their AH3 support, but it's worth considering in addition to BM3, and is my personal recommendation FWIW.
04-04-2021, 11:46 PM | #12 | |
Rep 7,602
CP doesnt really matter as long as it fits. Pick an IC depending on your climate and power goals. Nothing smaller than a good 5'' stepped. |
04-15-2021, 03:19 AM | #13 |
bt5000
Rep 45
The pipe between turbocharger and intake vales in my car easy to drop and leak.
04-15-2021, 05:26 PM | #14 |
Rep 7,602
